Question about Kenmore 74972 Gas Dryer
Won't start after flood
Our basement flooded for the first time ever (8 inches of water). In less than a day we drained the water. Our Kenmore gas dryer (model 79831) is not going on when the knob is pushed. Will it go on when it thoroughly drys? What can I do?
  • 87 Answers
First I would remove motor and put it in an oven for a few hrs at min temperature like 200 degrees then I would remove motor centricical switch and push in the actuator tab a few times, then put it back in. Use a cheater cord plugged into pins 4&5 and see if the motor runs, it should.
Posted on Jun 08, 2007
Had a patio put in and Contractor apparently did NOT hook up or install drainage pipes deep enough into the as my basement has flooded three different times
im not sure that the patio would have much effect on flooding in the basement
hi precipitation this year and a higher than normal water table which is the lvel below ground that if you dig into starts to fill with water.
your problem is more likely a drainage issue are there any sump pumps in your basement or does it at least have a floor drain if so perhaps there is a clog
call a plumber and the patio contractor and have a professional determine the reason for the flooding
ps you can purchase portable sump pumps you can set on a flooded floor and plug in and they will pump out water when the floor floods automatically
Simer 1/4 HP Portable and Submersible Utility Pump (4)
Questions & Answers (15) $8999 /each
Overview This versatile pump is lightweight and easily taken to remove water. Heavy-Duty Aluminum Construction for durability. Pumps up to 1320 Gal. per hour and comes with a male garden hose adapter. Home Improvement Made Easy with New Lower Prices Improve Repair
Feb 09, 2018 | Washing Machines
Basement was flooded and water cover electronics,
TURN OFF ELECTRICITY before touching gas or electric water heater this is or was flooded.
Replace flooded gas or electric water heater.
Warranty is void, all manufacturers say replace water heater, and even if parts are replaced, there is no guarantee that unit will work again.
Resources:
http://waterheatertimer.org/Flooded-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 01, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a Kenmore 600 electric dryer. The basement flooded and the dryer was in approximately 6 inches of water. I've removed all the water from the cabinet and let it sit for 2 days to completely dry out....
Sorry to say but water ruined the motor. You can test it again by pushing the start button and at the same time spin the motor. If the motor starts that will tell you the start windings in the motor are bad. The motor would have to be replaced.
Mar 20, 2010 | Kenmore 63942 Dryer
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
04 RX8 won't start??
Hold the gas pedal to the floor and try starting the rx8 has anti flood technology that gives less fuel when gas pedal is to the floor I do it all the time hope this helps
Mar 07, 2009 | 2004 Mazda RX-8
Water fill never stops - never! on Kenmore Model 665-16379301
I had this problem and the drain hose had become disconnected. I had a flooded basement.
Jan 10, 2009 | Kenmore 16919 Built-in Dishwasher
Kenmore 74972 Gas Dryer Logo
444 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
