Question about Hitachi 53UDX10B 53" Rear Projection Television
Where is the "little blue button" on Hitachi rear projection TV?
I have an Hitachi 53UDX10 rear projection TV that is stuck in the screen that consists of 9 cross hairs (I got there after a ROM save error trying to adjust color convergence misalignment from the service menu). The 52" screen of this TV sits on a "pedestal" that houses the speakers. I read some other threads here that for some Hitachi models I should remove the front panel to access a "little blue" reset button that gets me out of the cross-hairs mode and back to the service menu, but there are no screws in the base of the front of this TV that would let me remove it. Does anyone know where that reset button would be on this model? Is it behind one of the back panels?
  • Robert Katman Dec 29, 2008
    To answer my own question, the "little blue" reset button on the
    53UDX10 is on the convergence board which theoretically should be
    accessable from the front left side behind the speaker panel, as it is
    on other Hitachi sets. I reached it from the rear of the set while I
    had the back cover off and the set unplugged. But I still don't know
    how to get the front panel speaker cover off to access this reset
    button while the set is on. There are no screws visible. Is this panel
    clipped on? I've tried tugging at it without success. Any help would be
    appreciated because I'm still stuck in the service screen with the 9
    cross hairs.
  • Robert Katman Jan 07, 2009
    More answer(s) to my question: The entire front panel (including the
    L&R speaker covers) of the 53UDX10B is held on by plastic clips. I
    tugged on the upper left hand corner of the speaker cover with my
    fingertips, and it came loose. Then I pried off the rest of it with my
    fingers. That revealed a plywood panel that served as a front cover for
    the circuit board area and that was held by 5 screws. I removed those,
    and that plywood panel came off, giving access to the insides of the TV
    from the front. Hope this helps someone down the line. BTW, the "little
    blue button" is on the front side of the convergence board which sits
    to the far left as viewed from the front of this TV set.
  • 61 Answers
SOURCE: RCA 52" Rear Projection P52930BL
You can adj. from the front panel of the set using the channel and vol. buttons,if the set you have has a ptk 195 chassis,check and make sure you have adj. projection tv in screens of the menu,in not the convergence power supply has failed,replace the reg on the board,part number is 215530
Posted on Mar 06, 2008
MikeNJ1964
  • 398 Answers
SOURCE: 52" HITACHI PROJECTION ----50UX27KV6J009857
If you mean that one of the colors has suddenly drooped toward the center, creating a curve along the side where the colors no longer line up, it means that one of your convergence IC's has burned out and needs to be replaced. You should not play with the convergence settings when this happens because when the IC is replaced, the settings will be all out and have to be reset. It is a good idea to replace both STK392-110 IC's with the newer improved STK392-150's. If you have never replaced convergence IC's or realigned convergence circuits then allow a qualified tech to handle it for you.
Posted on Aug 07, 2007
  • 12 Answers
do you have a magic foucus button??
Posted on Aug 15, 2007
SOURCE: How do I Remove Front Cover Screen of Hitachi 53SBX59B53 Projection TV???
Did you ever find the solution to removing the front screen? I have the same problem. Please write at superduper200554@yahoo.com
Posted on Jan 21, 2008
yankeegurl
  • 121 Answers
SOURCE: PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
Posted on Apr 13, 2008
Magic focus runs half way & stops &showes a #4 ? one side of a face has a green outline the other side red
You may have a burned out convergence chip. But first, if you haven't already, you can try service mode to adjust convergence. Press the Magic Focusbutton, and then press it again to stop it, and then press the Statusbutton on your remote. Here's a link to the manual convergence procedure (scroll down). Warning-- When I did this the set got stuck in one of the adjustment screens. I had to remove the bottom front panel of the TV to reach the "little blue" reset button to get back a TV picture. But I think this is worth trying before replacing parts.
Mar 02, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi tv no picture or sound.
my hitachi projection tv 53uwx10b screen is black with no sound or picture when the power button is on
Dec 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
53udx10 goes into shutdown
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Jul 05, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Blue splotches on screen
sorry but u have a bad optical block price $450 - 600 dollar part
May 08, 2009 | Hitachi UltraVision 60V715 TV
Blue haze on hitachi 51" tv
http://www.hdtvoice.com/voice/showthread.php?t=15263
Jan 12, 2008 | Hitachi 51F500 51" Rear Projection...
Hitachi 50 rear projection
Just curious... since the Hitachi 50UX57B projection TV does not have any lamps in it, exactly which "lamp" did you replace? Did you actually replace the entire blue CRT itself?
Jul 23, 2007 | Hitachi 50UX57B 50" Rear Projection...
Blue screen
Your tuner or PLL circuit is blown out. if you have homeowners call the agent. Good Luck
Aug 10, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
823 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
