Question about HP Compaq ProLiant ML530 Server
Problem with scsi driver proliant ml 370 for NT4
When i boot server for reformat partition C:\ server can't detect hardisk...
  • Anonymous Mar 18, 2014
    i can't find multimedia audio controller drivers for HP proliant ML 115
    Problem Solver:
  • 6 Answers
Are you attempting to boot from the Windows CD?
If you are booting the server from a Windows installation disk and it is unable to detect the hard drive, this typically means the following things.
You need to provide the driver for the RAID controller of the server (this can vary, depending on the version of the ML370 e.g. G4/G5)
If it still cannot detect the hard drive after providing the driver for the RAID controller or if there is not a driver available for NT4, it may not support the controller.
In this case you can remove the RAID set by entering the RAID setup (could be LSI or adaptec). NOTE THIS WILL DESTROY ALL DATA ON THE DISKS THAT ARE A PART OF THIS RAID SET.
Posted on Dec 28, 2008
How to installed xp2 in server hp proliant ml 350 my hard drive ok
You may need raid controller driver for HP proliant ml 350. Copy raid controller driver in flopy disc, insert it in flopy drive, insert cd in cd driver, boot server from cd and start installation process, as soon as you see Press F6 if you need to install third party scsi drivers or raid controller, press F6 and follow the instruction. It will then ask you to select RAID driver file and then will continue to windows xp installation.
Regards,
Kaushik Patel
Aug 24, 2013 | Computers & Internet
Proliant does not boot from raid controller if external SCSI drive is powered on.
Try to disable boot to other device on your bios setting.
Make sure that your Smart Raid is set on the first boot device.
Nov 01, 2011 | HP Compaq ProLiant ML350 G3 Server
How to install scsi driver for hp prolaint ml 350 server and then install server 2003,because my os 2003 is currpted.
windows server 2003 enterprise edition with SP1 or SP2 , can detect
SCSI driver automatically.
Apr 22, 2011 | HP Compaq ProLiant ML350 G3 Server
Hi: i have hp server ML 370 with array smart 642 controller and i replace hard drives to clean and check but when turn on the server get me many messages no scsi boot device found and next line scsi bios...
when did this beast last work.
see the manual yet>
there are many 370s ,which one, the full service tag answers that.
G , 2, on up. 9????????????
Proliant servers.
use google to find old manuals.
here is g2
https://www.manualshelf.com/manual/hp/hp-proliant-ml370-g2-server/compaq-proliant-ml370-g2-service-update.html
here is HP site covering retired products, I suspect your is..
https://www.hpe.com/h20195/v2/Library.aspx?doccompany=HPE&cc=us&lc=en&filter_status=rw#&doccompany-hpe&sortorder-csdisplayorder&teasers-off&searchword-Compaq%20ProLiant%20ML370&isRetired-false&isRHParentNode-false&titleCheck-true
HPE has the , 642 book here. (just a spec)
https://www.hpe.com/h20195/v2/GetDocument.aspx?docname=c04284123
if read that page it tells you the controller is only works with
SCSI
Compatibility with all Ultra320, Ultra3 and Ultra2 LVD family products.
it also tells you , it needs the HP utility tools to set it up properly
why would your clean disks boot? why say that?
what does this mean?
"and i replace hard drives to clean and check" surely you can elaborate the full story,
last run when?> what G number is it.
what drives , make and model. installed.
do you have the software setup seen on page 5 link just above.
quote
All Smart Array products share a common set of configuration, management and diagnostic tools,
including Array Configuration Utility, Array Diagnostic Utility (ADU), and Insight Manager.
this product is offically retired, by hp and only few books there.
but google finds many books, 15 years old now. (as old as...)
http://kmcs-service.austin.hp.com/km-ext/kmcsdirect/emr_na-c01127202-1.pdf
see this, it tells you what to do in 77 pages.
my guess is you get lost at Set the boot controller
(Chapter 4).
my guess, is that you have no HP sofware support kits.
just hardware there.... right?
next time tell the helper, full spec on 370 Gn G numer.
and full spec , on 642, version. and that you dont have the HP software kit to support this machine, it's no simple desktop, no at all.
at the least you get stuck here,
Create at least one logical drive, as described in Chapter 5.
Sep 25, 2017 | HP Compaq ProLiant ML530 Server
How to enter in bios to boot change sequence in ProLiant ML 530
Press F10 during post boot if you have smartstart installed in the partition. If not, you need to boot from SmartStart CD.
May 08, 2010 | HP Compaq ProLiant ML530 Server
Configure & install two scsi disks scsi disks in ML 150 G2
The SCSI driver is required to installed during the initial boot up for installation when additional drivers are asked .the new models dont come with a Floppy drive so an external floppy drive can be used .The detection of HDD s must be at the startup by the Bios os SCSI card.
Feb 24, 2010 | HP ProLiant ML150 G2 Server
SCSI Devices not detected when posting ML530 Server.....
To get to the BIOS for your server, press F10 at start-up. This should get you there to verify if settings are detecting SCSI devices. If they are there, you may have to reinstall the SCSI controller drivers. Good Luck.
Jan 30, 2009 | HP Compaq ProLiant ML530 Server
HP Proliant ML370 Server: Very Urgent Please
Open the system cover and check whether any LEDs showing amber or Red colour
Oct 29, 2008 | HP Compaq ProLiant ML530 Server
Hardisk have difrent amount
Because Compaq has a hidden partition on you're C:\
Stored in that hidden partition is Compaq's restore drivers & software. If & when you need to run the restore CD on the Compaq, the restore CD enter's that partition & uses the software to help in the process of restoring the C:\ drive to factory settings. (This is normal for most Compaqs).
Mike
May 07, 2008 | Compaq ProLiant ML370 G3 (340262-001)
I have server model compaq proliant ml 370
hdd controler dead or disabled fom bios in the luky case
Nov 11, 2007 | Compaq Refurbished PRLNT ML370 G2 POWER...
HP Compaq ProLiant ML530 Server Logo
890 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
