My laptop has error stop: 0x000008E (oxC0000005,0x804D91F9,oxf4f4c510,0x00000000) appears after trying to start windows XP can you help
  • 22 Answers
I have researched this and found that this is a memory error.You will need to replace your ram.Borrow some from a friend that has the same type to make sure. If that doesn't fix it, then it could be bad capacitors. If its the caps then you could replace them yourself if your handy with a soldering iron.Search "Bad Caps"and here's a place to find a tut to replce them badcaps.net
Hope this helps.
Posted on Dec 26, 2008
WINDOWS 7 to WINDOWS XP
hi you have to use a sat win xp to install it on your p c.get back to me if you did get it
Jun 18, 2017 | ASUS Notebook
Laptop goes on some few minutes after being shut down.
you cannot blame windows xp because according to me it is such OS that it removes many problems of windows 7 and vista.windows 7 and vista makes your pc much slow and many features dont work but windows xp is free from these errors.actually you hear the sound but nothing appears on the screen.this is because your cpu fan is running which takes somes time to stop.may be some problem of the hardware especially the mainboard.go to any repair shop and just get it checked.
Apr 02, 2012 | Toshiba Satellite Pro L300 Notebook
I am not able to install Windows XP on Compaq Presario CQ60-104TU
Recommend removing OLD DOS Operating system First. Then Install Windows XP. XP will NOT upgrade older systems unless it's Windows 98 and Fully Updated. However, can NO Longer do because Microsoft does NOT support any versions other than "2000/ME/XP/Vista".
Jun 09, 2009 | Computers & Internet
Insataling windows xp problms
i believ ur using 32 bit operating system.change the boot sequence by pressing F12 at restart and select cd/dvd rom option while the windows cd still inside the drive,,format the c drive completely{if possible format the whole hdd} and then reinstall the windows os xp..i hope it will work fine,,just follow the screen prompts very very carefully and u will find everything mentioned,,best of luck
May 14, 2009 | HP Compaq Presario CQ60Z Notebook
Cisco VPN Client Error
Hello
Try to switch off the Cisco VPN Stateful firewall.
Apr 19, 2009 | Computers & Internet
WHEN I START MY HP LAPTOP AFTERTHE WINDOWS XP APPEAR IT JUST STOP
It's not booting to the OS I take it. THen you need to do a recovery it you have one. First try F8 key when you turn laptop on try safe mode see if that boots. If it does restart F8 again try last know see if that one work that would be your last start up backup if that works you should be ok. If not then go to setup do boot from CD install your Windows CD restart your laptop and try doing a windows repair if that does not work then you will have to do a complete reinstall.
Good luck
Mar 20, 2009 | HP OmniBook XE3 Notebook
Start up problem
It appears that Service Pack 2 did not completely install. Try to boot into safe mode (F8 at startup). If you can, go to control panel, then add/remove programs. Scroll all the way down, select Windows XP Service Pack 2 and click "remove".
After it's removed, you will need to reboot, but the system should come up normally after that.
Hope this helps - please remember to rate :)
Sep 25, 2008 | Compaq Presario R3000 Notebook
BSOD in windows XP Professional
A stop error occurs when Windows XP Professional stops responding. Stop error messages can be caused by hardware or software malfunctions. The error messages appear on a blue or black background. The following steps, which also appear on the stop error screen, help you find out the cause of a stop error and how to fix the problem. To troubleshoot General Stop Errors: 1. Restart your PC. Unplug each new hardware device, one at a time, to see if this resolves the error. Try to run any hardware diagnostic software supplied by your computer manufacturer. 2. If this is a new installation of hardware or software, contact the manufacturer for any Windows XP Professional updates or drivers you might need. Click Get support, or find information in Windows XP newsgroups (under "Ask for assistance") and then click Get help from Microsoft in the left-hand column. 3. Check the Microsoft Hardware Compatibility List (HCL) to verify that all your hardware and drivers are compatible with Windows XP Professional. 4. If you can start Windows XP Professional, check the System Log in Event Viewer for additional error messages that might help identify the device or driver causing the problem. 5. If you cant start Windows XP Professional, try to start your computer in safe mode, and then remove or disable any newly added programs or drivers. 6. Search the Microsoft Knowledge Base for "Windows XP Professional" and the number associated with the stop error you received. Specific Stop Errors Some stop errors display descriptive messages such as "DATA_BUS_ERROR" that can help you determine the exact solution for the error. This section discusses how to troubleshoot specific stop errors, based on the type of error you receive.
Jun 26, 2007 | Microsoft Windows XP Professional for PC
Logitech drivers causes system error using XP. LVckap.sys
View this site for possible solutions http://forums.logitech.com/logitech/board/message?board.id=quickcam_software&message.id=518
Jan 19, 2007 | Logitech QuickCam Orbit Personal Web...
Computers & Internet Logo
55 people viewed this question
Alun Cox
David Payne
David Payne
