Question about Whirlpool Duet GHW9150P Front Load Washer
HE2 Draining problem
I followed the steps listed for unclogging the drain (I have done this often over the last month) and there wasn't anything clogging the filter. I re-started and it went ok for a minute then listed the F21 fault again. I checked the drain again and nothing was in there. Is there anywhere else that this line may be clogged (other than the white drain filter) that I can check?
  • jdtech May 11, 2010
    Look inside the pump filter assembly remove the 3 screws holding the kick panel on the front and the screw that holds the pump unscrew the filter and look in the housing for a small sock or something like that also disconnect the drain hose observe for kinks and hook it the faucet and make sure water flows freely out of it there is also a check ball from the tub to the pump make sure it is clear
  • 113 Answers
If its no draining at all. Open the pump back up and there should be a small hole about the diameter of a quarter to the left. Inside you should feel the impeller with your finger. Try to spin the impeller with your finger, it should have some resistance and a recoil as it turns. If not, than the impeller shaft is broken and the pump needs replacing. Hope tht helps, Dave www.washermd.com
Posted on Dec 26, 2008
How do I unclog the drain in the powder drawer on my HE2 Plus
You can usually remove the top panel & squeeze the hose to break up soap powder that has hardened.
Dec 21, 2013 | Kenmore HE2 Plus Front Load Washer
Kenmore 80 Series Washer is not draining. Worked fine for first wash last night, but did not drain on the second. Anything that can be done by us to check this problem?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 25, 2011 | Kenmore Washing Machines
F21 shows up. not draining
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Sep 24, 2010 | Kenmore HE2 Plus Front Load Washer
F02 Washer not draining. How do I unclog drain? I have already taken the hose off, so I think its stopped up somewhere else. Thanks.
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&$&$&%&
Aug 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Giving a F- on the time screen and is not draining properly
http://www.applianceblog.com/mainforums/attachments/sears-kenmore/639d1187051794-he2-error-codes-he2-error-codes.pdf
That list all the service codes for that washer.
Feb 15, 2010 | Kenmore HE2 Plus Front Load Washer
My HE2 front loader was not draining and showing f21 checked for clogs and now it won't do anything
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Jul 16, 2009 | Kenmore Washing Machines
Condensate is blown out of the AC vents in front of passenger
Use compressed air to unclog the exit of the drain piping .Done in half second withour disassemblying anything.
I was told by a mechanic that this problem is very common with all Mitsubishi models.
May 14, 2009 | 1999 Mitsubishi Montero
Kenmore he2 front load washer
“F21” (AKA SD) is a Long (SLOW) Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Apr 03, 2009 | Kenmore HE2 Plus Front Load Washer
HOW DO I GET TO THE PUMP TO UNCLOG IT
take cabinet off and the pump is right there in the front of the motor.remove the top hose and the water will finish draining on the floor.reach in and you should be able to take out the obstruction.
Dec 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Duet GHW9150P Front Load Washer Logo
165 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
