Question about Tomtom One XL GPS Receiver
My TomTom will not shut off
I turn off the unit which then dislplays the suitecase and turns off. The screen goes black then a few seconds later it comes right back on.
SOURCE: turning unit on , only comes to a blank white screen
This worked, it took about 2 mins. and no more white screen.
Software problem I sure.
http://www.tomtom.com/support/index.php?FID=8578&Lid=4
Posted on Jan 04, 2008
SOURCE: tomtom wont turn on
http://www.tomtom.com/support/solution.php?GID=1&PID=233&SID=0&CID=152&Language=8&FID=6965#reset_button
Posted on Feb 21, 2008
SOURCE: tomtom won't turn on
Holding down the Power ON for a longer period of time worked for me. Totally grateful. Thanks.
Posted on Apr 20, 2008
SOURCE: TomTom ONE has flashing "X" and picture of TomTom
I found this.
Question: Device shows a flashing cross when turned on.
Answer:
If your device only shows a cross after you turn it on, the TomTom application is not installed or cannot be found.
To solve this, follow the steps below.
Manually remove the TomTom application:
Reset your device.
Connect your device to your computer.
Turn on your device by pressing the power button for 5 seconds.
Do one of the following:
Windows: Click Start > My Computer and then double-click the Removable Disk for your TomTom device.
Macintosh: Double-click the desktop icon for your TomTom device.
Delete all files except the following:
Do not delete any of the folders!
Do not delete the files antitheftw.bmp, lowbatteryw.bmp and splashw.bmp (if present)!
Reinstall the TomTom application:
Start TomTom HOME
Select an option:
I previously updated my device on this computer
I never updated my device on this computer
Click Done and then click Device > Disconnect Device.
Your device should now start up again. If it hasn't started up after 10 seconds, press the On/off button.
Posted on Jul 17, 2008
  • 121 Answers
SOURCE: tomtom xl.... on starting unit it immediately goes to select a language and then a few more windows such as right/left handed, time display format and eventually it goes to select a voice where after
yep common error reset it or plug it in to pc and download other voice
Posted on May 04, 2009
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
The screen shuts down after between 30 & 60 secs
This is an option for the TomTom. If you enter the Options, there should be something about Power Save features. In there, you will see options to shut off the screen, and you can have it do so after a certain time, once a certain speed is reached etc. Just change the time in which it turns itself off to never and you're fixed.
Sep 30, 2009 | Tomtom ONE GPS Receiver
Turn on the tv a few seconds later it shuts the power light blink
Replace both of your convergence ICs they are STKs big black ICs will have part number on them.
Jun 19, 2009 | Mitsubishi WS-55511 55" Rear Projection...
TomTom Go 910
my tom tom one xl has been used 3 times... tried to use it today...pushed on button...start screen on,,a few seconds later the satchel w/the gps and it turns off
Jun 09, 2009 | Tomtom ONE GPS Receiver
Screen goes blank after locating sattilites.
Accordingto Garmin, this problem can be fixed by disabling the WAAS feature in teh set up menu. There is an incompatibility between the old Garmin software and latest WAAS upgrades. Later software from Garmin is supposed to fix this problem.
May 21, 2009 | Garmin eTrex Legend GPS Receiver
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
My screen goes dark when I use my navigator
change screen settings. here's how to; goto change pref, -safety pref- (ignore first screen)-done-- done--done--then it will come up with---turn off map display, select never option then done , you will also need to check to see if your screen saver option are set to slide show and turn these off as well.
Jan 05, 2009 | Tomtom GO 910 GPS Receiver
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Tomtom 3rd edition
I think it has to do with hooking up your unit via the usb cable to the computer. I got one from Radio Shack and it worked fine for a day, drove with it and shut it on and off a couple of times. Then I hooked it up to my emachine computer, and all I got was a white screen. Took it back got another one, drove with it, turned it on and off a couple of times, worked fine. Then I hooked it up to my computer, and again the same white screen until I reset it. I noticed all these posts are in the last few days, so I would say it is a bad batch of units. I purchased one for my wife 3 weeks ago and no such problem.
Dec 17, 2007 | Tomtom ONE GPS Receiver
Tomtom One XL GPS Receiver Logo
176 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
