Question about Insignia IS-LCDTV32 32 in. Television
I have the following tv, Insignia 32" Flat-Panel LCD HDTV** (NS-LCD32-09CA) I get audio sound but no video output
  • justin060 Jan 13, 2009
    i have the ns-lcd 15, and whnen i turn the tv on the picture somtime flashes and then goes dark, and sometimes does not. However i still get sound as if nothing is wrong. I took the tv apart because i found that if i shook it or held it in a certain position it would start to work again, but then soon go back to a black screen. i figure since it does work somtimes it is a loos connction but no luck so far
  • 405 Answers
Power supply board most likely, I have one just like it with the same problem in my shop right now.
Posted on Dec 26, 2008
HOW OLD IS MY INSIGNIA TV
correction your model must be : NS-32L430A11
its from 2007 or 2008
here full specs for your set
http://www.insigniaproducts.com/products/televisions/NS-32L430A11.html
thnaks
http://www.bostonrecycling.net/
Oct 08, 2014 | Insignia 32" 720p Flat-Panel LCD HDTV
Setup insignia NS-LCD19. I get a "signal not
Your computer video output resolution is not compatible with the TV. Try adjusting your video card output settings to 800x600 at 60 hz to begin. Once the desktop displays on your TV, you may continue to adjust the settings to meet your needs.
Oct 12, 2011 | Insignia NS-LCD19 19 in. LCD TV
Im trying to connect my sega dreamcast which has red white an yellow av cable only, however my insignia NS-32E570A11 led tv only has for component connection with the blue green n red, when i hooked it up,...
Sorry, this will not be easy....
You need to locate a composite to RGB converter box.
Your Sega outputs a composite signal - Video (yellow) and audio left/right (white/red).
The TV needs RGB (red/green/blue) inputs on the component connection...your composite signal divided by three. There are converter boxes out there for around 70 bucks or so.
Are you certain you do not have a yellow VIDEO IN jack on your set? Every LCD and LED TV I have experience with has at least one.
Feb 18, 2011 | Insignia 42" LCD Flat-Panel HDTV
Insignia 32" NS 32 q09
Since you don't mention how you're receiving the signal, I'm assuming you use a cable box or computer. Adjust the output settings (e.g. 720p, 1080p) on the box and then adjust your TV settings. If it's a computer, you'll need to adjust the video card settings to a compatible aspect ratio (e.g. 1366x768) for the desktop to display properly on the TV. Details can be found in the owner's manual.
Jan 04, 2010 | Insignia 37" LCD Flat-Panel HDTV
Red tint on my TV, instead of all colors? Reset doesnt work?
Sounds like the component cables are misplaced. Check that, and report back.
Dec 30, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
414 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
