Question about Sharp Mebius PC-PJ2-S3 Notebook
Hello i have this message alll the time:com surrogate stopped working how can i fix it?
  • 108 Answers
I guess this is a common issue and i found the answer that will give you step by step instructions on how to rectify this.
Happy Holidays
Posted on Dec 26, 2008
If I diable com surrogate will it harm my computer
Com surrogate is a service that allows switching on the com ports. Without it, communication to your devices will stop. If you're encountering this error there is a driver problem with your com port controller and you need to install the correct drivers.
Sep 01, 2014 | Microsoft Windows Vista Home Premium...
''COM surrogate has stopped working.................
Sir COM means "Component Object Model". These are basically DLL files which are used for system tasks and if they get corrupted then you get same problem. For solving this you need to repaid your windows using windows disk.
Jul 21, 2009 | HP Computers & Internet
Com surrogate has stopped working.
find the link for the software u need on this website
May 31, 2009 | HP Computers & Internet
Com surrogate
These should help:
Error message: "COM Surrogate has stopped working."
COM objects are often defined in Dynamic Link Libraries (DLL files). The Program file for COM Surrogate is actually dllhost.exe that can load a DLL and make its objects available to other programs.
The COM Surrogate error message is often related to codecs and other COM objects that aren't fully compatible with Vista. These are installed by other programs. The most common culprits are DivX and Nero. The first thing you should do is upgrade to the latest versions of these to see if that fixes the problem. Another possible fix is to disable thumbnail previews in Explorer. To do that:
In Windows Explorer, click Organize, then select Folder and Search Options
Click the View tab
Check the box that says "Always show icons, never thumbnails"
Click OK
To help troubleshoot which codec(s) might be causing the problem, you can use a free tool called InstalledCodec. You can use it to disable individual codecs one at a time.
You can download it at
Hope that helps
May 13, 2009 | Dell Inspiron 1521 Laptop
The desctop is locked
COM Surrogate errors The Component Object Model (COM) is a platform for developing software components developed by Microsoft and commonly used on operating systems such as Windows Vista, Windows XP or Windows 2003 Server. COM has been known under many names over the last few years including OLE, ActiveX, DCOM and COM+. Essentially it is designed to allow for easy re-use of software.
So what are these errors? COM Surrogate errors can occur when something wrong happens when software uses in-process components outside the main process either on the same machine or on a remote server. The default DLL surrogate (Dllhost.exe) can act as a host for in-process components. This is often used on Windows Vista, XP or Windows Server 2003.
According to Microsoft
"The file Dllhost.exe is an executable component that you can run remotely and instruct to load any in-process component, providing the component with a surrogate parent process and security context."
How to help fix this? Usually some software is out of date on your PC. You could try updating your software components. You might try updating software like Nero or DivX as this often happens with media software players for video files, music or MP3s. Other people have reported success by using QuickTime or Real as an alternative to using the software that caused the previous errors. Here is what you need!!! Click on the Above Link. Follow Each and Every Step!!!
Hope This Helps!!! Please Rate my Response!!! Thanks!!!
Mar 13, 2009 | Microsoft Windows XP Home Edition
Just download this small program and everything should be just fine . I was having the same problem , ive been told that its because of nero or divx codecs , didnt unistalled anything just installed this program and my problem was solve !
Nov 28, 2008 | HP Thin Client - AMD Geode NX 1GHz - 256MB...
Com surrogate and run ddl 32 problem
download codec pack and install it, ex - k-lite codec pack its free on net
Nov 11, 2008 | Microsoft Windows Vista Ultimate Edition
Software problem
Hey there
You get an error message that COM Surrogate has stopped working whenever you browse folders containing video or media files, This problem is caused because of codecs and other COM components installed by various softwares that aren't fully Vista-compatible, like some versions of DivX or Nero.
There are a number of possible solutions to this problem, and the right solution depends greatly on what software is actually causing the problem.
If you are using DivX, you should be upgraded to the very latest version (6.5+)
If you are using Nero, you can try upgrading to the latest version (
If you’ve upgraded Nero and Divx and still have the problem, you can try renaming the file C:\Program Files\Common Files\Ahead\DSFilter\ to You may also need to rename to NeVideoHD.bak
Essentially, turning off Data Execution Prevention on dllhost (the COM surrogate) can fix this problem . This solution is detailed below.
Right click on Computer, and choose Properties
Click on Advanced System Settings, and then under Advanced, click Settings
Select the "Data Execution Protection" tab, and then click “Turn on DEP for all programs and services except those I select”
Click on the Add button, and then browse to C:\Windows\System32\dllhost.exe as shown
Click Open, and then OK.
Here's what you should see…
Now you can browse video folders without problems!
Gimme your Acknowledge by rating me
Jul 31, 2008 | Microsoft Windows Vista Ultimate Edition
Sharp Mebius PC-PJ2-S3 Notebook Logo
136 people viewed this question
Top Sharp Computers & Internet Experts
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
