Question about Pelco DX2000 Series 16-Channel 80GB DVR
I'm looking to config a Pelco DX2000 Dvr with A cross-over cable
I"d recently purchased a Pelco DVR, I contacted pelco , and they advise me, to purchased a cross-over cable to link it to the PC. I purchased the cross over cable, and try to use the IP address in internet explorer, to connect the drv but it does not connect. does any one knows the answer. Please advise me.
    Problem Solver:
  • 5 Answers
You can connect it to your PC directly with a cross-over net cable, and you also connect it to your LAN with straight net cable. Type The default address: 192.168.2.108:8004 in your IE after you set your pc address in the same geteway, you will see the user and PW requirement screen. if you can't get this screen,try to reset DVR to default setting. see Page#100 of its manual.
Posted on Aug 10, 2009
Need to increase the hard drive to at least 6TB
Nor am I.
A 6Tb hard drive cost around $850.
You need to check if the Pelco can support a hard drive as large as this and it will need the operating system installed on this hard drive,
The Pelco may have a slot to install a second hard drive.
Oct 19, 2012 | Pelco DX4516DVD-250 16-Channel Digital...
Delete video
Log in as admin and format the HDD will remove all recoded video.
Nov 22, 2011 | Pelco DX2000 Series 16-Channel 80GB DVR
I have 6 pelco make 5104 dvr connected to a
If all of the 6 DVRs are on the same location (on the same network), and you want to remotely connect (VPN) to that location, you can Endura Enable the DVRs and then VPN to the Primary DVR. (Note that you need to be Endura Certified to use the Endura Enabled feature).
If they're all geographically distributed, you can only VPN into a single unite at a time..
Jul 15, 2010 | Pelco Video Recorder
Using RAID DVR to format multiple drives 4individual resale
Download TRINITY DISC RESCUE iso , then burn it to a disc. Get all your pcs that need the same HDD setup and connect them to a router. Boot to Trinity Disc Rescue on each machine. READ the Manual it gives a very brief description of how to clone from one drive to many, its a single command
The master machine needs to boot trinity and have a special command enabled, again its just a single command. This setup will clone one pc to everything on the network which is running trinity and the special command,
READ THE MANUAL FIRST its a brilliant resource.
Feb 08, 2010 | Computers & Internet
Problem setting up Network Cameras
on the cameras them self there should be a adress and baud rate setting this should be the same as what you have on the software. also the cable that you have going back to your ethernet panel cannot be by any electric lighting or anything like that and check and make sure that the connetors that plug in to the panel have the right color code. you need to look for the straight through wiring diagram 568b. hope this helps.
Nov 11, 2009 | Pelco DX3100 Series 8-Channel 120GB DVR
Error when loading page from browser
Newer versions of Java does not work on Pelco dx2000. You have to use Microsoft's VM version of Java, which is no longer offered by Microsoft, but you may be able to find it somewhere. current Java (from Sun) needs to be uninstalled. this makes the computer compatible with DX2000, but not the Internet as is it today. Kinda sucks, eh?
May 22, 2009 | Pelco DX2000 Series 16-Channel 640GB DVR
My pelco DVXe dvr display is at minimum not 32 bit cant see pics
boot into bios and set your display for vga mode. At least that worked for me
Apr 09, 2009 | Pelco Home Security
I have pelco dx 2000 dvr of pelco brand i just want to know can i increase the recording days with new high rating hard drive from 90 days to 120 days
yes, on the configuratiion plage, use the schedule to increase the amount of time you want for
1) Sechedule recording
2) motion recording
3) event recording.
Remember, this is all based on the size of your hard drive and the number of camera you have installed.
Jan 14, 2009 | Pelco DX2000 Series 16-Channel 80GB DVR
Pelco DX2000 Series 16-Channel 80GB DVR Logo
461 people viewed this question
Top Pelco Televison & Video Experts
Electro Med Services...
Are you a Pelco Televison and Video Expert? Answer questions, earn points and help others
