Question about HP iPAQ H6300 Pocket PC
Unrecognized battery when input replacement battery i get a note "an unrecognized battery has been detected. this battery will be discharge and will not allow charging"
2 Suggested Answers
SOURCE:
  • 263 Answers
SOURCE: Hp h6325 not charging
Take it back to the shop where you boght it and ask for a replacement.
Posted on Aug 02, 2009
03800500-2F2F
2F2F Non-discharge detection error
As a result of nozzle checking made by the non-discharge detection unit:
All 640 nozzles in a nozzle train are non-discharging.
At least 50 nozzles have been found mismatched in a nozzle train of 640 nozzles since the last
session of detection.
ReferenceThe change (between non-discharging and discharging nozzle counts) noted since (a.louloudis1@gmail.com)for questions
Apr 23, 2014 | Canon imagePROGRAF iPF8000 Printer
Intermitent starting problems in my 2004 Jeep Grand Cherokee
Almost sounds like an injector heat-soak issue... However I'm wired on coffee and Monster at the moment. By not starting for a few days, do you try to start it several times in the interim, or do you just not touch it out of frustration for a few days? You should be able to check for heat-soak the next time it won't start after a drive by pouring a bottle of cool water over the injectors and down the fuel rail. Should cool off the injectors so they work properly again.
Have you checked to see if there are any codes coming from computer? With the key in the ignition, turn it from off to on three times (not all the way to start, ie crank the motor). So you go on-off-on-off-on-off then back to on and leave it there. The check engine light will flash a specific sequence. It may be handy to have a piece of paper in case there's multiple codes given. Basically what you do is count the flashes. They'll come in two-digit sequences, with the digits separated by a small pause. If there are multiple codes, they will be separated by a longer pause. So flash-flash-pause-flash-flash-flash paauuusssee flash-flash-flash-pause-flash-flash-flash would be a 23 and 33 respectively, if that makes sense.
This may help you with trouble-shooting, especially if the computer does give you some codes. Don't worry about Code 12 and Code 55, as 12 is battery/power disconnected within last 50 engine starts (or something like that), and 55 is end of message (ie, no more codes).
Edit**
Codes for your year are:
Code 88-Display used for start of test.
Code 11-Camshaft signal or Ignition signal-no reference signal detected during engine cranking.
Code 12-Memory to controller has been cleared within 50-l00 engine starts.
Code 13-MAP sensor pneumatic signal-no variation in MAP sensor signal is detected or no difference is recognized between the engine MAP reading and the stored barometric pressure reading..
Code 14-MAP voltage too high or too low.
Code 15-Vehicle speed sensor signal-no distance sensor signal detected during road load conditions.
Code 16-Knock sensor circuit-Open or short has been detected in the knock sensor circuit.
Code 16-Battery input sensor-battery voltage sensor input below 4 volts with engine running.
Code 17-Low engine temperature-engine coolant temperature remains below normal operating temperature during vehicle travel; possible thermostat problem.
Code 21-Oxygen sensor signal-neither rich or lean condition is detected from the oxygen sensor input.
Code 22-Coolant voltage low-coolant temperature sensor input below the minimum acceptable voltage/Coolant voltage high-coolant temperature sensor input above the maximum acceptable voltage.
Code 23-Air Charge or Throttle Body temperature voltage HIGH/LOW-charge air temperature sensor input is above or below the acceptable voltage limits.
Code 24-Throttle Position sensor voltage high or low.
Code 25-Automatic Idle Speed (AIS) motor driver circuit-short or open detected in 1 or more of the AIS control circuits.
Code 26-Injectors No. 1, 2, or 3 peak current not reached, high resistance in circuit.
Code 27 -Injector control circuit-bank output driver stage does not respond properly to the control signal.
Code 27-Injectors No. 1, 2, or 3 control circuit and peak current not reached.
Code 31-Purge solenoid circuit-open or short detected in the purge solenoid circuit.
Code 32-Exhaust Gas Recirculation (EGR) solenoid circuit-open or short detected in the EGR solenoid circuit/EGR system failure-required change in fuel/air ratio not detected during diagnostic test.
Code 33-Air conditioner clutch relay circuit-open or short detected in the air conditioner clutch relay circuit. If vehicle doesn't have air conditioning ignore this code.
Code 34-Speed control servo solenoids or MUX speed control circuit HIGH/LOW-open or short detected in the vacuum or vent solenoid circuits or speed control switch input above or below allowable voltage.
Code 35-Radiator fan control relay circuit-open or short detected in the radiator fan relay circuit.
Code 35-Idle switch shorted-switch input shorted to ground-some 1993 vehicles.
Code 37-Part Throttle Unlock (PTU) circuit for torque converter clutch-open or short detected in the torque converter part throttle unlock solenoid circuit.
