Question about E-Machines eMachines Desktop PC
Emachines T1100 video card
I have a T1100 emachine and am triing to install a radeon ATI R7000 video card can some one tell me what I need to do after install computer will not boot up
    Sergeant:
  • 287 Answers
You need to install driver before putting the graphics card in
Posted on Dec 26, 2008
Trouble with install second video card HD 5450 to emachines t6532
Unclear of your statement. (More like run-on sentence)
Problem heading statement reads,
"trouble with install second video card HD5450 TO eMachines T6532"
Need clarification
The eMachines T6532 Desktop PC uses an MSI MS-7207 motherboard.
Also known as the MSI K8NGM2-L,
http://www.msi.com/product/mb/K8NGM2-FID--IL--L.html
(Click on photo for a better image)
Has one long white PCI Express x16 slot. (Expansion Slot)
Only uses one graphics card at a time, will Not use two.
[Graphics card / Video card. Same/same]
Therefore I surmise you are not referring to adding a Second graphics card, but are referring to;
A) This is the second time you have added a graphics card.
Or,
B) This is the second ATI Radeon HD5450 graphics card.
Had one before. Removed it, and are using a new one.
Or,
C) This is the second time you have added a graphics card.
It is not an ATI Radeon HD5450 like the old one is.
Know this;
1) You can ONLY use the OnBoard (Integrated) graphics,
OR the graphics card.
You CANNOT use both.
When using a graphics card the monitor is plugged into it.
You cannot plug into the onboard graphics of the motherboard, with it installed in the computer.
Said differently;
With the graphics card physically installed in the computer, you cannot just unplug the monitor from the graphics card; and plug it into the OnBoard graphics of the motherboard.
[Also; Computer on, you CANNOT unplug a monitor, and plug it back in.
This = NO ]
2) Driver: Small piece of software that allows the Operating System to communicate with a device.
The device is the graphics card.
The version of Windows operating system was not stated.
Did you install the software from the Installation Disk? (CD/DVD)
Has the drivers on it, and the user interface software.
User interface software for an ATI graphics card, is Catalyst Control Center.
(Just to note; I'm using a Powercolor Radeon HD5450 graphics card, right now.
I'm using dual monitors.
HP 2009M - 20 inch widescreen LCD monitor, and an RCA L26HD31 HDTV as the main monitor. (26 inch HDTV)
They work GREAT! ]
(It is an ATI Radeon HD5450 graphics card just like yours, IF yours has 1GB of graphics memory.
Doesn't matter what graphics card manufacturer, makes that HD5450, it is still an ATI (AMD) design.
Powercolor, VisionTek, Sapphire, Diamond Multimedia, Mickey Mouse, or Goofy. It is still an ATI graphics card )
The ATI Radeon HD5450 graphics card, has to have a MINIMUM power requirement of 350 Watts.
Does your power supply have 350 Watts or more?
If it is the original power supply, the answer is NO.
Back then power supply manufacturers were 'fudging' the true maximum rated wattage.
Why?
Sold more power supplies.
Power supply rated at 250 Watts?
Nope.
More like 60 to 70 percent of that.
Divide 250 by 10.
= 25.
Take that times 6. = 150 Watts (60 percent)
Times 7 = 175 Watts (70 percent)
Would like your opening statements clarified.
Post back in a Comment.
Regards,
joecoolvette
Mar 15, 2013 | E-Machines eMachines Desktop PC
Will an ati radeon 9250se graphic card be compatible in an emachine d2244 computer? there are two empty pci slots on the motherboard above the one that has the phone and modem conections. i have upgraded...
I am presuming you have XP on your computer.
According to ATI, this graphics board should work fine in a spare PCI slot.
Install in the top PCI slot as your CMOS detects top to bottom.
XP should detect the ATI board and will ask for drivers.
Install your CD drivers and or software as needed.
If you have VIsta or Windows 7, it does not appear ATI supports them for drivers.
