Question about Motorola Talkabout T5700 AA (22 Channels) 2-Way Radio
Blank screen until I press menu
I turn on one of my T5700 radios and I get a blank screen. I have just put new batteries in it. The only way I can get something to show up on the screen is to press the menu button. I can't figure out what is wrong with the radio.
  • 127 Answers
I am sorry but i think it is time for a new one.
Posted on Jul 16, 2009
How do I get the FV300 to power up
Hold the power/menu button in a long press to turn the radio on/off. Once the radio is turned on, this same button acts as your menu button when pressed a short press.
You can find a copy of the user guide at shop.giantintl.com/Manuals.asp
Best regards.
Jun 14, 2013 | Motorola Talkabout FV300 Two Way Radio
Can't get FV300 to power up
You can find a copy of the user guide at: shop.giantintl.com/Manuals.asp
The power/menu button will turn the radio on/off by holding it in a long press. Once the radio is on this same button acts as a menu button when pressed a short press.
Best regards.
T5700 and T9500 con speak between them?
Directions for programming the T5700 can be found starting on page 18 here http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Directions for programming the T9500 can be found on page 1 under the heading MENU OPTIONS here http://www.giantintl.com/ContentManage/manuals/Moto/T9500%20FINAL%20-%20English%20only%20all%20rights%20reserved%20and%20call%20center%20email%2004-24-07.pdf
These two radios have many similar features, but some which differ. For best results leave all the special features such as Qt filter, call alert, and interference eliminator codes, turned off or set to zero until you get the radios to function in a basic mode on just the same channel as one another. Then once you've found what works, you can experiment adding special features, if desired.
Best regards.
Jun 18, 2012 | Motorola Talkabout T5700 (22 Channels)...
Radio cuts out (screen goes blank) when you press "talk" button
You are correct, the battery is bad. When batteries begin to fail, they may appear to hold a full charge, but when put under a load they fail to maintain the proper power to fully power the radio. Generally you will notice screens going blank, poor or no transmit, etc. Simple solution, replace the battery. New batteries are available for around $30 (US dollars).
Mar 17, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
Motorola Talkabout T5700 and Audiovox GMRS 1582CH don't talk
Most radios of this series would have Interference Eliminator Codes. The codes eliminate other incoming transmission not with the same code (number). There could be similar radios working on the same channel/frequency, but if they do not have the same code then neither one would hear each other. This does not make a channel "private", rather it limits what one can hear on that channel to another radio with an identical setting of the code. In some Motorola models, pressing the Menu button until the small numbers/code flashes would enable them to be changed. To change, press the + or - keys. Pressing the MON key or setting the code to Zero would enable the radio to receive and sound off all incoming signals with or without the code.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 15, 2008 | Radio Communications
Blank screen
This has happened to my radio several times after I've dropped it. This is how I fixed the problem:
1) Take the radio out of the cradle and let it play until the battery runs low and
the radio can no longer play.
2) Put the radio back into the cradle, plug in the power cord. When it comes on
the screen should no longer be blank.
Aug 25, 2008 | Samsung NeXus 25 MP3 Player
LCD display has gradually disappeared, now I have nothing. I have had this problem with other sangean products. Is there something that can be repaired? If so where can I send it for repair? Please...
This is a defect in the radio. Reportedly this issue was resolved in later vamps of production, but it still seemed to persist. We discontinued this model due to this exact reason. At this time there is no other solution and the factory can not tell us what the problem was and simply pointed to the LCD.
Feb 20, 2008 | Sangean PRD2 AM/FM/TV Radio
A blank screen
Try going to recovery mode by enabling the hold switch then press the record button then press the menu button until you see on the player screen welcom to recovery mode. Download the update from the sandisk site then install and run it on your computer. Then perform the update. Hope that helps.
Jun 14, 2007 | SanDisk Sansa e250 MP3 Player
Blank LCD on the camera
The camera turns on but the screen stays blank and I press any button and do not do anything no zoom no nothing and I press the menu button but neither nothing shows up just the blank screen
Jan 16, 2007 | HP Photosmart 620 Digital Camera
Motorola Talkabout T5700 AA (22 Channels) 2-Way Radio Logo
122 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
