Question about Panasonic NN-P295SF Microwave Oven
Panasonic nn-p295 blows buss fuse when turned on for cooking
Over the range microwave oven, all of a sudden blows 250v 18amp bussfuse when trying to cook. replace fuse, display panel lights up, lights and blower fan work, but when try to cook, blows fuse again. No visible signs of damage to control panel or board. Unsure of next move, could safety switch be possible cause of problem? Any help would be appreciated. Cannot find anything on line to help me with this problem.
  • Panasonic Master
  • 9,149 Answers
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer. But this is likely an inverter model, so it wouldn't have one and would be some other component in the inverter I'd say.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/mag_test.html
The best place to order Sharp parts is Tritronics. Or you can call them toll-free at 866-779-5835.
Posted on Dec 26, 2008
The Mocrowave Panasonic NN P295 stopped working. Not a single light is on. I checked the power at the receptacle - is OK. May be the fuse inside the microwave was blown. How can I replace the fuse. Where...
Did you recently have trouble with the cooktop lights?
Sometimes when the cooktop lights blow or are inserted or removed while the oven is still plugged in, the filaments can short, causing a surge that damages the controller.
They can be repaired. More details here.
Nov 05, 2011 | Panasonic NN-P295SF Microwave Oven
Where is the thermal switch located
If your model is NN-P295, then the service manual is here.
You can order Panasonic parts from
Encompass here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Most microwaves have a thermal cutout or thermostat on the magnetron, on the top of the cooking cavity, and often on the floor of the oven or above the bottom cover.
Jul 13, 2011 | Panasonic NN-P295SF Microwave Oven
Discussion on the appearance, aesthetics, form and colur
Hello dutch.
This is an excellent microwave, over the range, white only. Here is a link to all of the features, and even the owner manual http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Over-the-Range-Microwaves/Technical-Specification/model.NN-S254WF.T#ts
Microwave Type: Over-the-Range Cooking Power: 1200 Watts Capacity: 2 cu. ft. Convection Cook: Without Convection Cook Dimensions Exterior Depth: 15 in. Exterior Height: 9.5 in. Exterior Width: 23.25 in. Miscellaneous Product ID: 22541798 More Information Details: Over the Range Microwave with Panasonic Inverter Technology provides true multiple power levels. When the user asks for 60% power, the oven delivers a true 60% power, not a pulsed delivery of 100% power 60% of the time. This method is called linear power delivery
Dec 08, 2010 | Panasonic NN-S254WF Microwave Oven
Fuse keeps blowing Found out we shouldn't have it
A 20 will work but I would change it to the correct on as soon as possible...
heatman101
Sep 07, 2010 | Panasonic NN-S953 Microwave Oven
Terminal connector to the door switch overheated & fuse blown
Just cleaning is not enought.The terminal is loose and that isusually the problem most of the time.Replace them with new ones and I think you be happy.
Mar 12, 2009 | Panasonic NN-P794SF Microwave Oven
Panasonic NN-P295 Cooktop Light not working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Jan 23, 2009 | Panasonic NN-P295SF Microwave Oven
Pansonic model nn-p295 over the range microwave oven
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
We're happy to help and we appreciate your thoughtful rating of our answer.
Nov 28, 2007 | Panasonic NN-P294SF Microwave Oven
Panasonic NN-2501 Microwave Oven range hood
It is possible that the magnatron is bad but hard to say on a no heat problem without checking all components. A lot of model give 5-7 yr warranty on that part.
Oct 05, 2007 | Panasonic NN-S251 Microwave Oven
Fuse
Agrivated, looks like the fuse 18amp is in the back on top. You will have to remove the shell off the microwave to get at it. This one operates with a inverter..you have some high voltage there. Make sure it's unplugged. While you have it apart, check the primary switch, top one on door latch. If the monitor switch finds this closed when the door is opened it will blow that fuse. You also have a cavity thermal cut out that will shut the oven down. Catriver...post back.
Aug 28, 2006 | Panasonic NN-T993SF Microwave Oven
Panasonic NN-P295SF Microwave Oven Logo
1,245 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
