Question about Dryers
We have a whirlpool gas dryer that just stopped heating up. I pulled out the little square window on the front bottom and there is no flame. It is a LGN2000
  • 2 more comments
  • LaShun Dec 29, 2008
    What does the thermal fuse look like? And what should we do?
    If you are talking about the white piece that is attached by one bolt, we took that off, and put it back on, but it is attached to two green wires, which we did not try to take off, they seemed to be on really tight. How do we check if it's not working?
  • LaShun Dec 30, 2008
    Thank you! After putting the wires together and bypassing the fuse, we found that it worked! We will replace it today!
  • Dave May 11, 2010
    Does the ignitor glow at all?
  • 113 Answers
The thermal fuse is white with 2 prongs. Here is a link. It may also have a round plastic base instead of a narrow plastic base.
Posted on Dec 29, 2008
  • 3 more comments
  • Dave Dec 29, 2008
  • Dave Dec 29, 2008
    Dont know if this posted earlier but heres the link to a pic and to purchase a fuse.
    http://shop.washermd.com/product.sc?cate...
  • Dave Dec 29, 2008
    Its # 7 on this diagram. You access it throught the front bottom panel. If you unplug the dryer. Take off the 2 wires and conect them, basically bypassing the fuse. Make sure the wires dont touch anything else. Connect the 2 wires a nd turn on the dryer. If the flame comes on, youve found your prolem. Other wise if you have a voltmeter you can do a check as well. Dave,,www.washermd.com
  • Dave Dec 29, 2008
    try that again
  • Dave Dec 29, 2008
    its on the blower housing
  • 179 Answers
If the ignitor does not glow check the thermal fuse
Posted on Dec 26, 2008
I have a whirlpool lgq8611pw2 gas dryer. it has stopped producing heat. gas supply seems fine and other gas appliances work fine. Took front lower cover off and blew out dust> pulled and replaced...
go to this site..
I think the first item is what is bad. here's where to start.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-5-654402-/new/Whirlpool-Dryer-not-heating-LGQ8611PW2
Jan 07, 2018 | Whirlpool WGD5200TQ Gas Dryer
My whirlpool gas dryer is taking twice as long to dry clothes. I cleaned all vents and filter and also ran it with the exhaust vent disconnected and dryer still did not dry any faster, but there was a...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Nov 25, 2010 | Whirlpool Dryers
DRYER RUNS BUT NO HEAT BELEIVE IT TO BE HEATING ELEMENT
With the gas machine you won't actually have a heating element. What you will have is a burner assembly. There are a few common things that can cause a gas dryer to stop heating.
The dryers have a square cap on the front near the bottom. Remove this with a knife or small object. Looking through this hole you are face to face with the burner assembly. Turn the machine on, if after 10-15 seconds you see a glow and the flame starts, you probably have a bad set of coils. Coils can allow the dryer to start, but after the flame goes off, they have problems starting it again. So, when you come back and find damp laundry, it may actually be heating, just not very well. IF there is no glow when you look through the peep hole, keep reading.
The most common part is a thermal fuse. This fuse is located on the back of the dryer. Simply unplug the dryer, pull it out, and remove the back (Eight 1/4 screws). The fuse looks like this http://www.appliancepartscompany.com/xcart/images/D/3392519.JPG it will be on the lower left hand side. If you do not have a multimeter to check continuity you cannot be for sure. This is a cheap start to figuring out your problem.
If you have a multimeter simply check the two terminals where the wires were plugged in for continuity. It should read about .1. This fuse goes bad when it gets to hot. There are few reasons this happens, but the #1 reason is that the vent to the dryer is clogged in some form or fashion. Outside the house where the vent exits should have a strong air flow while the dryer is on. If it is clogged by any means, the hot air cannot escape the dryer and the fuse will blow.
Two of the other commonly replaced parts are inside the dryer, accessible from the front. These parts are the ignitor and the coils.
