SOURCE: GE Spacesaver JVM 1651 Not heating, making burning smell
Fisrt, check to be sure your missing cat it not inside the unit. IF the interior is dirty (splatters, grease, etc.) , it may inhibit the unit from working properly.
SOURCE: GE Profile Spacemaker Microwave - won't heat
Thanks for making your post very detailed and including the model number. That really helps! :)
With the symptoms you
have, I would most strongly suspect a shorted high voltage rectifier
diode or a bad magnetron.
The diode is a fairly
easy & cheap do-it-yourself fix, and the mag will cost more.
If you or someone you
know
decide to look into it, we have critical safety information and
disassembly information at our site, and our link is at our listing here on FixYa.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Here are some links you
or someone you know can use for test help, but read their safety
warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's
probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find
helpful exploded view diagrams and order parts by entering your full
model number here.
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
SOURCE: GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
SOURCE: My GE spacemaker microwave won't heat and makes an unusual sound
I have the same problem on my oven- model JVM1640WB and called an appliance repairman who is honest and reliable (I've used him before). He said the problem is with the electrode, to fix it is roughly $300. He recommended buying a new microwave rather than fixing it.
SOURCE: GE JVM1850CH06 microwave no heat with loud humming sound
With the details you described, the high voltage diode might be shorted( usually HVR 1X). It is connected from the Capacitor and the chassis, or else the capacitor is the one at fault,but not common .
