Question about Hyundai X224W
Hyundai monitor on for 5 minutes and screen goes black
When you first turn on the monitor it works perfect, screen is beautiful, after about 10 minutes screen goes black, nothing on the screen, not sleep mode, power is on, lights are on, sound works from speakers. When screen goes black, no picture, nothing returns the screen, not safe mode, not resolution, not changing hertz. if I unplug the monitor and power off for 5 or more minutes, when I plug back in, the display comes back on for about 1 minute, then goes black again. I think it my be the sync board, but I'm not sure where to purchase one. Any help would be great. Thanks
SOURCE:
  • 63 Answers
SOURCE: flashes on then goes black
The green light only lets you know there is a valid video signal reaching the monitor. If the green light was not "on" your problems would possibly be within the pc itself. Something is not holding the circuit for the backlight "on" thus going black. Suggestions are: 1. Take it to get it repaired (if not under warranty) Hyundai carries a 3 yr warranty on this monitor. Website provided. 2. Buy a new monitor http://www.hyundaiq.com/Eng/Customer/CusSvc/Csvc.asp
Posted on Aug 27, 2007
jomama5509
  • 87 Answers
SOURCE: Hyundai LCD monitor L70N Stuck in sleep mode?
push and hold the power button... then hit the settings button on the monitor and goto power>sleep mode
Posted on Jun 17, 2008
SOURCE: Monitors goes black - Hyundai Q17
I can verify after opening my monitor up as well that the solution posted by W_Steenhuis does in fact work. The power cord itself didn't have an adapter, but the power "adapter" was in the base of the monitor itself. The big circuit on that was where I found a diode and resister side by side that were badly burnt. I basically put some solder down each of the connections to the board to broaden the overall connection of each just to make sure that there were no gaps. Now my monitor works :)
Thanks again, W_Steenhuis.
Posted on Nov 07, 2008
SOURCE: after a few minutes the screen just goes black. If
may be there is a problem with your power cable. It might not be as tight as it should be or maybe the VGA cable is not tightly screwed up. Please check those physical connections and if it is still goes away after 3 seconds, take notice if there is any message appears on your screen. If there is no message, try to use another power cable or another VGA (blue) cable to it. If still did not work, try another CPU (Tower) if it will work. Otherwise, consult Hyundai for your Monitor repair and diagnostics....
Posted on Nov 23, 2010
SuperTech-11
  • 1591 Answers
SOURCE: hyundai L19T : power bottom
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom (look for discoloration of the circuit board around the base of the capacitor) need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the unit will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and/or inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are SURE it's only doing supply output ripple filtering,
and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
Backlight related video here:
http://www.youtube.com/watch?v=6XoF6QZ1dmw&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors, amplifiers, computer power supplies and motherboards, and other electronic equipment.
The parts are cheap, and skill required is minimal.
A great parts source is Digi-Key, and you can order the parts online at www.digikey.com
They typically cost under a dollar a piece plus a flat shipping rate.
The parts usually arrive one business day later.
If you watch the third video, you will see that even someone with no soldering experience can perform these repairs as demonstrated by the woman in the video.
Posted on Jul 21, 2011
Screen goes black after 5 to 10 minutes of operation. Comes back on for seconds if monitor is turned off then back on
there is a screen light board defective as inverter board. there are on the market, some inverter boards available to LCD Monitor, Check for diemen Company on this site: http://www.hrdiemen.es/products/esp/index_esp.php
Dec 23, 2009 | HP w1907 LCD Monitor
Screen comes on then goes out in 5 seconds. The backlight goes dark but the seen is working, just can't see it. The backlight is out...
mark587, Did you shine a very bright flashlight 1" from the screen to try and see the WIN-desktop ?? Even though the screen appears BLACK. Your words above said: JUST CAN'T SEE IT Did you really NOT see anything? Have you seen any of the longer video clips of "LCD Monitor Disassembly" on YOUTUBE? Some BLACK screen "symptom" lcd displays can be repaired for less than $10 in parts. Capacitors! Also check videos on lcd repair. Then get back here to fixya and I or any of the guys can help you decide what to do with your display whoose screen is now dark and lifeless. After doing the YOUTUBE thing you may even tell us what you will do!!! Hope this was helpful. Yes we do want to hear back from you. please rate this response on fixya. I'm louie12fix on fixya or lmistyrel @ aol.com. Bye for now.
Oct 07, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
When monitor power button is pressed, a small white image appears and alternates briefly between an alalog and digital icon in black then the screen goes blank, no color.
My issue is similar.. however after trying a couple of times it will work. (yes everything is plugged in) It will function for a good 10 minutes before just powering off (blackout) screen.
If you attempt to turn it on after it blacking out, the blue led for the power button will blink a couple of times and it will remain off.
However if you wait 5-10 minutes and turn it back on, it will repeat itself...
I have it hooked up to a radeon X1650 graphics controller as a secondary digital controller, and its hooked up by VGA cable.
I also have two other displays besides this one (one primary and extended that dont have any issues whatsoever.. they continue to function while the syncmaster 193p takes its time snoozing.... please help.
Mar 17, 2009 | Samsung SyncMaster 193P 19" LCD Monitor
Monitor goes blank after 5-10 minutes
You may have a compatibility issue with your monitor. You computer may not be putting out enough power to support your monitor. Check your users manual on your monitor for output requirements. If the monitor's manual has a number to call, call the manufacturer to see if there are any compatibility problems between your computer and your monitor and calling the people who built your computer as well. Get as many scenarios as you can to find a solution. Hoped this helped.
Oct 04, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
17" LCD Monitor - only works for a few seconds when turned on.
It seems to be an Inverter related problem in which backlight seems to be shiutting down.Is this monitor 3-4 years old???If so backlight of the panel could be an issue.
Feb 15, 2008 | Microsoft HannsG HU171D 17" LCD Monitor
Screen turns black after 5-10 minutes
check the power options in os from control panel whether the option "turn off the monitor" is in "after 5 mins" if so make it never....
if not check in bios power and frequency control properties...
Feb 06, 2008 | Sharp ll-m17w1u 17" Flat Panel LCD Monitor
Good picture for 30 seconds then screen goes black with a faint ghost of the image
the 12V is for speakers.. the 245bw takes regular 120V AC (same cord as your computer)
the buzzing is annoying, though. i don't know if it's a "feature" or just a side effect.. ie, if i could take the case off and poke around, i would. 4 times out of 5 it's some dumb piece of tin reverberating from a transformer or something..
Dec 03, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Scanport H21 problem.
Fried chips? Tech with electronic repair requested.
Sep 08, 2017 | Scanport H21 21" LCD Display Monitor
HP mx705 17 in.CRT Conventional Monitor vertical goes bad
While it is sounding like a hardware problem. I'll throw in my 2 cents. Have you check the cables from the power to the source and from the monitor to the computer. Just make sure those aren't loose. One other thing...you mentioned you turn off the computer "afterwards" then it fixes itself. Is the fix for longer than it turns on at first? or does it stay on longer then goes out? Let me know what happens. Good Luck, Tim
Mar 14, 2007 | HP mx705 17" CRT Monitor
Hyundai X224W Logo
173 people viewed this question
Top Hyundai Computers & Internet Experts
 Mike M
Mike M
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