May 28, 2010 | Whirlpool LGR3624JQ Gas Dryer
Gas won't ignite, no heat. were to start troubleshooting.
If the motor is running you need to determine if the glow ignitor is coming on.
On the front of the dryer in the lower left corner is a small plastic square, pry this square piece off.
Start the dryer in a heat cycle and watch through the window.
- If the ignitor glows for a while then shuts off and no flame appears the problem is the gas valve coils.
- If the ignitor glows and does not stop glowing the problem is the radiant sensor
- If the ignitor does not glow and you hear a 'clunk' every few minutes from the area close to the small window you are looking into then the ignitor is bad.
- If there is no glow and no clunk the problem is most likely the thermal fuse or thermal cut off.
- the thermal cut off trips if you have a venting problem and there is inadequate air flow
Sorry this is so lengthy, but there is a lot that can cause the symptoms you described.
Let me know if you need more info....
Apr 23, 2010 | Whirlpool LGB6300 Gas Dryer
Whirlpool gas dryer, model LGR5636EQ3, runs and drum turns but it won't heat. What part do I check and where is it?
Usually the coils (2 black) on the gas valve. If the ignitor comes on, no flame and the ignitor goes off...bad coils...they are usually located inside, on the bottom towards the front of the dryer.
Oct 25, 2009 | Kenmore 73952 Gas Dryer
Dryer wont heat
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 279834.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a 5/16” hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Take careful note of belt configuration BEFORE removing it. Draw a diagram of its travel.
Motor and idler pulley for dyer will be on right. Gas components will be on left. Replace All coils with Kit Number listed above. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
Reverse process to re-assemble.
Sep 07, 2009 | Whirlpool LGR5636L Gas Dryer
How to replace gas coil valves on Whirlpool LGR5636EQ3 Gas Dryer
DOES YOUR DRYER HAVE THE LINT SCREEN ON THE TOP? IF SO, REMOVE THAT AND TAKE TWO SCREWS OF(CARE NOT TO DROP IT INTO THE VENT). PULL THE TOP PANEL TOWARD YOU LITTLE BIT AND LIFT UP, THERE WILL BE TWO 5/16 SCREWS INSIDE FRONT PANEL, REMOVE AND UNPLUG THE LID SWITCH CONNECTOR, FRONT PANEL WILL COME OUT. THE GAS VALVES AND COILS ASSEMBLY WILL BE ON THE BOTTOM RIGHT. UNPLUG AND TAKE THE SCREWS OFF THE BRACKET AND REPLACE COILS. CHECK FOR CONTINUITY ON COILS, IT SHOULD READ 1.3 TO 1.9 OHMS. THE ONE WITH THREE TERMINAL, CHECK OHM FROM MIDDLE TERMINAL TO OUTSIDE TERMINALS.
BOYNISMO@YAHOO.COM 714-334-1998.
Aug 21, 2009 | Whirlpool LGR5636L Gas Dryer
Hello, My fairly new whirlpool gas dryer does not heat. I replaced the thermal fuse a month ago and the heating problem was resolved, now no heat again, thermal fuse was tested good. The igniter will turn...
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Jun 14, 2009 | Whirlpool Dryers
Whirlpool model GGQ8858EQ1 gas dryer starts, gets flame and begins heating. then after a short while flame shuts off and i hear a chattering noise somewhere near the bottom of dryer. It lasts for about...
The problem is your gas valve solenoids (coils). There are usually two of them mounted on the burner assembly. One is the MAIN coil, the other is the SECONDARY coil. It is recommended that you replace BOTH of them at the same time. Replacements can be purchased on line at appliancepartspros.com. Just type in the model number you provided and look under the "Burner Assembly" section for items 13 and 14. I hope this helps you.
May 05, 2009 | Whirlpool Dryers
Dryers Logo
307 people viewed this question
Top Dryers Experts
Marvin
Marvin
