Question about Pioneer VSX-D903S Receiver
I'd like to know where the vcr cable & cable wire from wall
Would be plugged into the Pioneer VSX-D903x receiver. I only find one place on the unit for cable connection.
    Problem Solver:
  • 18 Answers
(I own 2 VSX-D903S Units.)
There are NO optical (Toslink) or coaxial connections for Satellite or Cable-TV on this Pioneer unit.
The coaxial connector on the receiver is for connection to an external antenna for FM Tuner (radio) reception only.
Your cable line from the wall would go to your Cable Box, or a "cable-ready" TV or VCR. You would then connect the composite (YLR) or S-video output A/V (S+LR) connection to the VCR 1 input on the back of the receiver. Connect your TV L/R audio and S-video or Composite video output to the TV in connection on the Receiver. (Connect the Composite TV-out connection to a composite video-in connection on the TV.)
Posted on Nov 25, 2014
5 Suggested Answers
SOURCE: Pioneer VSX-D608 Optical connection
Do you have the original remote for the receiver? You need the remote to set up the optical settings according to the manual there is a fair bit of things to do to set it up reply if you do have the remote then I will post up word for word on how to change the settings but without the remote you basically cant do much with it sorry
hope this helps
Posted on Sep 21, 2008
dthomas1969
  • 4 Answers
SOURCE: Owner's Manual - Pioneer VSX 455 Receiver
It should be compatible with all of them. I have one that works just fine with my Sony HD/TV, HD DVD PLAYER, etc. The only difference is that its is stereo w/ a middle speaker hook up, if you so desire.
I find it just as enjoyable and easy to use as my Denon 6.1 with fewer speakers. That is because as men, our hearing range is poorer especially as we grow older.
Email me with any other concerns you may have.
Thanks,
dthomas
Chicago, IL
dbondick@comcast.net
Posted on Feb 07, 2009
  • 30 Answers
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
Posted on Aug 02, 2009
  • 15 Answers
SOURCE: Pioneer vsx-819H: MCACC setup won't display on tv
Its because the pioneer does not display menu options through hdmi. You have to hook up basic yellow composite to monitor out.
Posted on May 03, 2010
Pioneer vsx-5231 not pairing with Phillips bdp-2175 smart bluray player
have you tried to connect the Philips direct to the TV's hdmi?
Could be the resolution on the bluray is set to 1080p which may be out of range for the receiver or even the TV for that matter. If you can reset the output resolution of the bluray to 480p first, just to establish a picture then try 720P which all HD tv's and receivers can handle.
I did a quick search and could not find the resolution reset procedure for this unit. Other units will reset if you press and hold 2 or more buttons together.
May 04, 2014 | Pioneer VSX-521-K 5.1 Channel A/V Receiver
Pioneer vsx-515 no sound from dvd player plugged into coax input.how do you check the coax cable?
Its just a wire covered with a shield. You can ohm it out with a multimeter.
Mar 22, 2010 | Pioneer VSX-515 Receiver
I would say check the cable version not everyone knows this but there are different version HDMI cables such as 1.0,1.1,1.2 and the newest 1.3 cable these are band-with depended cables and if you use a lower version this should work if not you might have a issue with video.
Other then that you might have a issue with the unit if all other signals are working on the monitor.. Ruling out this will be hard if you do not have another monitor to test it on. I would be conducting a test on other output monitors and see if you get any results.
please press the accept button as I worked hard to answer you question.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Oct 24, 2009 | Pioneer VSX-819H-K A/V Receiver
Unacceptable humming @ zero volume from new VSX-82TXS
Not normal. Get another working one or return and get your money back.
Jul 28, 2017 | Pioneer VSX-82TXS 7.1 Channels Receiver
Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
Feb 10, 2008 | Pioneer VSX-505S Receiver
Av illiterate
Make sure your cables are all properly connected
Jan 28, 2008 | Pioneer VSX-455 Receiver
Pioneer VSX-4900S Receiver Connections
I know this is an old post but run front speaker outputs to the inputs on the sub then from the sub to the front speakers. bam!! it should work
Jan 23, 2008 | Audio Players & Recorders
Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Nov 08, 2007 | Pioneer VSX-453 Receiver
Pioneer vsx-d307
You have a flashing "mute" on the display?...accordianman
Oct 04, 2007 | Pioneer VSX-D307 Receiver
Woofer problem
If I am not mistaking here, you need a self powered subwoofer to use with this unit. Those are line driven outputs for this unit. Make sure there is a wall plug on the sub that is plugged in. Good Luck
Jun 07, 2007 | Pioneer VSX-516-K/S Amplifier
115 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
