Question about Samsung CXM2785TP 27 in. TV/VCR/DVD Combo
18 Mo old Samsung CXM2785TP made high pitched noise and lost power
My set is 18 months old and has had very light usage as it is in a garage apt and has averaged 6-10 hrs of use per week. Today it made a high pitched sound and then i lost power. Neither remote nor TV power button will turn the TV on. Does anyone have any idea what the issue is and if the repair is worth the value of the TV?
  • 81 Answers
The high pitch sound could have been the flyback transformer. check the horzontal output transsitor if is gone the tranfomer is sure to be gone . Tranformers are varying in price are the transistors can also vary you could be looking at around 150.00 plus labour.
Posted on Apr 19, 2007
SOURCE:
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
My Samsung LCD has no picture (screen is black) and the power repeatedly turns on and off. The red light on the power button continues to turn on and off. Can you help? The TV is only 3 years old.
open back cover check 5v filter capacitor on powersupply board that is either 1000uf or 2000uf
do you see any bulging capacitor? replace with top quality capacitor.
Aug 07, 2009 | Samsung CXM2785TP 27 in. TV/VCR/DVD Combo
High pitched noise red light blinking
A high pitch noise comes normally from blown capacitors from the motherboard or the power supply. But mostly high pitch noise comes from power supplies.
You could have to open up the power supply to see them.
Verify if it is the case and replace the faulty part.
May 26, 2009 | Dell PowerEdge 1800 Server
Samsung SlimFit 30" high pitch whining noise
I have had the same high pitch tone problem for several months after about 20 minutes of use. It is so bad it's rendered the TV almost unwatchable. I contacted a repair place from Samsung's website. I was told that is likely the flyback transformer. I don't know what it is, but it sounds cool like a flux capacitator. I was told it would be about $100 to fix. However, I have had very little luck getting the repair shop to order the part and do the work.
Sep 04, 2008 | Samsung TXR3079 TV
Samsung LNT3253H is making a high-pitched noise
I had the same issue. The tech that came out today removed the transformer on the power supply board, "resealed" it, and replaced it (re-soldered the same part back on) -- the transformer apparently vibrates because it was not properly sealed. BTW, mine was about the fifteenth that he has performed this repair on within the past couple of months -- all 32" and 26" Samsungs. Now, it appears to be absolutely silent.
Mar 22, 2008 | Televison & Video
High Pitched Noise
try washing on hottest cycle it may be the seal in the spray pump somethimes the rinse aid can put a glaze on the seal if that doesnt work you can replace just the front part of the motor( in australia) dont know where you are.
Feb 06, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
High pitch noise
Hello there, You have to specify where the noise is coming from. Is it coming from the speaker or from the back of the unit. SMPS power supply powering your unit create this kind of noise when some capacitor gone out of their value.
Good Luck.
Jan 26, 2008 | Samsung LW26A33W 26 in. HD-Ready LCD...
Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Jan 01, 2008 | Samsung TX-P2670WH 26" TV
High-pitched noise when I turn on the tv
No I think your problem is the horizontal output transistor blew out an that was a result of the flyback transformer going out or blowing up.. Good Luck TO you.
Mar 25, 2007 | Samsung CXM2785TP 27 in. TV/VCR/DVD Combo
Samsung txc2515 lost picture makes high pitched noise
Sorry mark that high pitched noise is an indication that the switching power supply has an overload on the outputs. It could be a shorted Horizontal output transformer or transistor or a combo of both. Also could be a shorted vertical driver or output device or could also be a simple cap opened up and is causing a really large current flow BUT if your not a tech i advise you not to tamper with or open the set as you will not "see' a problem or "look" at the open set and find anything wrong! these sets are not user serviceable and can cause you great harm.. So please if the set is this old its probably not worth investing any cash into the repair unless of course it has personal meaning to ya. its up to you to decide Good Luck
May 23, 2006 | Samsung TXK2567 TV
Samsung CXM2785TP 27 in. TV/VCR/DVD Combo Logo
183 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
