Question about Lowrance LC X-15MT Sonar
Troubleshooting my Lowrance LC X - 15MT Unit
I can't display any Navonics maps on my unit. When I go into Map Data, the section under Navonics Maps says "none" even when I load both chips. I can't find a "Use Navonics Maps" box to be checked on my unit. I know the maps are there as the files are shown when I go into the "Browse MMIC" command. I also know the chips are good as I have loaded them into another unit. What's happening?? Thanks for your help!
Lowrance mark 5x will not come on
Posted on Aug 22, 2011
All of my lowrance products ar very particular to cards. Both my I-finder and my X-15MT would not read cards that other readers would read. I finally have three cards that work and guard them very carefully. PS. I found this via Lowrance troubleshooting and received great help from a tech there. You can check the cards before registering them by placing them in your unit and see if it shows the card present.
Posted on Jul 27, 2007
SOURCE:
I need a map chip & onwers manual for a Lowrance HDS 5 like insight. Serial no. 102574610. Where can I get them?
here is the manual
HDS-5, HDS-7, HDS-5m & HDS-7m - Lowrance
https://www.lowrance.com/.../Lowrance.../HDS-5-7-5M-7M_OM_EN_988-10041-00...Sonar references do not apply to the HDS-5m and HDS-7m GPS only units. Manual Conventions. When you are instructed to press a button in this manual, the ..
Software Upgrades here
Lowrance HDS 5 Software Google Search
and finally Mapping
mapping for Lowrance HDS 5 Google Search
and specifically, INSIGHT
Insight Genesis - Download free Lake, River and Coastal Maps
https://gofreemarine.com/insight-genesis/Make your own maps and download free maps from the community. Insight Genesis' cloud-based software does all the work, automatically processing ... with sonar signals from your existing Lowrance, Simrad or B&G transducer. ... The cloud automatically backs up all your data, protecting against lost or damaged SD cards.
Jun 26, 2017 | Lowrance Boating
How do I get my lake map chip to come on
With your card in your unit follow these steps it should accomplish letting you view your map data.
push MENU twice
Highlight CHART push ENTER
Highlight CHART DATA push ENTER
Highlight LOWRANCE push ENTER.
You will note there is an option for Lowrance and Navionics, if you select Navionics you will see a distinct difference in the way the base map displays on your unit.
Hope this helps.
Feb 11, 2015 | Lowrance HDS 5 Fishfinder GPS Chart...
Will the hds7 gen 2 read navionics lake map?
Yes, all Lowrance products will use and display Navionics map data.
Compatibility Guide America
Here is a link to the navionics compatability page so you can see which map cards will work in your unit.
Feb 03, 2015 | Lowrance HDS7 GEN2 Insight 83/200KHZ
Navionics card wont work
You most likely need to change the map data displayed.
The elite series won't change for you automatically. Lowrance Elite 7 HDI Hybrid Dual Imaging Fishfinder Chartplotter
here is a link to the elite 7 page where you can download a pdf owners manual.
go to the gps/map page on your unit. Find "chart data" on your menu.
select nation is as your chart data. Then you will be ableaving to see your map data.
Jul 30, 2014 | Lowrance Elite7m Chartplotter With Gold...
Gps will not start up
Hello :
I recommend you to reset your device to fix the problem .
Here is how to reset your GPS :
1. Turn unit OFF
2. Press and hold the PAGES key
3. Press and hold the PWR key
4. Release both buttons when the USA map appears
Here is how to hard reset your GPS . But be careful because Hard Reset (Deletes stored GPS Data such as Waypoints and trails)
1. Turn unit OFF
2. Press and hold the ZIN&ZOUT Keys at the same time
PLEASE DON'T FORGET TO RATE !
Apr 16, 2010 | Lowrance LCX-15MT GPS Receiver
I cannot bring up a marine chart showing depth and markers on my
Marine maps must be installed on SD cards. The base-map does not contain marine maps. Most on-line or brick-and-mortar hunting/fishing stores carry map cards for Lowrance units.
May 28, 2009 | Lowrance iFinder Expedition C Handheld GPS...
Global map 5200c loading problems- navionics platinum hot maps
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out and it works every time.
Mar 22, 2009 | Lowrance Globalmap 5200c Color...
Data card lost all it data
I don't know how it would have "lost" all it's data. More likely is all of it's data was "erased" or "deleted".
Take the card out and put it into your computer or someone else's Iway and see if the file folder is still on there. It probably is. You might just need to reset your Iway. You also might try downloading the newest software update (ver 1.3) from the Lowrance website. http://www.lowrance.com/en/Products/Automotive/iWAY-250C/Downloads/iWAY-250C-Software-Update/
This is not the maps, it's just the software for the unit itself.
If the map file actually isn't on the card anymore, then ask yourself:
Did you make a data card backup to your computer like the user manual suggests?
If yes, put the backup file onto a 2GB SD card and stick it back into your Iway.
If no, then you're out about $90 to buy a new set of maps. They come from Navtec, you can't buy them from Lowrance because Lowrance doesn't produce them.
Good luck
Dec 30, 2008 | Lowrance iWAY 250C GPS Receiver
How to Transfer Maps to GPSmap 60csx
Have you highlighted the section with the map select tool, then hit the Transfer to GPS button? If you do, what happens then? Does it freeze?
If you are able to send routes and waypoints to the unit, you should be able to send selected unlocked maps as well.
Dec 31, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Sonar Problem
Try a soft reset first, if that doesn't correct it try a hard reset. BE SURE and Save Data before th eHard Reset, it clears all waypoints and such.
Soft Reset Hard Reset
LCX 15mt Reset 1. Turn unit OFF 1. Turn unit OFF 2. Press and hold the PAGES key 2. Press and hold the ZIN&ZOUT Keys at the same time 3. Press and hold the PWR key 3. Press and hold the PWR key 4. Release both buttons when the USA map appears 4. Release both buttons when the USA map appears
Jun 26, 2007 | Lowrance LC X-15MT Sonar
Boating Logo
523 people viewed this question
Top Lowrance Boating Experts
Bob Peloquin
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
