Question about Maytag SkyBox MBV1976A Beverage Dispenser
MBV1976AAP Will not dispense. When pressing button, no lights no beer! Actually, not a single light on the panel lights (except the main light for the entire door). Beer is cold. It just does not dispense.
I have the same problem with my skybox. Will not dispense. I found a web site that has the part to fix the problem.Have not fixed it my self yet but this should do the trick.(repair clinic.com)Item#1066720. (board,pcb flipper door)The sensor burns out do to condestation.The sensor is in the door next to the flipper door.Removing this should be no problem with any kind of skill level.Good luck.
Posted on Apr 21, 2007
Control panel failure
Have you tried unplugging and plugging the fridge back in? This may reset the control baoard.
Apr 13, 2014 | Refrigerators
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Where is the automatically dispenser light located on the refrigerator
Go to page 5 of your user manual HERE
Style 1: The dispenser light can be turned on by pressing the ON
button.
Style 2: When you use the dispenser, the lever will automatically
turn the light on. If you want the light to be on continuously, you
may choose either ON or NIGHT LIGHT.
ON: Press the LIGHT button to turn the dispenser light on.
NIGHT LIGHT: Press the LIGHT button a second time to select
the Night Light. The dispenser light will automatically adjust to
become brighter as the room brightens, dimmer as the room
darkens.
OFF: Press the LIGHT button a third time to turn the dispenser
light off.
The dispenser lights are LEDs which should not need to be
changed. If it appears that your dispenser lights are not working,
check to be sure that the light sensor is not blocked (in Night Light
mode). See "Troubleshooting" for more information.
I am here if you need help, Sea Breeze
Parts Manual
Mar 03, 2013 | Whirlpool GC5SHEXNS Side by Side...
How do i reset the filter light on my refrigerator msd278ge
Simply press and hold the dispenser lock and auto light buttons on the dispenser (at the same time) for four (4) seconds until the filter status indicator begins to flash, then release the buttons. On some Amana refrigerators, you need to press the dispenser lock and water buttons for four (4) seconds until the filter status indicator begins to flash, then release the buttons.
Also note that
  • Remove the old water filter from your refrigerator by turning the handle counterclockwise and pulling it out of the filter holder. The filter is located in the upper right corner of the refrigerator.
  • Step 2Slide the replacement filter into the filter holder and turn it clockwise.
  • Step 3Press and hold the "Reset Filter" button until the indicator lights go off if your model refrigerator has a "Reset Filter" button on the control panel.
  • Step 4Hold the "Lock" and "Light" buttons on the control panel until the filter indicator lights turn off if your model refrigerator does not have a "Reset Filter" button. For models that do not have a "Light" button, press and hold the "Lock" and "Water" buttons.
  • Good luck......
    Jul 29, 2010 | Maytag MSD2758GEB Side by Side...
    Bosch B22CS80SNS sxs with no lights
    You can get the manual here. on page 16 it tells you how to take off savagemode.
    Sabbatical mode settings:
    – Accoustic signal is switched off.
    – Super cool or Super freezing
    functions are ended (if activated).
    – The interior illumination is
    switched off.
    – The light on the display panel is
    reduced to basic lighting.
    – Buttons are locked (except
    “options” and “+” buttons).
    Switching on and off:
    ̨ Simultaneously press “options”
    and “+” buttons for 5 seconds
    When switched on, [Sabbath] is
    indicated on the display panel.
    Good Luck
    Nov 02, 2009 | Bosch Refrigerators
    No ice or water from GE Profile side by side refrigerator freeze
    I had this problem and did 3 things to correct it:
    1st: I changed out the Main Circuit Board in the back of the fridge.... very easy to do, but that wasn't the problem.
    2nd: I changed out the Dispenser Circuit board, which is behind the touch panel. Also very easy to do, just snaps out. but that also wasn't the problem
    3rd: I checked the wire harness connection point located behind the grill at the bottom front of the fridge underneath the freezer side. This is also very easy to do, and son of a ..... that is what is was. Moister from mopping the floor had started to corrode the connections. So I purchases a cheap 3 wire plug and cut out the old and spliced in the new. You don’t actually need the plug, you can hard wire direct but if you ever have to take the door off you will have to cut the wires.
    So now I’m the proud owner of an extra functioning Main Circuit Board and Dispenser Circuit board if anyone is in need.
    Nick
    Jun 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    How do I get the filter light off after changing the water filter?
    PRESS THE LOCK AND LIGHT BUTTONS AT THE SAME TIME UNTIL LIGHTS BLINK.THEN IT WILL RESET FOR 12 MONTHS OR 44O GAL.HOPE THIS HELPS
    May 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
    Skybox wont dispense
    look for ice blocking the door on the unit and causing it not to fully open , good luck
    Jan 08, 2009 | Maytag MBV1976AAP Beverage Cooler
    Skybox
    I have a Sky box Model mbv1976aap series 10. It is complete but not working. I think it is the overload switch on the compressor as it arcs every time I plug it in. I don't want to fix it but I will sell parts for half price of parts direct website. I can be reached at scrapjunky@cox.net. I have dispensers, cooling fan, circuit boards, what do you need?
    Mar 09, 2008 | Maytag MBV1976AAP Beverage Cooler
    Beer won't dispense, last one furthest to the right.
    Have you checked the child-lock buttons?  They are located on the right side of the machine and are accessible only when the door is opened.
    Sep 10, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
    Maytag SkyBox MBV1976A Beverage Dispenser Logo
    331 people viewed this question
    Top Maytag Retail Supplies Experts
    John Tripp
    John Tripp
    Sal De
    Bailey's...
    Bailey's...
    Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
