Question about Acer 22" X223w LCD Monitor
Built own tower no signal on monitor screen
We have a nvdia 780i sli geforce graphics card and a acer 22 x223w monitor are they compatible? when i plug in my single link cable and the power, as the installation directs you to, and i turn on the monitor there is a message that appears NO SIGNAL. could you please inform what to do
    Sergeant:
  • 287 Answers
TRY NOT USING THE GRAPHICS CARD AND SEE IF IT WORKS THEN. IF SO I WOULD INSTALL THE DRIVERS AND THEN INSTALL THE GRAPHICS CARD.
Posted on Dec 26, 2008
Acer Z223w Display Problem
This is either your monitor or, more likely, your graphics card telling you it's going to fail soon.
Try another monitor, if that sorts it you're done. If not, it's the video source (graphics card).
Jan 18, 2013 | Acer 22" X223w LCD Monitor
I have an Acer Monitor X223w - is it capable of hooking up as a douple monitor to one computer?
Any monitor can be used as the second monitor for a computer. However, your computer's graphics card must have two outputs. Some simpler graphics cards, most on-board video chipsets and all laptops *do not have* two outputs. Please check the back of your computer for two VGA outputs, or one VGA and one DVI output (you can use it by connecting a DVI cable to your monitor, or by plugging in a DVI to VGA adapter).
If your graphics card does not have two outputs, or if your computer uses an on-board video chipset, you can buy another graphics card to replace the one you're using.
Mar 03, 2011 | Acer 22" X223w LCD Monitor
I have a Dell Dimension 2400 that I am running dual monitors on. I recently upgraded to Windows 7 professional from Windows XP and now I can't get both monitors to run at the same time. I have a Nvdia...
You should have 2 video ports on the 8400 GS card. One is the standard 15 pin VGA port and the other is the DVI port. You should be able to use these ports on the card to connect dual monitors. If you use the video port integrated on the motherboard you will bypass the 8400 GS card. Here's a link from Microsoft about running dual displays:
http://www.microsoft.com/athome/organization/twomonitors.aspx
The other issue is whether your monitors are DVI compatible.
Feb 10, 2011 | Dell Dimension 2400 PC Desktop
No signal pops up on the screen
make sure your cables are tight. make sure you have the correct input selected on your monitor. swap your monitor on the pc with one from a freind that works. this rules out your graphics card and the pc. if all of these are correct you probably have a bad video input on the monitor. you may need it repaired.
Dec 25, 2009 | Acer 22" X223w LCD Monitor
My new acer X223W monitor has power and display however it does not recognize the signal coming from the tower. I have tried starting them both at the same time as well as starting the monitor first. I'm...
Try plugging in the USB port as well.
Also, your monitor priority settings may need to be configured so that your CPU and GPU card know where to address their data to.
I presume you've installed the monitor's drivers if XP or earlier?
If 7 or later, your Win drivers and INF files should find a compatible driver in the built-in database library.
I don't have an Acer X223W, so my USB tip is based on my AOC wide-screen LCD, which without the USB is semi-intelligent.
I think VGA supplies the RGB video, while USB sets resolution, sync, etc, and digital addressing.
Nov 20, 2017 | Acer X223WBD Monitor
I HAVE THE SAME QUESTION REGARDING THE acER MONITOR I just bought Is x223W LCD Monitor compaatible with IBM towers. Acer Has one extra cord Andmy Ibm tower has no home for it Please respond
well that Would be a VGA Cord(BLUE COLOUR) which u have connected the other one with the white port will be DVI port.if u want better Display connect ur LCD with DVI port.u will usally find this port on a graphic card.
May 13, 2009 | Acer 22" X223w LCD Monitor
Acer x 223w monitor and what video card
I have not answered the question about this problem, however someone else told me that I would have to change my graphics card to take full advantage of the features of the X223W monitor. But they did not know what I had to change it to.
Jan 18, 2009 | Acer 22" X223w LCD Monitor
No sound driver on acer x223w how do i download
This is not a sound monitor, it does NOT have built in speakers. You need to have external speakers that plug into the audio jack in the back of your motherboard.
If this monitor did have sound, then you do NOT use an additional cable, you do not use DVI and HDMI at the same time.
HDMI is for graphics and sound, and you also need a graphics card that has a HDMI port to buy a monitor with sound, or you can't use it.
Monitors do not need drivers, most all OS, Windows have a monitor driver and there is no better monitor driver then the one in windows.
The drivers for sound come from the graphics card that has HDMI.
Dec 01, 2008 | Acer 22" X223w LCD Monitor
Text ghosting on Acer 22" widescreen monitor
Hi...there,
It's seems you need to reset your WB (white blance). Open your on screen display and look for WB settings... Good lucks!
Oct 05, 2008 | Acer Computers & Internet
Acer 22" X223w LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
