Question about JVC AV-65WP74 Rear Projection Television
Looks 3d i have a 65 inch jvc projection tv and it looks like everything is 3d!
  • Anonymous Dec 27, 2008
    Can you tell me what stk's stand for. And maybe how hard and expensive this will be. Thanks Same Problem,3D picture
  • guest0001 Apr 05, 2009
    I have the same problem, the top left corner of my screen looks 3D what does skt stand for?
    Problem Solver:
  • 3 Answers
Do not open anything until you. Go to menu on your remote find convergence and press the volume button to the right go to manual and press right again. you should see a bunch of rectangles, now you should also see a set of red cross heirs press the #2 to move cross heirs up and eight to move down numbers 4 and 6 will move left and right and 5 will place the cross heirs back to the center once you have chosen the selected section to adjust line up the magenta with the other colors using the channel and volume buttons these move the lines up down left to right adjust all lines until they are white. i do not know how to switch from magenta to green or blue but this should get you started on the right track with out having to replace anything. good luck! if you figure out how to switch from maqgent to green or blue please post it so that I may adjust mine as well tahnks
Posted on Apr 17, 2009
  • JVC Master
  • 3,459 Answers
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on May 22, 2009
  • 185 Answers
Your convergence is not working, if i'm right the colors don't line up? especially in the corners.
you would need to replace the stk's
Posted on Dec 26, 2008
JVC Modle HD-61FN97 2006 65 inch tv light went out replaced it now can not adj brightness
Aside from the customer controls you might be able to turn the screen controls up a bit to get more brightness, they are on a black block inside the set.
Nov 29, 2012 | JVC AV-65WP55 65" Rear Projection...
Convergence issue. lost about an inch on right side of screen model 65SWX20B after i manually adjusted convergence grid.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 16, 2011 | Hitachi 65SWX20B 65" Rear Projection...
Hooked up PS3 to system and when watching DVD's the right side of the picture is blurry and appears doubled, like an old 3D movie without the red and blue glasses. When watching TV everything looks fine.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Jan 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
My Samsung HCN653W 65-Inch Widescreen Projection HD-Ready TV has a 3d like picture when it has been on a hour it goes back to normal
  • Screen looks 3D, wavy, or has a shadow or shadows
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 05, 2011 | Samsung HCN653W 65" Rear Projection...
The color is distorted and the images on the screen is double.
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | JVC AV-65WP55 65" Rear Projection...
I have a JVC rear projection TV. from the frot it looks like the green color is sagging. we took off the back panel & the green lens... it looks like there is liquid under the lens & that it is...
The tv pictures cloudy or hallow?Yes,than the R,G,B CRTS Tubes guns require changing it coolant liquid.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a coolant kit to used.But just R,B,G colors lines mis alignment,colors shadows or 3D pictures,this problems is a convergence problems,it dead.The tv convergence board require changing the 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 11, 2010 | JVC AV-65WP84 65" Rear Projection...
The tv looks like it is in 3d. when i try to adjust the convergiance the plus signs on the left are bent
do not play with this tv replace the stk ic chips and the resistors around the stk chips ,cant miss em about 2 inches big with heat sinks on them.
Sep 11, 2010 | JVC AV-48WP30 48" Rear Projection...
Green and blue shadows on the screen
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Jul 30, 2010 | Mitsubishi WS-65809 65" Rear Projection...
JVC 65 inch AV-65WP55 tv, the color red is failing
The tube is old. You need to contact a service center. He may try to boost it from inside. If it doesn't work, then need a new tube.
Jan 09, 2010 | JVC AV-65WP55 65" Rear Projection...
Jvc 48 inch tv and the picture looks 3d
Convergence ICs have failed. You can get the convergence repair kit for your model JVC at www.tvrepairworld.com the kit contains both ICs the associated resistors and the CD with detailed instructions.
Jan 03, 2010 | JVC AV-48WP74 48" Rear Projection...
JVC AV-65WP74 Rear Projection Television Logo
222 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