Code 37-Baro Reed Solenoid-solenoid does not turn off when it should.
Code 37-Shift indicator circuit (manual transaxle).
Code 41-Charging system circuit-output driver stage for generator field does not respond properly to the voltage regulator control signal.
Code 42-Fuel pump or no Autoshut-down (ASD) relay voltage sense at controller.
Code 43-Ignition control circuit-peak primary circuit current not respond properly with maximum dwell time.
Code 43-Ignition coil #1, 2, or 3 primary circuits-peak primary was not achieved within the maximum allowable dwell time.
Code 44-Battery temperature voltage-problem exists in the PCM battery temperature circuit or there is an open or short in the engine coolant temperature circuit.
Code 44-Fused J2 circuit in not present in the logic board; used on the single engine module controller system.
Code 44-Overdrive solenoid circuit-open or short in overdrive solenoid circuit.
Code 46-Battery voltage too high-battery voltage sense input above target charging voltage during engine operation.
Code 47-Battery voltage too low-battery voltage sense input below target charging voltage.
Code 51-Air/fuel at limit-oxygen sensor signal input indicates LEAN air/fuel ratio condition during engine operation.
Code 52-Air/fuel at limit-oxygen sensor signal input indicates RICH air/fuel ratio condition during engine operation.
Code 53-Internal controller failure-internal engine controller fault condition detected during self test.
Code 54-Camshaft or (distributor sync.) reference circuit-No camshaft position sensor signal detected during engine rotation.
Code 55-End of message.
Code 61-Baro read solenoid-open or short detected in the baro read solenoid circuit.
Code 62-EMR mileage not stored-unsuccessful attempt to update EMR mileage in the controller EEPROM.
Code 63-EEPROM write denied-unsuccessful attempt to write to an EEPROM location by the controller.
Code 64-Flex fuel sensor- Flex fuel sensor signal out of range-(new in 1993)-CNG Temperature voltage out of range-CN gas pressure out of range.
Code 66-No CCD messages or no BODY CCD messages or no EATX CCD messages-messages from the CCD bus or the BODY CCD or the EATX CCD were not received by the PCM.
Code 76-Ballast bypass relay-open or short in fuel pump relay circuit.
Code 77-Speed control relay-an open or short has been detected in the speed control relay.
Code Error-Fault code error-Unrecognized fault ID received by DRBII.
Please let me know.
Apr 04, 2017 | 2004 Jeep Grand Cherokee
No battery detected
LOL, good ole Vista. I would never discharge my battery once I got it charged. I know the instructions say that, but I just never do it. Sounds like your battery is defective. Send it back.
Apr 08, 2012 | Computers & Internet
I have a Dell Vostro 1520. I bought a replacement battery in october 2010 and it stopped charging at all in June 2011. they tested it at the battery store and said it was irreparable. So i bought a new...
Lithium batteries mustn't be fully discharged or it can loss the possibility to recharge it: only every 2-3 months you have to dischage it until the pc shuts down and then recharge to preserve its capacity. Is normal that in the battery remain some volts but ther's no sufficent ampere to make works the pc, listen if someone has different ideas but I think you've to buy another one.
Jul 09, 2011 | Dell Inspiron 1545 Notebook
How do I charge the battery of my ACER note book PC? What is the correct manner to charge it? Should I always plug the Note Book PC into the main AC when I log on to the computer?
Yes you should when the battery is low.
You can check the amount of charge in your battery by -
Open Control Panel - Power Options - click on Power meter tab - un-tick Show power levels on each battery.
Apr 14, 2011 | Acer Aspire One PC Notebook
Is it possible to replace the HDMI input connector of my Samsung LNR408DX/XAA? What is the exact name or code/type etc for replacement of the HDMI female connector of my Samsung LNR408DX/XAA? I seem to...
Re soldering the sockets connections on the pcboard will normally fix this problem. It is unusual to require a socket but possible. Sockets are available through a good electronics outlet, depending on your country.
Dec 27, 2010 | Televison & Video
When try t charge my battery in my Vostro 1000, I get a message " The battery cannot be identified the system will not be able to cahrge the battery
Try this first:
Use up the battery until the the screen would black out. Afterwards, reboot the laptop ( without using the AC adaptor) and the system will warn you of low battery - to press F1. After pressing F1, plugged the AC adaptor back and try rebooting.
If the above does not work, there is a Bios update from Dell that suppose to fix this problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Oct 20, 2010 | Dell Vostro 1000 Notebook
Aug 02, 2009 | HP Computers & Internet
HP 6300 iPAQ - Crashes
yeah
your problem is backup battery
you need to change your backup battery
Sep 08, 2005 | HP iPAQ H6300 Pocket PC
Open Questions:
See all HP iPAQ H6300 Pocket PC Questions
HP iPAQ H6300 Pocket PC Logo
71 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
