Question about Samsung PCL541R 54" Rear Projection Television
No picture, sound OK...setup menu shows up, able to get picture in PIP
Hello, the problem I am having with my TV is that there is no picture but there is sound. I am able to get a picture on my PIP (picture in picture), but none on the main. However, I can get the menu screen to work on the main. When I power on my TV, the red power light blinks and blinks, then finally turns off. When the TV was working properly, the red light would blink while it's warming up and would stay on when the picture is on the screen. I tried unplugging the TV for a while and when I plugged it in, it worked for a minute or so and blanked out again. I visually checked the fuse inside the TV and it looks fine. Please advise, thank you in advance!
  • 2 more comments
  • Anonymous Apr 28, 2008
    Tv has no picture. Sound works fine. Please advise on what might be the problem. Would it be the picture tube or another part?
  • Anonymous May 03, 2008
    Sound works fine. The picture on the main screen will not show at all. The channel indicator, however, does show when I change the channel. The problem began when the Television started flashing in and out of picture during use. It finally blanked out for good and has been this way for nearly a year now. It has been checked for brightness and unplugged, which many suggest should be done. Still no picture. Any suggestions?
  • Anonymous May 06, 2008
    i have the exact same problem as the original lister
  • Anonymous May 20, 2008
    I am having the same problem with my Samsung PCL542R. Exactly. PIP works fine while the main picture does not. Channel number information works and the menu works, but no TV picture. Sound works fine.
    Problem Solver:
  • 10 Answers
You will need to check the inputs on the television. You more than likely have a bad video in signal. This can be a bad cable or a loose connection either at the input of your television or at the output from your receiver, (cable or satellite). First, try wiggling the cable and then try replacing it. This should fix the problem. If not, your signal may be routed through a stereo or other switching device?
Posted on Oct 24, 2008
SOURCE:
How do I do picture in picture
How to turn on PIP in Samsung TV SAMSUNG STEP 1. OPENING MENU SETTINGS
Click here to know about PIP in Samsung TV.
a). Press MENU key ( 20130724181903971_281z433j.jpg ) from TV remote.
b). Select Picture option and press ENTER key ( 20130724182110969_vyofsac0.jpg ) from TV remote.
c). Select PIP option and press ENTER key ( 20130724182110969_vyofsac0.jpg) from TV remote control.
20130724182409386_3o5go25e.jpg STEP 2. TURNING ON PIP SETTINGS
d). PIP window will open on TV screen. Select PIP and press ENTER key ( 20130724182948520_6zvcucfc.jpg ) from TV remote control.
e). Select On option and press ENTER key ( 20130724183213111_ln8iy22v.jpg ) from TV remote control.
f). Enjoy watching PIP screen.
Oct 19, 2014 | Samsung New 55"" Class 54.6"" Diag. Led...
WS-65611 PIP worked until cable tech connected new Digital Box
do u want pip form the cable box itself or watch dvd on one side then tv on other
Jan 25, 2008 | Mitsubishi WS-65611 65" Rear Projection...
HI, MY TV PCL5415R, HAVE SOUND BUT NO PICTURES SHOW ONLY BIG BLACK SQUARE
Set would seem to be either in PIP (picture in picture multiple mode) or the black box might be the TEXT feature which is found in the closed caption menu.
Nov 04, 2012 | Samsung PCL5415R TV
Hey there just have simple question: Is it possible to lock setting for the different modes? I have found that a little brighter for movies and games works for me but I think that it keeps switching back...
Hello
Just enter to its picture and sound settings by menu option, and do the picture setting as you interested in.
1 Press MENU on the remote control.
2 Use Up, Down, Forward, Reverse buttons to select [ Setup] > [ Picture].
3 Use Up, Down, Forward, Reverse buttons to select one of the picture settings, and press OK
to enter the setting.
4 Adjust the picture quality.
The following picture settings can be confi gured. Depending on
the format of the picture source, some picture settings are not
available
You must set [Home] in [ Location] Otherwise, the settings you adjusted will not be memorized after you
turn off the unit.
You can set the location of your TV to [Home] or [Retail store].
Choosing [Home] gives you full fl exibility to change predefi ned settings for
picture and sound.
1 Press MENU on the remote control and then use Up, Down, Forward, Reverse buttons to
select [Setup] > [Installation] > [Preferences] > [Location].
2 Select [Home] and then press OK to confi rm your choice.
3 Press MENU to exit.
Mar 23, 2011 | Philips 55PFL7705D 55" LCD TV
How to setup pip
You should first enable the PIP option from the settings before you can use the PIP button on the remote. To do this press the "MENU" button on the remote, navigate to the "SETUP" option, Select the "PREFERENCES" option, select Picture/Sound preferences, select PIPFORMAT and turn it on. That should do the trick. Once enabled you can use the same menu to adjust the position of PIP etc.,
Should you have any further queries be sure to let me know.
Sai.
Dec 11, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Some channels have lost their sound. picture is ok, but no sound. this is rcab27tf680
Hello; I am John at J. D. Electronics, Poland Maine. This problem is very likely caused by SAP selected on your remote control. Make sure you have selected Stereo or Mono in the audio menu. You can find all of this in your owners manual ( which you can probably download if you don't have it). Good luck, John
Nov 22, 2010 | RCA B27TF680 27 in. TV/VCR/DVD Combo
How do I enable closed captioning on my Zenith PIP System 3? Thanks.
Hello
To enable close cationing on your TV follow this:-
[1] Press "Menu" button on the remote control to appear "Setup" menu on the screen.
[2] Use "Up and Down" arrows on the remote contol to select "Captions/Text" on your screen.
[3] Press "Right or Left " arrows to select any one of the following options. Caption-1, Caption-2, Caption-3, Caption-4 Text-1, Text-2, Text-3, Text-4.
[4] Press enter to return TV viewing.
To turn the caption feature to "On" or "Off'
[1] Press menu key on the remote control to display "Setup" menu.
[2] Using "UP/DOWN" buttons to select captions on your screen.
[3] Press "Right or Left" arrow to switch the captions feature 'ON" or "OFF" or "EZ Mute"
[4] Press enter to continue.
Ok.
Oct 22, 2010 | Zenith C27A24T 27" TV
Sony Trinitron XBR TV, picture-in-picture got
A solution I found for our KV-32XBR200 was to press Setup on top of the set, then select the "Demo" item with TV/Video. The text overlay apparently banished PIP. Verified this twice, as I'm at this page because our remote can only turn PIP on :-).
Dec 24, 2009 | Sony Televison & Video
Mitsubishi cs-26ex1
This sound like the standard Mitshubisi PIP board problem. There are two ways to adress this one is to repair the board, this involves replacing surface mounted capacitor and is about %80.00 sucsessful. The other is to simply bypass this board. this option is the way to go, it involves installing two capacitor on the main board and fixes the main pix but kills the Picture in Picture (PIP) I will send off both these repairs to your E-mail
Feb 13, 2008 | Proton MM2701VT 27" TV
No pic or sound
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Oct 22, 2007 | Philips Magnavox 42MF521D/37 Television
Samsung PCL541R 54" Rear Projection Television Logo
194 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
