Question about Hitachi 43FDX01B TV
Looking for schematic of Hitachi 43FDX01B TV- 18 pin transistor
I have a Hitachi 43FDX01B rear projection TV. it was in the middle of being repaired. no more repair guys. the tech removed two large (18 pin) transistors on a large heat sink. (large amplifiers?) i want to locate the parts and install them myself, but i don't have the parts and don't have a schematic.
how can i locate the parts?
their name/number?
any suggestions?
thanks,
Michael
  • michaelbp Dec 26, 2008
    Thank you so much for your response.that's the information i needed.
    but i just checked, model # on my TV is the 53 (with "A") not 43.
    Model # 53FDX01BA
    i just wanted to make sure-
    is it still the same component number?
    STK392-110
    thanks again,
    Michael
  • tararandy Mar 13, 2009
    I have the same convergance problem. Where are the IC's located? I know I can swap them out myself but need help locating them.
  • 4,234 Answers
The parts that are missing are likely to be the convergence ICs. These are STK392-110 and should be available online from any electonics parts supplier. Expect a cost of around $25 each.
Dan
Posted on Dec 26, 2008
I have a Hitachi 43fdx01b rear projection tv. it's picture looks like it is 3D.It was fine, happened all at once. wHAT IS IT ?
STK ICS replace both of them STK392-110 use 150s
Call Mats Elecronics for ICs 10.95 each
1-800-628-1118
Jan 22, 2010 | Hitachi FDX Series 43FDX10B 43" Rear...
I have Hitachi 43" hd rear projection tv - too much red
It's probably either a bad red CRT (the red projection tube) or a shorted (or open) driver transistor on the red CRT driver board. If it's the latter case (bad transistor), it can be fixed. If it's the picture tube, well, it's probably time to go shopping for a new TV.
Do you need more information? Do you want to fix it yourself? Do you have electronics knowledge and experience? If not, call a qualified electronic technician (TV repairman), and he can tell you if it's the picture tube or not.
IF (and only if) you are a competant electronic technician, CAREFULLY check and compare the voltage on the collector of the driver transistor on the 3 CRT boards. (The driver transistor is the large one, possibly connected to a heat sink.) The voltages shoud be somewhere around 140 to 160 volts. If the red one is significantly different from the green and blue ones, then it's probably the transistor. Unplug the set (and wait a bit), and check the transistor with a diode or transistor checker. If it checks bad, then you found a bad transistor. Go to NTE Electronic's website to find a replacement. If it checks OK, then you're probably looking at bad (shorted) red CRT.
Dec 12, 2009 | Hitachi 43FDX01B TV
I have a hitachi 43FDX10B ultrascand HD rear
well it seems to me that you need to call the manufacturer to see how to reset the pixels for that tv. it seems someone has taking a magnet or something like that to the tv screen
Nov 29, 2009 | Hitachi 43FDX01B TV
I have a Hitachi Ultra Scan HD TV model #43FDX01B - Green line
Hitachi Projection TV Repair Kit for one or more of the following symptoms
This might not be your model but you should contact them to see if the have the parts I know they list the manual
Feb 18, 2018 | Hitachi 43FDX01B TV
Hitachi rear projection TV clicks when you turn it on, no picture
No schematic, major short, usually the power supply or high voltage circuit, nothing you yourself can do. Pro repair about $450.00. If your in electronics replace the HV transistor first.. then??
Please rate
Apr 01, 2009 | Televison & Video
Picture has a blue shadow
Seems convergence out IC is fried in TV so it gives blue shadow.
Check out Convergence Out IC which you need to replace in TV, if you have enough experience of repair of big TV, necessary tools and know basic electronics.
Dec 18, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi 43FDX01B (convergence) problem
hi i have same prob iv bin told its a convergence chip an thay r £150 ! thay go bout evry 6 years an its comon .. any way there coming 2 fix mine 2day so ill let u know if it sorts it out my mail is mjoutlaw@hotmail.co.uk thanx
Jan 30, 2008 | Hitachi 51F500 51" Rear Projection...
Convergence IC's must be changed to start repair..original...
STK392-110 sub to Hitachi upgrade STK394-160E.....PART #
CZ 01341...you need two....
Next, take a critical look at the B+ feed resistors near the IC's..
check for over-heat / damage......usually 2.2 ohm 2 watt......
Let me know....................T.
Jan 03, 2008 | Hitachi 43FDX01B TV
Resistor ohm values??????
RK42 = 2.2 , RK46 = 1.5 , RK58 = 3.3 , RK52 = 1.8 , RK 50 = 2.2 , RK54 = 1.5
Aug 28, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 43FDX01B TV Logo
242 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
