Question about Vacuums
Can't find a replacement tank for Maytag legacy F7223900
My tank is cracked on my Maytag legacy F7223900 and I would like to purchase a new tank but cannot seem to find a place online that sells the model that I need.
2 Suggested Answers
SOURCE: Hi, I can't get the
How do I empty my Maytag Legacy vacuum cleaner. It came without instructions.
Posted on Aug 14, 2010
I don't know how to change the bag for the machine, bag # SR 401010. Vaccum is Maytag Legacy series. Is there a diagram or picture to show how to replace the bag. Thanks
http://www.hoover.com/CustomerService/Manuals/Default.aspx Enter your model number on Hoover's website to view or print a manual. I suspect that you may have accidentally discarded the bag frame ( part # 93001544 ), which holds the bag in position.
May 21, 2011 | Maytag Hoover Duros S3590 Vacuum...
Water leaks out of the clean water tank valve
This was a very common problem with the earlier tanks on this model. The newer tanks can be identified as a single clear plastic molding, and the older, defective tanks had a separate soap container glued to them, usually blue or green in color. If you look carefully, I think you will find the leak is due to cracks in the plastic beneath the valve. Purchasing a new tank should solve the problem. ( Part # 42272104 ). It is probably worth a call to Hoover, to try to get a new tank at no charge.
Apr 19, 2011 | Hoover F7431-900 SteamVac Vacuum
Iput the tank back on and it cracked
You can purchase a new tank if needed. No known way of fixing the cracked plastic.
http://www.usavacuum.com/category-s/343.htm
Feb 22, 2010 | Bissell 1425 Little Green ProHeat Handheld...
Hoover Steam Vac V2 Leaks from Bottom
That is not the solution. I have purchased several tanks and the issue is not the tank it is leaking from the bottom of the unit. can you please let me know if you found a real fix? thx for your time
Jul 20, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
My shampooer leaks
you need a new tank old tanks cracked at the seal hoover came out wih a replacenent tank old tank will have a crack in it by the seal
Nov 09, 2008 | Hoover F7431-900 SteamVac Vacuum
Leaking problem
I had the same problem and it was a crack in the plastic near the small rubber valves that let the water out. After having two tanks crack like this I complained to Hoover about the poor design and they sent me a new tank with a new design fee of charge. Obviously they were aware of the problem.
Aug 20, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Hi, I can't get the bag back onto my Maytag Legacy vacuum, model number s3591 any help? I can't find the manual, and no manual online
hello, my wand gets very warm and then the nozzle-where the brush is) does not rotate. i took out that wand that got a little warm and the vacuum works fine. i cannot find a on line place to locate another wand or fix this one. any suggestions?
Jul 19, 2008 | Vacuums
Tank for Hoover SteamVac continuously cracking
I use shoe goo or similar product to glue the cracks together. I have fixed large holes this way and it works fine. It is best done when cracks first appear. If cracks are minor then super glue might also work but if it is major or there are holes then shoo goo does the trick and it is a permanent fix.
May 30, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
