Question about Toshiba Gigabeat MEG-F10K MP3 Player
Can't transfer files to Gigabeat
I can't download any new songs to the MP3 player. I go into the gigabeat room, can syncronize the folder but it doesn't allow me to transfer the files to the gigabeat. What am I missing? I have refreshed the files, but still nothing... I'm sure its something I am doing wrong but don't know what.
  • embilly Apr 26, 2008
    my device doent come up on the ggabeat roo so i cant transfer music?
I actually had this problem before and all I did was re-install the gigabeat program in my computer and everything was fixed.
Posted on May 07, 2007
SOURCE:
Everytime when i switch on my gigabeat f20, it shows this error.NO SYSTEM FOUND ON HDD. i've tried formating but once this error appears, you can't do anything. Sometimes it shows SYSTEM ERROR.
Hi theofrimp109,
This error usually happens when the firmware has been corrupted or deleted. The easiest way to correct this is by updating the firmware. You may also try to restore the firmware data by following the steps below.
1. Connect the gigabeat to your computer using a USB cable.
2. Start Explorer on the PC.
3. Open the folder in which the gigabeat room is installed.
--> The folder in which the gigabeat room is installed can be opened by clicking [Start] [All Programs] [TOSHIBA gigabeat room 2.0] [gigabeat room 2.0
Program Folder]. Usually, the folder will be found in C:\Program Files\TOSHIBA\gigabeat room 2.0.
4. If you can't find the folder, please go inside the gigabeat then click on [tools], [folder option], go to [view tab] then select [show hidden files and folders].
5. Now, inside the gigabeat root, copy a folder named "GBSYSTEM" located in the folder that was opened in Step 3.
6. Use "Safely Remove Hardware" and disconnect the gigabeat.
Hope it helps.
Thank you for using FixYa.
Jun 28, 2011 | Toshiba Gigabeat MEG-F20S MP3 Player
Could I please have more instructions on how to restore firmware data as I am still getting same results. "NO SYSTEM FOUND ON HDD" 00200060
Just install your software that came with your Gigabeat. After installation please run the following program. Start/Programs/Toshiba Gigabeat Room/Formatting Utility for Gigabeat. This will place all the files back in the hard drive. Please do not format this unit from My computer to the drive letter. You end up deleting the system and boot files. if that does not help try this in your software you right click on your gigabeat room and open it up and find gbsytem folder drag and drop into your gigabeat on your my computer screen. and then check out.try it couple of times.many times this does work for first time directly. -------- you can also try contacting topshiba service center click the link directly http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp ---------- try downloading the firmware again and installing it in your device click this link directly for firmware http://www.megaupload.com/?d=MO4S7T6I ----- This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya.
Oct 22, 2009 | Toshiba Gigabeat MEG-F20K (20 GB) MP3...
Is transfer from Gigabeat to iPod possible?
There are programs like sound taxi that will do it easily but they do charge for them. If all of the files are on your computer just add them to iTunes and they'll all transfer to your ipod. If not just transfer them from your Gigabeat to your computers music file. Add the file to your iTunes and then sync your ipod to your computer and all of your songs will be on your ipod. Unfortunately without paying for a transfer program you will loose all of your playlists and organization files.
Jun 01, 2009 | Toshiba Gigabeat MEGF40S MP3 Player
Gigabeat room fails to recognize my Gigabeat
transfering is not a a problem its a player problem have  you ever format your mp3 player?
Dec 16, 2008 | Toshiba Gigabeat MEGF40S MP3 Player
It seems to be a permissions thing. When you launch Gigabeat Room, right click and choose "Run as Administrator". The Gigabeat button is then activated in the room interface.
Oct 30, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
File transfer Problem
Ok, I figured out a solution on my own.
Remarkably simple - all I did was reformat the player again and then reinstall windows media player.
Although in my travels I came across an article which may help users with a similar problem: http://support.microsoft.com/kb/911091/en-us#appliesto
Apr 20, 2008 | Toshiba gigabeat S MP3 Player
Toshiba Gigabeat
try using windows media player it does work if you go to the setting file on yor f20 and slect media player in the pc connections folder
Apr 20, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
Gigabeat Room
I've got the install CD that has gigabeat room 2.02 - US version. if someone wants it - email me the request and I'll email a zip of the whole CD. it's only 29 MB (kelly . piper . cherokee at gmail . com) remove spaces...
Feb 16, 2008 | Toshiba Gigabeat MEGF40S MP3 Player
Iva (toshiba gigabeat 10gb)
If you reformated the mp3 player's hard drive, the problem probably is that it can't find it's firmware which is supposed to be located on it's hard drive. To fix this, simply copy the GBSYSTEM folder located (usually) in C:\Program Files\TOSHIBA\gigabeat room 2.0.2 to your mp3 player's root.
May 26, 2006 | Toshiba Gigabeat MEG-F10K MP3 Player
Toshiba Gigabeat MEG-F10K MP3 Player Logo
293 people viewed this question
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Andrew Taylor
Andrew Taylor
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
