Question about Sony Handycam DCR-TRV110 Camcorder
Playback When playing back either through a monitor or on the camera screen I get 3 wide horizontal bands. I have tried a claning tape but with no success. Any suggestions?
  • Tony Baker Apr 17, 2007
    Thanks for coming back so promptly. Will give it a try otherwise will fit new video head.
    Kind regards
    Bakes
  • Robin Bennett Nov 18, 2007
    I have exactly the same problem on a DCR-TRV110E. Does the E make any difference to the part number for a new head?
    Sergeant:
    Champion:
  • 326 Answers
Hello, after the cleaning try to record and then check the new recordings. If there is no change (3 wide bands still present) the video head is malfunctioning. The part number is: A7048938A Best regards, Arpi
Posted on Apr 17, 2007
SOURCE:
On the Sony DCR-TRV320E video camera I get two wide horizontal bands on playback and the audio is intermitant. What is the cause?
Having used a cleaning tape several times to no effect. I then went to record, to see if the bands appeared in recording mode. They didn't. So I went back to playback mode and the bands had disappeared.
Jan 28, 2010 | Sony Video Cameras
Gray horizontal lines in video playback
dear ,
i Jasdeep working in superb broadcast as an lengineer .and for this problem i can suggest u the following things :
1. Play back the cleaning tape for 10 sec. only then use it.
actually this problem occurs when the head get clogged (i.e, dirty ) it REC. only single band and shows the same in play back too.
Jun 27, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
I have a Dell 17" LCD monitor with a horizontal band.
You would better served replacing monitor you can buy one for about $100-$120 dell if you lie has one for $99
Mar 01, 2018 | Dell Computers & Internet
Black bars on zr300
Cleaning Tape did the trick. Thanks!
Andy
Mar 30, 2009 | Canon ZR300 Mini DV Digital Camcorder
Horizontal lines on display but firewire and SD card work fine
Hello people who face similar problems...
First confirm whether it is a problem with the head assembly/ dirty heads.
Do the symptoms appear only on the camcorder's internal TFT side display or is it visible on an external monitor (connect using the AV cable supplied) and the EVF(electronic view finder) also.
If it is visible on the EVF, TFT Side display and the external monitor then it is definately a case of Bad video heads or the tape guide requires to be aligned or calibrated
Dec 18, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Playback
That's dirty video head! Try to playback new tape for five minutes, do it for 2 to 3 times, this will serve as your videohead cleaner. eject then reinsert then playback, eject again for at least 3 to five times. most camera has a built in videohead cleaner that activates during eject, initial play and reinsert mode. you can even try to play the whole blank tape! thats 1 to 2 hours of playback! If the problem is still there after doing those things, you need pro fix then.
Sep 13, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Grey bands horitontally in LCD screen
Hello, please try to clean the head with mini DV tape cleaning cassette. Best regards. Arpi
Jun 17, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Black bands and skipping in playback
Thank You Guest, this this solution is helpful, I clean the head with alcohol and the problem is solved.
And thanks for FixYa for the technical support.
Apr 02, 2007 | Panasonic NV-GS11B Mini DV Digital...
Wide Horizontal lines on playback
Wide bands in the playback video indicate a clogged or defective video head assembly. If your cleaning tape appears to resolve the problem, the heads are getting contaminated. I would not use the same tape in this unit. Try cleaning the heads and then use a brand new tape to avoid clogging the drum assy again. If this does not resolve the problem, the drum assembly will have to be replaced. Hope this helps. Joe Weibel customelectronics.org
Feb 19, 2007 | Sony DCR-HC26 Mini DV Digital Camcorder
Sony Handycam DCR-TRV110 Camcorder Logo
280 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
