Question about Pelco DX2000 Series 16-Channel 80GB DVR
I'm looking to hookup the DVR with the PC via A cross-over cable
I recently purchased a Pelco DX2000 16 Ch Dvr, I'm having problems configuring the Dvr to work with the Pc. pelco advise me, to get a cross-over cable, and to ping the IP address listed in the manual. When
i try using the IP address in internet Explore, it does not connect to the main system configuration. Please advise, me how to fix this problem.
I have 2 DX2000's, In order for you to communicate with your pc, you need a Crossover cable, if you have a laptop or computers, connect the crossover cable to that, set your ip address on your computer to 192.168.2.108, (Note: since you never configured it, this would be the default setting). If you have the manual this is in there.,
Another method, if you don't have a crossover cable is to set the ip on your computer to 192.168.2.110 Subnet, 255.255.255.0. its a little more funky, the crossover would be easier, once you get in, then go to the configuration page and setup up the IPaddess for the DX2000, the Gateway to your Router and the subnet mask, once you do this, then you're able to get to it on your network, by typing in http://xxx.xxx.xxx.xxx:8004 .
Posted on Mar 23, 2009
How to hookup audio to home security sys
do you have audio cameras, they don't usually give you the audio cameras with a standard setup, on the back of the dvr there is a plug for audio its either a phono plug or a mic input socket, this can be used in one room or outside depending on the mic you have to buy. you then wire this up to the cctv and have to setup the sound to the camara number.
Jun 24, 2013 | Zmodo dvr-dk41103-1tb cctv 4 ch home...
I have 6 pelco make 5104 dvr connected to a
If all of the 6 DVRs are on the same location (on the same network), and you want to remotely connect (VPN) to that location, you can Endura Enable the DVRs and then VPN to the Primary DVR. (Note that you need to be Endura Certified to use the Endura Enabled feature).
If they're all geographically distributed, you can only VPN into a single unite at a time..
Jul 15, 2010 | Pelco Video Recorder
Problem setting up Network Cameras
on the cameras them self there should be a adress and baud rate setting this should be the same as what you have on the software. also the cable that you have going back to your ethernet panel cannot be by any electric lighting or anything like that and check and make sure that the connetors that plug in to the panel have the right color code. you need to look for the straight through wiring diagram 568b. hope this helps.
Nov 11, 2009 | Pelco DX3100 Series 8-Channel 120GB DVR
I have a problem with the HDMI hookup. The sound
I've come across issues in the past where low quality hdmi cables can cause issues like this. When they were upgraded, the problem was resolved. With having you switching the cables, I wanted to make sure that the audio and video output of the dvr was functioning correctly, which it seems to be. I don't think that you have a problem with either the TV or the DVR. There is a term known as the "HDMI handshake" between 2 components that are connected. Where the DVR isn't even aware that their is a problem with either intermittent audio or video to the TV. It's just that communication via the hdmi cable causes the TV to keep trying to interface with the DVR if it "senses" any inadequacies in data transfer from the DVR. I am not sure what quality hdmi cables you are utilizing, but a higher quality pair will hopefully suffice to resolve the issue. Just a suggestion.. Try finding cables online, such as ebay. You will get a much better deal on them. I hope this information is of some help, despite sordid rambling..lol. If you have any more questions, feel free to contact me. I would be more than happy to assist you in any way possible. Good luck!
Nov 02, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a 500GB WD My DVR Expander that is connected via an eSATA cable to my Scientific Atlantic Explorer 8300HDC DVR. It was working great for several months, but recently my recordings are bad. The video...
What happens if you move the DVR off your Sony TV and put it onto your wife's TV (swap DVRs). Does the problem follow the DVR?
If it does, then you are looking at something common with the DVR, since the expander appears to work just fine on another dvr. If it problem doesn't follow the DVR when swapped, you may be looking at a ground loop issue.
Ground Loops occur when different devices are plugged in at different points. Ideally, everything should be plugged into the same power strip, or wall outlet. But, when things are plugged into different points, noise can pop up due to the difference of electrical potential on the grounds of the equipment, and even the neutral conductors. This can occur even when using an extension cord that is plugged into the same strip. Also try using a different power strip temporarily to see if that improves things as well.
Sep 02, 2009 | Televison & Video
My pelco DVXe dvr display is at minimum not 32 bit cant see pics
boot into bios and set your display for vga mode. At least that worked for me
Apr 09, 2009 | Pelco Home Security
I have pelco dx 2000 dvr of pelco brand i just want to know can i increase the recording days with new high rating hard drive from 90 days to 120 days
yes, on the configuratiion plage, use the schedule to increase the amount of time you want for
1) Sechedule recording
2) motion recording
3) event recording.
Remember, this is all based on the size of your hard drive and the number of camera you have installed.
Jan 14, 2009 | Pelco DX2000 Series 16-Channel 80GB DVR
I'm looking to config a Pelco DX2000 Dvr with A cross-over cable
You can connect it to your PC directly with a cross-over net cable, and you also connect it to your LAN with straight net cable. Type The default address: 192.168.2.108:8004 in your IE after you set your pc address in the same geteway, you will see the user and PW requirement screen. if you can't get this screen,try to reset DVR to default setting. see Page#100 of its manual.
Dec 26, 2008 | Pelco DX2000 Series 16-Channel 80GB DVR
Hd dvr
if you are connecting the dvr via component video cables select the output to 480i and not 480p or other higher formats.the tv cannot support anything higher than 480i. or try using composite video hookup instead.
Jan 29, 2008 | JVC AV-36320 36" TV
Linksys Wireless WRT54G vs. WET54G
For what it is worth, I fhave found streaming video does not function well using a wireless connection. The options of multipale routers will work as long as you configure them as to not have conflicting IP address assignment's via DHCP, and the routers do not have matching IP address's. Never fear all is possible with paticence. BPCS
Jan 20, 2008 | Linksys Wireless-G WRT54G Router
Pelco DX2000 Series 16-Channel 80GB DVR Logo
325 people viewed this question
Top Pelco Televison & Video Experts
Marvin
Marvin
Are you a Pelco Televison and Video Expert? Answer questions, earn points and help others
