Question about Magic Chef CEL1110 Electric Kitchen Range
HELP DO I NEED TO UNHOOK THE GROUNG TO MAKE IT WORK
    Problem Solver:
  • 8 Answers
DO NOT UNHOOK THE GROUND!!! If it is a newer range it needs a 4 wire circuit ( 2 hots, neutral and ground). The range needs 220 volts for the heating elements and 110 volts for the controls. Call an electrician!!!
Posted on Dec 26, 2008
I am trying to figure out how to adjust deck height
most mowers have a lever to raise and lower the deck . that is the height adjustment also then the wheels need adjusted to meet the ground . without a make listed we really can do no more
Sep 03, 2016 | Garden
My 24' above groung pool with a 1.5hp pump and sand filter ssems to be losing prime when i hook up my aqua critter. If i unhook the critter the pump re-primes. Any sugguestions as to why?
Your hose either has a hole in it, at the sections at the waters surface where it is exposed to the air? Even a "Pin" hole will create the symptom you are experiencing.
Or... there is a clog in the unit itself.
It appears that you are either sucking in air, or the water flow is being blocked. The pump should pull water no problem through a vacuum hose or a suction style pool cleaner. If the pump loses prime, then "Water" flow is being restricted either physically are mixing with air.
Aug 13, 2013 | Hayward SAND FILTER, PRO SERIES
My off set light is on even after i unhook my rca and speakers how do i fix this
offset light is on when coonected amp, groung is good, wires fine, tried another amp and works fine , what the heck. is the amp no good
Oct 27, 2010 | Sony XM-1502SX Car Audio Amplifier
When I pulled bed off ,wires were cut. I have 2 green wires cut making 4 ends, 1 black wire and one white wire. I assume the green go with green , but the black ground and white wire I am not sure where...
Use a test light and check which wire has power as you turn on each function. The ground can be checked with an ohm meter . Put one lead of the meter on a clean groung spot on the frame and test each wire with the other lead . The wire that shows infinity or 0 resistance should be groung .
Oct 22, 2010 | 1990 Chevrolet C1500
Headlight not working ,checked fuse,changed bulb,checked for voltage
If you did these things what are the results, a new bulb and good voltage would end in a bulb that works. If positive power to run the bulb is there a groung to the bulb is also needed.
Apr 17, 2010 | 2003 Honda VTX 1800 Retro Cast
Wipers move a little but do not work at all?
I HAVE SEEN THIS BEFORE IT IS EITHER A BAD GROUNG OR MOTOR, SO HOOK UP AN GROUND FROM KNOWN GOOD GROUND TO WIPER MOTOR. IF IT DOESNT START REPLACE THE MOTOR HOPE THIS HELPS
Feb 12, 2010 | 2003 Pontiac Montana
Blower Motor doesn't work in Heat or AC in a 1999 Ford F250 Super Duty.
If it is not workring at all, including all speeds then i would say blower motor is broke and needs replaced. But first check your fuse panel for a blown fues. It is located under your steering column. Your book will tell you which fuse runs it. Then try unhooking the wire harness from the blower motor so that the motor is not connected to anything. Run a groung wire to the ground side and a hot 12 Positive wire to the other wire and see if it comes on. If it does not then replace it. If it does then you need to look elsewhere.... IE switch, resistor pack relay, or even possibly wiring.
Jan 23, 2010 | 1999 Ford F250 Regular Cab
Brake Lights Out
Hi welcome to fixya.com
Try putting on your flashers,and see if they come on.
Sounds like a loose groung wire usually green.They need to contact bare metal.lots of times they just need retighting.
Dec 13, 2008 | 2006 Hyundai Sonata
Need new power cord
any one will work, just make sure to groung the cord
Jan 06, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Magic Chef CEL1110 Electric Kitchen Range Logo
64 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
