Question about Tascam CC-222MKII CD-RW Cassette Combo " Shipping" CD Player
Sharp mini system cd- mps660 this unit comes up with an toc reading problem and won't play cd's can u help?Owen
4 Suggested Answers
SOURCE: TOC Reading...
According to rep. at Tascam, laser is weak or dead. If you are electronically/mecahically inclined, you can replace the drive mechanism (sort of like aCD-RW drive in a computer, but this has flex-circuit cables going to it for power, signal, and control which are relatively delicate compared to the cables in a computer). Parts Dept @ 323-726-0303 ex.840 can supply you
with your needs.
Posted on Jan 24, 2008
  • 86 Answers
SOURCE: Sharp XL-HP515 CD Player won't play. Displays "toc read"
take it apart and clean len with a qtip an rubbing achol on face and mirror sides(top and under
Posted on Oct 09, 2009
wglenn742010
  • 6 Answers
SOURCE: Cd-mps660 sharp mini system will not play any cd-r
sounds like a codec issue.... what format are you burning to disc? are you able to connect your system to your computer? id try different formats on burning discs first. ive had this problem with other cd players and funny thiong is i have a really old denon cd player that that is bout my age or a lil older and im 31 that will play burned discs but yet alot of newer players wont and its all bout codecs and copyright protection these days so hopefully this will help you.... also try different brand of blank discs.
Posted on Oct 22, 2011
I have a Sharp mini component system. The CD function says TOC Reading when I try to play a CD. A few seconds after it says Can't Read. I am not able to use a CD disc cleaner.
I am assuming it fails on multiple CDs right? Why can't u use a CD disc cleaner? Otherwize u have to get access to the laser with a Q tip.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Mar 01, 2018 | Sharp Audio Players & Recorders
What does utoc error mean on a Kenwood mini disc player
Well, what it means is
TOC errors often mean the recording head/optical block is cooked. A cleaner might work, but often it's the end of the MDR.
Are you sure the battery is correctly (fully) charged? Try removing the battery and running on (only) the charger.
try cleaning the lens with a minidisc lens cleaner.
open the unit and check the laser position - it should be all the way to the left. that's where it should start to read the disk.
Read these:
https://groups.google.com/forum/#!topic/alt.audio.minidisc/63uCBegyG8A
http://www.minidisc.org/repair_q2.html
http://forums.sonyinsider.com/topic/21439-fun-with-the-sharp-702-utoc-error-fixed/
http://www.mazdas247.com/forum/showthread.php?98358-TOC-Error-on-brand-new-disc!
http://www.borus.de/minidisc/303.htm
Jul 07, 2014 | Sharp MD-MS702 Personal MiniDisc Player
I have a cd xp120 sharp mini stereo andt it won`t read the disc,i bought and replaced the lens but it still says no disc.
To fix this properly the whole laser assembly needs to be purchased, because it comes pre-aligned which is critical when it comes to a set up.
Apr 06, 2012 | Sharp CD-XP120 CD Shelf System
Oct 22, 2011 | Sharp Audio Players & Recorders
When I input a disc and hit play I receive an error which says "TOC ERRORa".
Possible that the disc is not reading and so the the TOC- table of content error must be referred.
It can be due to a poor head tracking or the failure of the data being read or processed.
Clean the head and use a good disc to be checked once again. If so the optical head can be faulty as it might be getting weaker.
Nov 06, 2010 | Sharp MD-MS702 Personal MiniDisc Player
Kenwood MD plays ok but recordings fail to play; U TOC error?
Without a decent Table Of Contents, your MiniDisc will NOT work, as you've found out. Does it matter what brand of MD you use? I would record it at "1X" and NOT 4x speed too. Try erasing a blank minidisc first and then shut off the unit and then turn it back on and see if the TOC works. Try adding a title, then turn it off and back on. Then try the CD to MD.
Jan 16, 2010 | Audio Players & Recorders
Oct 09, 2009 | Philips CDR770 CD Recorder
Sharp XL-HP505 Not playing CDs
Hi try this.....
Put the system in standby (ie off but plugged in) then whilst pressing down the record button and the X-BASS/DEMO button, press the PRESET DOWN (i.e.left hand one) button until "CLEAR ALL" appears, then power on your system.
This gave me some functionality back i.e. i can play normal wave CD's but not mp3 ones....
Hope this helps
Sep 07, 2008 | Sharp XL-HP505 CD Shelf System
TOC error message
Unit displays TOC error when I inserted two new cds I purchased.
Nov 05, 2007 | Audio Players & Recorders
Mini sharp stereo
Try pressing the play button on the remote. If it works correctly, the play button on the unit may be defective.
Sep 04, 2007 | Sharp CD-BA150 Shelf System
145 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
