Question about Olympus EVOLT E-500 Digital Camera
Need help my focus on my camera is not focusing it has to be my lens because I have two lenses and the other lens works please help
  • 75 Answers
I'll bet that the problem lens is the 14-45 lens. I will also suggest that the lens received a knock or drop. This has caused the focus link to jump out of position. The repair is not difficult but you do need to be familiar with micro circuits. (There is a board to remove) I believe that Olympus may cover this if the lens is under a year old.
Posted on Apr 18, 2007
My pl1 camera has blurred pictures but when lens taken out, its ok.
Are you using an auto-focus m4/3 lens? I have about 20 lenses for this camera and only 1 of them is an auto-focus m4/3 lens. I have an adapter so I can use my 4/3 lenses on it in auto-focus mode along with other various mounts (including cctv) that do not support auto-focus. So if you are using a non-auto-focus lens, you will need to manually focus the pictures.
If you are certain it is an auto-focus lens, are you sure you have it set to auto-focus?
What settings do you have your camera set to (aperature mostly is what I'd like to know)? Try adjusting your aperature to be small (to increase your DOF).
Also what lens are you using and what is your focal distance? It could be your lens has a larger or shallower focal distance than what you are trying to achieve (like a macro lens doesn't work that great for landscape photography or a telephoto lens doesn't work great for macro photography).
Last thought: is your lens or sensor dirty? A dirty lens can cause focusing issues if it is REALLY dirty and a dirty sensor can too (sensor is a bigger pain to clean. I strongly recommend taking it to the pros as they scratch really easily). Dirty lenses can be cleaned with a blower and a lint free cloth and rubbing alcohol if those 2 things don't clear it out.
Mar 03, 2013 | Olympus E-pl1 Pen Digital Slr Camera w/ M....
This lens makes a whirring noise when attached to the camera body. It will not focus in either manual or automatic. The camera works well with the other lens.
Sounds like the focus mechanism is broken on that lens. There's a small screw on the back of it where it meets the camera body, the motor in the camera body turns that screw to autofocus. To me it sounds like the screw is turning, but the lens isn't focusing. You said it also doesn't focus in manual mode, so there is probably something inside the lens that needs repair or replacement. Your best option is to take it to a camera repair shop and ask them for an estimate, camera lenses are not the kind of thing you can take apart and fix on your own. Hope that helps.
May 03, 2011 | Nikon 35-70mm f/2.8D AF Zoom-Nikkor Lens
What is the lense for taking a profetional picture from crafts (indoor)
By "crafts", do you mean things like figurines or models?
Most any lens (other than fisheyes or super-wide-angle) will work so long as the object is within the lens' focusing range.
If you need to shoot up close, you will either need close-focus filters (basically screw-on magnifying lenses) or a lens with "macro" capability. Other lenses typically cannot focus on objects closer than about two feet to the camera.
It also helps to have decent lighting, which cannot be controlled with the camera alone.
Apr 12, 2011 | Nikon D40x Digital Camera
The lens keeps trying to focus it zooms in and
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Dec 02, 2009 | Nikon Cameras
Sigma 50-500mm auto focus problem
Hi is the manual focus working from inf to close focus and not stoping then it needs a new hsm motor
Jun 07, 2009 | Sigma APO 50-500mm F4-6.3 EX DG/HSM Lens
My camera lense will not focus automatically or manually.
There is no battery in the lens.  The lens receives power from the camera. Whether or not the lens is getting power, though, you should be able to focus manually.
When you say you can't focus manually, do you mean that you can't turn the focusing ring on the lens, or that when you turn the ring the image does not come into focus?
If you decide the lens needs to be repaired, I recommend sending it to Canon.  You can go to their website (canonusa.com if you're in the US), click on support, and follow the links.
Dec 20, 2008 | Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens
Sigma 28-300 3.5-6.3 won't focus
Did it ever work on this camera?
I have seen some Sigma lenses that are auto focus on canon film cameras but then when put on the digital they dont work right. If you have used it on this camera then make sure the lens is clean.sometimes dirt on the front wil make it try focusing on the dirt. Next try focusing in manual focus to make sure the focus is working. Then take the lens off and then put it back on and make sure it clicks into place.
Let me know if none of those things work. also make sure to try focus on something close and somthing far away.
let me know how it works,
Caleb
Jun 26, 2008 | Sigma 24-70mm F3.5-5.6 AF Zoom Lens
Lens
If this is a manual focus lens, you will need to do two things (and an optional third thing.)
1) On the side of the camera, you have to switch the focus mode switch from "AF" (Autofocus) to "MF" (Manual focus) . . . Yeah. I know, you probably already did that. <grin>
2) When you press Menu, go to the Custom Setting and change the Allow aperture setting to on, so that the Pentax K100D will then work with manual control of the aperture ring. You need to do this or the K100D will not work with manual exposure lenses (M lenses) or even autoexposure lenses (KA, KA2, FA, etc.) when you move the aperture ring from the "A" position to one of the manual aperture settings!
3) This is optional, but in the Custom Setting you can also turn on the Fl in manual focus mode, so that even though you don't have autofocus capability, you will get a beep indicator when you have successfully managed to manually focus your lens.
I have a few nice manual focus lenses that I have a lot of fun playing with on my K100D.
Take care & Happing Imaging!
Glen
Jun 09, 2008 | Pentax K100D Digital Camera
HELP Sigma 24-60MM wide Angle
The helicoid or the barrel thread in the lens may be jammed. The lens will have to be serviced. You should take it back for warranty service.
As for myself, I aways buy origional manufacture lenses and accessorites for my cameras.
Jerry G.
Jun 06, 2008 | Nikon D80 Digital Camera with 18-135mm...
Compatibility of vivitar lens with Minolta x370
Minolta X 370 is not an auto focus camera so provided you are willing to use the Vivitar lens in manual AND provided the lens has minolta mount , you will be able to use it.
Sep 04, 2007 | Cameras
Olympus EVOLT E-500 Digital Camera Logo
113 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
