Question about Panasonic PT-51HX40 51" Rear Projection Television
Convergence problem. hi!!. sony projection model-kp-57ws510. problem adjusting corvergence,not adjusting at all. we do need technical adjusting setting.
  • 185 Answers
Replace the stk chips
Posted on Dec 26, 2008
I have a Sony KP-57S510 and need to get to the service menu but dont have the remote. Is there a way around using the remote to access it?
On that model I believe you need an original Sony projection remote or one of the "magic tv remotes" that support the convergence function.
Feb 18, 2013 | Sony KP-57WS510 57" Rear Projection HDTV
How do i find out if sony kp/57ws510 picture tube is bad
While the set is prone to bad tubes a double or 3d like image is convergence--this model uses two of the STK-392-560 CHIPS for this.
Go into customer menu and call up convergence--if off and will not adjust in any area of the screen the chips are bad.
May 02, 2012 | Sony KP-57WS510 57" Rear Projection HDTV
Hi,I have sony projection tv KP-57WS510 every subject apears threeple with colorful reflection.What to do? Thanks,Kris
You will have to install a convergence repair kit which will consist of both convergence ICs and the 8 associated pico fuses and the 4.7 ohm resistors will also need to be checked. Your model uses the Sony type 1 convergence kit. If you want to know where you get one they are available from www.tvrepairworld.com they do include the parts and the CD with repair instructions.
Jul 09, 2011 | Sony KP-57WS510 57" Rear Projection HDTV
Hi, I have a Sony KP-57WS510 57 in. Rear
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 25, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
My screen accidentally got broken but TV was working fine...is there a way to get a replacement screen? can I buy the materials to do it myself?
Sony KP-57WS510 has 3 layers front screen and I do not know what layer is broken. Part number of all 3 screens are as follows.. count it as front, middle and rear screen layers..
4-090-881-11 SCREEN (57), CONTRAST (KP-57WS510 ONLY)
4-095-924-11 PLATE (57WL), DIFFUSION (KP-57WS510 ONLY)
4-081-950-11 PLATE (57WFV), DIFFUSION (KP-57WS510 ONLY)
Also check HERE for your TV screen.
Aug 04, 2009 | Sony KP-65WS510 65" Rear Projection...
Sony kp-57ws510 convergenece prblem
You didnt replace the STK's? You must replace the convergance IC's or you will continue to have this problem.
Sep 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
How do i dissassemble the board which has the stk392-560 ic
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Sep 11, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
No sound Sony KP-57WS510
Brain Freeze ! Sometimes the microprocessor locks up...
you may need reset = unplug ac cord, wait, then try again..
..........T.
Jul 01, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
3D picture stlye Samsung SP55W3HFX
Hi Ross, This repair is quite easy, But before I tell you how to fix the problem I need to know have you gone in to the user menu & tried adjusting the convergence This will save time & expense for you ? If you havent then try this first it may sort it out without needing to dismantle the set. Let me know how you get on by either replying to this post or let me know via email dyson@gawab.com Chris..
Oct 06, 2007 | Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-57WS510 57 in. Rear Projection HDTV
hi. if the rolling is slow that mean you have a fault in the vertical and sync seperate part of the tv and need a technical support to slove but if it is fast yo can set it up with the vertical hold knub in the back or you have to open the back cover carefully that if you know how to do that but be carefull tv is a dangerous set hazard , look for the vertical hols variable resistor and fix it to stup rollinf for the sound fault , if you hit the side of the tv does it comes normal ?/ if yes then some part need to be resolders dried up soldering pin
May 05, 2007 | Sony KP-57WS510 57" Rear Projection HDTV
Panasonic PT-51HX40 51" Rear Projection Television Logo
44 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
