Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
GE Profile Built In Dishwsher won't start when you push the start
Button. The LED screen is lit up on Heated Dry and Normal Wash with 94 minutes lit on the time remaining. At first I thought it was just in the locked position but when I held the lock release down for 3 secs it did nothing. Help, my Christmas day dishes are overflowing..
  • Anonymous Dec 31, 2008
    circuit breaker pops on ge dishwasher when start button is pressed
I turned off the power to the dishwasher for 10 minutes as recommended by a serviceman via the phone and then turned it back on and it reset itself and worked fine.....
Posted on Dec 26, 2008
Dishwasher will not start
Unlock dishwasher if locked by holding heated dry button for about 4-5 seconds next quickly hit the following buttons in successive order heated dry, normal wash heated dry then normal wash this should run diagnosis of the unit. Wait about2 minutes then press the cancel/drain button this should reset it and restore operation be sure to check that water supply is on and the drain is clear or you may get the code again.
Dec 07, 2013 | Kenmore 24" Built-In Dishwasher with...
Tip
Thanks for the advice, it worked! For a few days I tried to cancel the blinking...
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Sep 15, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
The clean light is blinking and the dishwasher does not run???
Close the dishwasher door. Push the "normal wash" button, then push the "heated dry" button. Push the "normal wash" button again, and push the "heated dry" button again.Try out his and see what happens.It must reset the memory and your dishwasher must work.
Jul 06, 2010 | Kenmore 24 in. 16352 / 16354 / 16359...
Low detergent light does not come on indicating the GE profile dishwasher is out of detergent.
It is probably because your Smart Dispenser is full of water and there may be a clog of some type in the pump. Try purging your Smart Dispenser and see if it fixes the problem!! It fixed ours!!
How to Purge Smart Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Jul 09, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Purging ge profile smart dispense dishwasher
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
Jul 05, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Buttons won't work on GE Profile PDW7980N10SS
You have the control lock activated. Press and hold the heated dry pad for 5 seconds and it should unlock it
Nov 15, 2008 | GE Profile PDW8400J Built-in Dishwasher
Blinking lights on control panel
Same issue, machine is about 30 days past waranty. Door switch broke, but of course they (GE repair) do not fix the switch, you have to order the Escutcheon Body (whole panel) to fix ~$350 total.
Apr 26, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Kenmore dishwasher wont start blinking clean light
today January 9, 2009...blinking clean light, kenmore dishwasher would not run,,,the solution on Fixya ..."keep hitting normal -heated wash-normal -heated wash buttons over and over...unlocked the blinking green light problem. Dishwasher is running as I type this....will post again when I see the results of another washing tomorrow. H.T. Las Vegas Nv
Jan 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Whirlpool 24 in. DU1055XTP Built-in Dishwasher
I don't know if your dishwasher is the same as mine, but this solution may be what you need. For electronic panel dishwashers made by whirlpool (mine is a whirlpool but with a kenmore name on it), some of them can be reset by pushing in sequence the Heated-Dry button followed by the Normal-Wash button, several times in a row. that is... Push Heated-Dry, then Normal-Wash, Then Heated-Dry, then Normal-Wash... Repeat until all lights light up. When all lights light up you can stop. The washer will then take 5-10 minutes to go through a diagnostics cycle, which is about 18-25 steps or so. You can bypass one step at a time by pushing the STart button. This may not apply to your washer, but is pure gold if it does. Good Luck!
May 26, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
297 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