Good Luck
http://support.amd.com/us/gpudownload/Pages/index.aspx
Aug 29, 2011 | ATI RADEON 9250SE, (128 MB) PCI Video Card
What type of video card do i buy for a emachines model T-6412
You can buy a video card named ATI Radeon Xpress 200 which is having up to 128MB DDR shared video memory. Its is a good video card for your system This card will be fixed into your PCI Express slot which is available for upgrade.
Thanks.
Have a great day.
Nov 20, 2010 | Computers & Internet
Frequency out of range
the monitors resolution range is only to 1280X740 or 780
and your video card may also need an upgrade.
The game may require a higher resolution that is not compatible with the the devices mentioned.
Jul 08, 2010 | E-Machines eMachines Monitor E15T4
EMachine Video Card upgrade
Ok so are you getting video from the card? Look in system information and see what graphics hardware the computers says is installed. Are you replacing a video card or did you add a card to the system? If you are adding a card make sure that you change the settings in the BIOS to boot first on AGP/PCI-E express slot. Make sure that fast write settings and bus speed settings are compatible with your card. For example if you purchased a 8X AGP card and your computer only does 4X the card may not work. Double check that you are trying to install the correct drivers for your card and operating system.
Sep 12, 2009 | E-Machines eMachines Desktop PC
Ok, i have two things to ask 1: Where is the video card on a emachines W3503? 2: Could a video card swap be done between a W3503 and a W3052? Thank you for viewing :)
1. The emachines W3503 has an integrated ATI Radeon™ X300 based graphics card. It has also a PCI Express (PCIe x16) slot available.
2. The emachines W3052 has a NVIDIA® GeForce®4™ MX graphics card. I'm not sure whether it is integrated or not, but I'm sure that if it is not, it will be an AGP graphics card. Since The emachines W3503 has a PCI Express (PCIe x16) slot available for installing a graphics card, the swapping of graphics cards between the 2 machines is not possible since they support different types of graphics cards.
Jul 11, 2009 | Computers & Internet
How do I upgrade memory on a t1100 emachine from 256mb
Your emachines eMachines T1100 only supports modules made with a specific type of chip. Should you find what seems to be the exact same memory elsewhere for a lower price, it is very possible that the cheaper memory will not work in your computer. From what I see you should use straight PC-133 Try a site like Kahlon.com-they make sure it works with your computer as would kingston or corsair...
Your maximum amount of ram is only 256mb total.
hope this helps...good luck- please leave a rating...thank you kindly
Apr 26, 2009 | E-Machines T1100 PC Desktop
Ati radeon 7500 pci won't work with vista
According to this site it looks like Vista doesn't have drivers. You possibly could try this XP drivers listed at this site. In order to try this I would suggest removing the failed driver from device manager and checking the box that ask if you want to remove the files.
NOTE: You will need to make sure that you are removing the correct card when you do this. If you remove the wrong driver it could disable your video output.
Hope this helps. Please remember to rate this information.
Thanks
Nov 15, 2008 | Computers & Internet
Yellow question on sm bus controller, pci device and video controller
For Emachines W3503, download the chipset drivers for ATI Radeon® Xpress 200 at http://e4allupgraders.info/dir1/motherboards/socket775/D101GGC_downloads.shtml which provides all drivers for this model of computer.
This resolves Sm Bus Controller driver problem.
Also a good tool can be driver detective for emachines http://www.drivershq.com/Drivers/eMachines/W-Series/W3503/22605/22758/37169/Drivers.aspx
If you are recieving "Error 22: A critical error has occurred while initializing DirectDraw." while trying to play Diablo 2, Warcraft III, or World of Warcraft, it is because direct draw has been disabled. I reenabled mine by installing the catalyst at http://ati.amd.com/support/driver.html for Windows XP Media Center Edition - Radeon - Radeon X300 Series.. Then use the Catalyst Control Center to renable DirectDraw.
Jul 29, 2008 | E-Machines W3503 PC Desktop
Resolution keeps resetting Emachine T5246 - Vista
You might try this:
- Open the Control panel
- Open Display
- Click on Settings
- Note which video controller or on-board graphics are installed (for example - 'ATI Radeon')
- Go to the manufacturer's website and download the latest drivers for Vista and the listed graphics controller.
These things are being updated often as new problems occur.
Jul 13, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
66 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
