Question about AOpen MX36LE-UN (91.89Q10.101) Motherboard
The monitor display is all jumbled up; each text line is split
When I boot up the PC, all of the lines of text are split in half and offset to where I cannot read the screen. I thought about adding a graphics board but if I can't read the screen, how would I be able to add any drivers? Sending the board out for diagnosis and repair would cost more than buying another board, but I'm kind of stubborn about throwing away good parts on an otherwise operational board.
    President:
  • 948 Answers
Try putting a video card in it. The screen is most likely garbled because the onboard card is not working correctly.
Posted on Dec 26, 2008
Laptop has jumbled horizontal muli-colored lines flickering and rolling, can't see screen
You should try to connect a VGA monitor to your laptop and see what happens. It sounds like a video card failure, and often the hdmi and the VGA are powered by different graphics chips.
If it works with a VGA monitor, try to install a new driver for your graphics card. Otherwise, try a system restore. That often solves your problem.
If a restoration doesn't help, your graphics card is probably broken. Get a new laptop. Avoid Acer :)
Feb 15, 2013 | Acer Aspire Computers & Internet
Toshiba satilite C6550 has rainbow lines on half my screen the other half is fine ?
Sounds like the screen is going bad. Isolate the problem by plugging an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker to plug to the laptop. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the Borrowed monitor does not show the rainbow lines, that proves your video card is ok and the problem is your lcd screen. If the borrowed monitor shows the same rainbow lines it means your video card inside the computer has the issue.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 18, 2012 | Computers & Internet
Toshiba lap top half screen rainbow lines
May 18, 2012 | Toshiba Satellite M35X-S149 Notebook
The gateway FPD2275W LCD Monitor has a large vertical line on the right side which splits my screen display in half. What is it? Can't seem to get rid of it. I just had a part in changed on my pc about 3...
The vertical line on the LCD are usually caused by components failure in the LCD controller board (T-CON) which is part of the LCD panel. You can try reseting the cable connected to the LCD panel, but I doubt very much that it will fix the problem.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 16, 2010 | Gateway FPD2275W LCD Monitor
I have an Infocus LP350. The image it displays has lines running through it, which consists of the text displayed, but offset and a bit jumpy. There are also some dark black lines on the right. How can I...
if you reset the settings to factory default and the text is still like that, you have a colorwheel issue and probably a dmd chip problem. as for the dark lines, if they are more of a shadow on the edge, the colorwheel is collapsing. if they are thin and definite, you may have a main board or dmd chip problem.
Oct 23, 2009 | InFocus ScreenPlay 5700 Multimedia...
Pc wont read monitor
If you look at the monitor there will be an led light on the front that is always orange or yellow when the computer is off but still connected to the monitor. This led will turn green when the computer boots up, sometimes even showing a "no signal" display before boot. If you see the 'command line'  text during the boot process (video info, BIOS version, POST text, etc) then the monitor is being recognized by the computer. If that text goes away and the led goes back to orange then it is a driver or operating system problem. Pressing whatever key is prompted at the lower left of the display, if you have a display, like F1, F2, F10, Delete or whatever will get you to the setup program and all is good with the display/computer connection and a green light will stay on. If you never get that green led light then either the video card is bad or not seated properly
Nov 16, 2008 | HP PAVILION A6230N DESKTOP PC
Lcd display
Try connecting your laptop to an external monitor.Connect it with a vga cable to your monitor and press Fn+ monitor key(I don't know what it is for acer) to switch displays.If there are no lines on the external monitor then the problem is due to the notebook lcd.If there are lines then it is due to a driver.Reinstalling the driver should fix that then.
Aug 24, 2008 | Acer Aspire 4315 Notebook
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
AOpen MX36LE-UN (91.89Q10.101) Motherboard Logo
159 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
