Question about MSI NX7300LE-TD256EH GeForce 7300 LE, (256 MB) PCI Express Graphic Card
Problems w/ laptop
When i turn my laptop on there are 9 displays... like picture ONE screen... divided into 9 boxes... all having tha same display.. dont think its a virus because after like 10 minutes it work fine but after restarting its back... btw i recently had to replace my laptop screen... and i did do it myself... so im guessing tha problem originated from there... anybody have any ideas
4 Suggested Answers
  • 84 Answers
SOURCE: No display on LCD
hi toffie!
you probably have it connected it to your onboard vga, please have it check at the back if you have a video card connected separately, and if you have it means that you need to disconnect it on the onboard and connect it to your video card.
have it check and let me know.
allen
Posted on Jun 13, 2008
  • 5 Answers
SOURCE: MSI G31TMP21 Motherboard: VGA has
Start windows 7 in safe mode and reinstall the drivers for your graphics card.
Posted on Mar 05, 2011
Zebronic
  • 10 Answers
SOURCE: K9N6PGM2-V MSI Mobo no display
Your VGA device of motherboard might have problem. and it also can be caused due to some IC failure... you will have to repair your Motherboard as soon as possible. if it dosen't worrks consider replacing your Motherboard.
Posted on Sep 01, 2011
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
My asus laptop screen is divided into diffrent desktop
Right click on the main screen, go to properties, go to display options, change the display settings so number 1 box is bigger and to the left of number 2 box, all other settings should be set to default.
Jun 09, 2012 | ASUS Computers & Internet
Sony bravia picture to large for screen
Sir press the screen mode button in your remote below input select button, press the screen mode button repeatedly to select smart, 4:3, wide, zoom, or 14:9.
  • Smart- Display conventional 4:3 broadcast with an imitation wide screen effect. The 4:3 picture is stretched to fill the screen.
  • 4:3- Display conventional 4:3 broadcast non-wide screen TV in the correct proportions.
  • Wide- Display wide screen 16:9 broadcast in the correct proportions.
  • Zoom- Display cinemascopic letter box format broadcasts in the correct proportions.
  • 14:9- Display 14:9 broadcasts in the correct proportions. As a result, black border areas are visible on the screen.
Sep 27, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have a Compaq Presario 700 series. About a month ago the LCD went crazy for no apparent reason and I took it in for service. They told me the LCD was bad and had to be replaced. They said it would cost...
  1. First, since this LCD your using is a TV ready you need to check if it's in the PIP mode (picture in picture). Because if its in this mode the TV screen will be divided into parts.
  2. Secondly, checked the remote then try to press the PIP mode so that your screen will back to a normal mode.
  3. If pressing the PIP button will not bring it m\back to a normal mode try to remove the connection of the TV to your LCD TV and then make sure that the LCD and the laptop is off then try to connect it again then power on both LCD tv and the laptop.
If you have further questions fell free to reply to this solution. Cheers!
Feb 10, 2011 | HP Compaq Presario C769US Notebook
LCD displays 4 white lines and has double vision
I saw your tv pictures at above mentioned website link.
It is LCD Panel (screen) problem, call Sony and ask for warranty cover to replace lcd panel.
Thanks.
Jul 18, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
Thick lines descending plasma screen
maybe you have interference with other electrical component near your tv. move the component, example cable box, dvd, sat box.
Apr 14, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Nikon D60 and a box on the screen
i am assuming that you are not talking about the "shooting info display on page 9 of the manual.
if it is the Photo info (sounds most likely) you can change that display by scrolling you can change your display by using the multi selector. From that screen i believe you hit the left tab by the okay key twice. Play around. when you get the display you want. just leave it alone and they will all display that way. That happened to me during a soccer game.. very frustrating.. see no way to lock it.
Jun 07, 2009 | Nikon D60 Digital Camera
LG 1710b tft monitor - no picture. screen shows 4 hozizontal line
Problem with Interface board or panel.
Also maybe due to defective powersupply filters.
Samir
Dec 10, 2008 | LG Flatron L1710B 17" LCD Monitor
Screen does not work
Did you try to start in safe mode? Turn on the laptop and start tapping the <F8> key. This will bring you to a menu with different options and select ‘Safe mode”. If that doesn’t work, try connecting an external monitor to the laptop. You may have to select the video output to display on the external monitor by holding down the blue <FN> key and pressing the blue CRT/LCD (located on one of the <F> keys, like F8,F9, etc..).
If the laptop display works in safe mode, then you probably have a video software driver problem.
If the display works on the external monitor in normal mode, then you probably have a problem with either your LCD panel.
Hope this helps.
By the way, the "9" led with the pad lock means your "Num Lock" is enabled.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 22, 2008 | Dell Inspiron 6000 Notebook
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
MSI NX7300LE-TD256EH GeForce  7300 LE, (256 MB) PCI Express Graphic Card Logo
50 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
