Question about Dryers
My dryer will not heat up
It is a whirlpool LGN2000 and only 5 yrs old
  • Anonymous Dec 26, 2008
    my clothes dryer is running but is not heating up
  • 21 Answers
First make sure the circuit breaker on the house 9the one for the dryer) is not popped. it takes only one leg of the 220 to turn the dryer, but it takes both to heat it. If the circuit breakers are ok, you need to check the heating element, and the internal fuses in the dryer.
Posted on Dec 27, 2008
  • HNHAPP Dec 27, 2008
    MY MISTAKE, IT LOOKS AS IF YOU HAVE A GAS DRYER.....
    check the ignitor. if that is fine, you may have a bad fuse in the dryer
Electric Whirlpool dryer m11036334, dryer will not always heat
Sounds like a limit switch has broken. Doesn't sound too expensive to fix.
Nov 14, 2016 | Whirlpool Dryers
I have a whirlpool dryer (wed5540sq) and will not heat. it is only about 2 yrs old. I have put a brand new plug on and it does nothing. if i put the old plug back on, it will turn but not heat
Hello & Welcome to FixYa
As everything in your dryer is working fine apart from it heating properly so the recommended repair will be thermal fuse/thermostat replacement. However, you can also test its continuity before replacement. Please get back to me if you have any other questions.
Kevin
Dec 06, 2010 | Whirlpool Dryers
GGW9200LW0 whirlpol dryer runs but ther is no heat. It is 8 yrs, old. Waht to do?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 19, 2010 | Whirlpool GGQ8831L Gas Dryer
Lightning strike power surge partially disabled dryer.(Whirlpool)
If it took a lightning strike something in the heating coil is shorting to ground tripping the breaker. DO NOT Keep trying it, you could cause more damage or even burn your house down.
Sep 29, 2009 | GE Profile Harmony DPGT750EC Electric...
Whirlpool DWJR - ELE, Model LER7646EQ2, about 12 yrs old.
belt may be broke since you hear the motor running.
Sep 22, 2009 | Dryers
No heat
i'll guess the lint filer is on the top?remove the back panel,check the fuse on the heater box,it is on the left side top,also check the heating element to see if any of the wire is broke,let me know what you find-mike
Apr 14, 2009 | Dryers
Whirlpool dryer model LEB6000PQ0 its not heating up anymore''it starts it turns but the clothes dont dry its only 2 yrs old.
check your breaker first.A dryer will run on 110 but wont heat.if not breaker it could be your thermal fuse or element.the thermal fuse is located on element cage,unplug machine and test for continuity to your thermal cut off fuse which will be the top one on cage and check continuity to element.
Mar 08, 2009 | Whirlpool Dryers
No heats from the dryer. the mechine is 4 yrs old.
First thing is to check the fuses. Often there is a separate line for the heating elements. If that fuse or circuit breaker is tripped there is no heat but the dryer will still turn.
There are heating elements behind the drum that may need to be replaced if broken. Also check thermostat control.
Sep 16, 2008 | Whirlpool Dryers
Dryers Logo
157 people viewed this question
Top Dryers Experts
