Question about Toshiba Gigabeat MEGF40S MP3 Player
Won't respond to cradle/charge
Hello all, This week I noticed that when I try to connect my F40 to its cradle, the charge indicator does not come on, nor does it recognize a USB connection. If the Gigabeat is out of the cradle, it does recognize a USB connection, but the charge indicator still does not come on when I piug the adapter in directly to an outlet (NOT using the cradle), What is wrong and how can I fix this? I have only had this Gigabeat for about two months, bought it from Office Depot online. I tried shutting off the battery and restarting but that didn't work. Help?
SOURCE: Touchpad won't work on my Gigabeat F40
Mine did the same, touch pad became erratic then stopped working, I could still access everything when linked to a computer. Then all stopped, on power up I got a 00000010 or 0000020 error and nothing.
I popped the end caps off, removed the two small screws holding the back on and found the strap of wires connecting the hard drive was almost completely dissconnected. Pushed the connector back together , reassembled and now all working
Posted on May 10, 2008
SOURCE: Gigabeat Will Not Turn On - Battery Flashes Then Goes Dead
I called and they told me,i have the same problem, to just turn the battery switch ( bottom thing) off and charge it over night via wall outlet. hope it helps im trying it as i type so i wouldn't know...
Posted on May 19, 2008
SOURCE: gigabeat f40 system error 00000020
http://www.mygigabeat.com/forum/messages.cfm?threadid=BC5B8B48-3048-2906-EA65BE069DC676DE
Posted on Jun 13, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Driver files for Toshiba Gigabeat MES30VW
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 26, 2008
SOURCE: I've lost my cd.s for
do a search on pc and see if files are still there, if not download drivers from internet.
Posted on Feb 01, 2009
Mint Plus Turbo Charging Cradle won't function properly
Cradle and contacts are fine. Cradle circuit is nothing but a reed relay and few wires, relay closes on proximity to robot's body, therefore no voltage on contacts before robot is close to cradle.
There is a thermistor inside of battery, and mine was bad. I removed it and now I am charging the battery from my bench power supply at about 220 ma current, overnight, and it works. Probably the solution is to get a new replacement battery, but the one with the thermistor inside (OEM), easily recognized by the third wire, and all should be fine, assuming that nothing else is wrong with charging circuit or power adapter (12v/1A)
Hope this will give you some ideas of where to poke.
Once successful, please post your solution.
Jan 19, 2013 | Mint Plus Turbo Charging Cradle
Kenmore elite dryer. model 110.6708 or 09. check lint screen light is on. I have cleaned inlet/outlet/screen/front and back. unit will start but will not heat. if in the normal setting the f40 code wi
The F40 error code indicates a communication failure between the main machine control board and the motor control board for the blower motor on the dryer.
This can be caused by a loose wiring connection or a blown fuse.
Nov 22, 2012 | Dryers
Nuvi 760 will not accept charge from car charger. Does charge from USB. Car charger lights up indicating that 12V is OK. Fuse checks OK. When plugged into car Nuvi reports 'external source required for...
Your units powered cradle has probably died out, this is very common with the 7xx series, see if you have a friend or someone that has the 7xx cradle you could try. But it is a very common issue, if you do need a replacement one can be obtained from here http://www.gpscity.ca/garmin-nuvi-700-series-cradle-replacement.html
Hope this helps!
Mar 22, 2011 | Garmin Nuvi 770 Car GPS Receiver
My Harmony One remote will no longer charge. I took the battery out of it and place it in my Harmony 880 and placed it in it charging cradle. It started charging. I know it is not a battery issue. Yes...
This is a common problem for these remotes. Constant handling of the remote results in dirty charging contacts located on the bottom of the remote. Oils and acids from your fingers and hands also dirty the charging contacts. Also the contacts on the charging cradle can become dirty and have been known to not make solid contact. I would recommend cleaning BOTH the charging contacts AND the cradle contacts using a Q-tip and some good quality rubbing alcohol.Be careful to just wet the Q-tip and gently scrub the contacts only. Careful regular maintenance should help you resolve this problem. Also you could check the Logitech website for recommendations on how to clean their equipment.You can also try the rubber band trick!! Which is while placing the remote into the docking cradle, listen for a beep which indicates a solid connection. While still maintaining a solid grip on both charger and remote wrap a rubber band around both devices. This should ensure a good connection while the remote is charging! Good Luck!
Jan 04, 2011 | Logitech Harmony One Advanced Universal...
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Oregon Scientific Clock Radio Cordless Phone won't get dialtone
Did you try unplugging it the receiver, and plugging it back in?
If it's not too old, look at the manufacturer's website for warranty or support information
Here's a link to their contact us page: Oregon Scientific US Contact Us
Nov 16, 2017 | Oregon Scientific OS6976 Cordless Phone
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
It thinks its still plugged into the USB
Turn the battery button to the off position. It seems to work when I do it to mine. Good Luck.
Jan 09, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
My H5450 won't charge!
When you charge up your iPaq, do you use the cradle, or do you use the AC-adapter with the little iPaq power converter that came with the iPaq? Try both, and see if it charges up your pda. Try and borrow an iPaq car-charger and see if it charges up that way (the ones that do not need the iPaq power converter). If you are lucky enough to power up the iPaq even for 2 minutes, enable USB fast charging in the SETTING -> BATTERY. Your USB-data-cable or cradle will then be able to charge it up that way...
Sep 08, 2005 | HP iPAQ H5450 Pocket PC
Toshiba Gigabeat MEGF40S MP3 Player Logo
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Andrew Taylor
Andrew Taylor
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
