Cannot watch 2 pictures at the same time. All features of PIP seem to work except displaying different channels. The smaller PIP screen activates properly but I only get the main window that I am tuned to. When I attempt to change the main window or the PIP channel the screens become filled with snow. I am following the directions outlined to use PIP from the owners manual. I have cable and I set the toshiba remote to "cable" as indicated in the operating manual. All other features of the toshiba work properly and the cable channels work properly although the only way I can change channels is on the remote provided by the cable company and not the remote provided by toshiba in the "TV" setting on the remote. Perplexed. Thank you.
SOURCE: Toshibe 36AFX61 36" TV
I uncovered the problem. The "analog tuner" seems to have gone bad. The part is $25 -$36. The set can still be used however. I just removed the coaxial cable from ANT 1 in the back of the TV (this is what I believe has become defective)which was going to a VCR. I then just used composite cables(red,white,yellow)to bring the signal directly to the TV from the cable box, rather than the VCR. All works however, will replace the defective part.
SOURCE: how do you adjust the
convergence problem in your TV is caused by a faulty STK #### IC this IC is the one responsible for controlling the the color allignment(convergence)There are 2 big STK ic on your TV and they are mounted with heat sink .Replacing this IC requires a little know how on electronics.there is also some components to check (resistors)before replacing the IC I would suggest to ask the help of technical people to do the job but if you still want to do it your self let me know and I will give you step by step procedure...just post back!
