Question about Coleman Powermate Powermate 5000W Generator
Runs rough when choke pushed all the way to run position
The generator starts easy when in full choke. When the choke is pushed half way back, it runs well. However, when choke is pushed further towards run position, it begins to choke out. At first, it cut off, and now it runs rough in that position. Generator only has 2-3 hours of run time.
Also, I bought this generator from Home Depot--it had previously been returned and had no manual. Where could I get a manual for this Coleman Powermate 5500 which has a Yamaha MZ300 motor.
    New Friend:
Where can i obtain a manual for the 5500 gas generator
Posted on Jan 30, 2013
I have a coleman powermate 5500 with yamahe engine starts fine but has no power reset buttons did not pop and i replaced the brushes any help would greatly appreciated
Posted on Sep 11, 2011
Powermate generator 3250 runs for hours then chokes out runs rough
If it runs for hours under the same a mount of load then, chokes down, make sure fuel lines are fully clear, it may operate with a full tank of gas then when the weight of the fuel in the tank gets less has a problem. When it chokes out fill the gas back up and see if it works again. Also make sure the choke butterfly is not closing again whilst hot. I don't know how many hours are on it, but a decarb may be in order, especially if it runs for hours no issues
Oct 27, 2012 | Powermate Portable Generator: 3250-Watt...
How to start the generator
Hi Joe, I had asked for a little clarification and have not received any information. I will answer this question based on the generator is in good working order and it is a recoil start. Open the petcock, (this is the fuel valve) and give it about a minute to fill the fuel bowl on the carburetor. If your generator has an engine an on/off kill switch, set to on. If the generator has an auto idle switch set it to off. If the engine has a throttle lever located under the carburetor, push it all the way down (full throttle). Pull the choke knob out completely, there is a detent on the choke for half choke, pull it past this for full choke. pull the recoil starter rapidly. As soon as the engine starts running push the choke knob to half choke, this will allow the engine to run smooth while it's warming up. Depending on the climate that you are in, warm up time will vary. After a minute or two in cold climates start pushing the choke knob in, if it starts to run poorly pull it back out too the half position and let it warm up some more. When you can posh the choke in without the engine faltering it is ready to go. In warmer climates you might be able to start the engine without the choke or in the halfway position. Robin Subaru makes some of the finest small engines available. I would choose a Robin over a Honda every time. I hope this gets your generator going, and once again this is based on the generator being in good working order. Good luck, Michael Burke.
Dec 03, 2011 | Coleman Powermate Subaru 5000W Portable...
I have a brand new 3000i generator and it will start, then run for a few seconds and then cut out when I move the choke to run.
Two things, (assuming it is not a Kitchen Range, but a 3kW petrol driven alternator). Don't start it with the load connected. Let it run for a short while on choke; until it starts to run rough a bit, then put the choke to the run position.
Apr 01, 2011 | Kitchen Ranges
I have a coleman powermate premium plus 6250 generator,put in new plug ,new filter ,changed oil,cleaned the carb,put in new gas. runs ok at half choke but when go full choke it starts backfiring and runs...
if you are running the engine at full CHOKE, then it is flooding the engine, but if you meant off full choke, then the carb is still stopped up. Try soaking in carb cleaner overnight after removing jet & all rubber goods. HOPE THIS HELPS.
Dec 17, 2010 | Coleman Powermate Premium Plus 6250W...
Greetings... My son's crf150f was running rough yesterday [backfiring-wouldn't rev smoothly] with choke in normal "off" position. Setting choke to half choke middle position allowed much smoother...
sometimes they are stubborne,I use stranded electrical wire to send through jets,just make sure when blowing into an orfus that it comes out somewhere hope this helps
Jun 27, 2010 | 2005 Honda CRF 150 F
ONAN GENERATOR STARTS THEN ONLY RUNS WITH CHOKE ON
This sounds like a problem with fuel settings or dirt in the jet.
If you can find the carb adjustment screws, with it runing on full choke - screw it in fully untill it stalls, then back out to original position, then restart.
Take off choke and adjust setting untill it runs well when warm with choke fully out.
You can then try and make it run leaner without stalling.
Feb 07, 2010 | Watts Onan Portable Generator - 4000 ,...
How can you start a Ariens 824 snowblower
Ignition key on, throttle three quarters on, full choke, press primer 3 or 4 times, pull cord. Should cough, maybe start and run rough, then as it's chugging, turn choke to half, then quarter choke, let it warm up slightly, then choke off.
Dec 05, 2009 | Ariens Garden
Coleman 6250 generator runs rough
Fresh fuel? Does carburetor have adjustable jets? Turn the high speed jet (at bottom of float bowl) about 1/4 to1/2 CCW (looking at bottom of bowl). If no improvement, carburetor should be torn apart and cleaned. This also applies if there are no adjustable jets. Is there a fuel filter anywhere?
Jul 14, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate 5500 runs rough
vent in gas cap.
fuel filter.
dirt or gum in the carb.???
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
3,141 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
