Question about Hitachi 43UWX10B 43" Rear Projection Television
Brightness I have a Hitachi 43UWX10B and noticed suddenly that the picture looks dark. The default setting is '50' so I increased it to '100' and the picture looks normal now. Am I looking at an expensive future fix or is there something I can try to alleviate the brightness issue?
    President:
  • 1,284 Answers
If you want to attempt the repair the fix for most Hitachis going dark is to remove the front panel and get access to the 3 CRT's (picture tubes) Then one by one with the set off and unplugged, remove the CRT boards from the CRT's and blow out the sockets with compressed air. Once all three are done cover it all back up and reapply power and 99% of the time your picture will return to normal.
Posted on Apr 18, 2007
Dark picture even after new lamp was installed
Reseat all connectors that you removed then try once more. its a back light problem reseat back light once more.
Oct 15, 2012 | Hitachi 50VG825 50 in. LCD HDTV
Samsung dlp 1080p picture is dark and brightness control is at max
I am hoping somebody will answer this because my TV is dark and I played with the controls and it is still dark!
Sep 24, 2012 | Samsung HL-S6187W - Rear projection TV -...
Screen is Extremely Dark!
Good Day, Cary;
PICTURE IS DARK WHEN OSD CONTRAST MENU ADJUST LEVEL CHANGES.
Cause: SHORTED ZD-309.
Also, increase Screen controls at front of TV and see what pix brightness does . Hopefully you did check brighteness & contast levels. When adjusting Sreen controls set contrast control at about 90% and brightness at about 50%.
Good Luck, big IRISH.
Aug 20, 2008 | Hitachi 53UWX10B 53" Rear Projection...
HITACHI ultrascan hd tv....
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 24, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Problems with brightness on the hitachi 50v810
Yes, they dim as they age, and you've done well to get 3 years out of one.
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy.
Jan 02, 2008 | Hitachi 50VS810 50" Rear Projection HDTV
Screen going Black
Hi, does it go dark immediately at turn on or after it has warmed up? BMW Rider
Dec 02, 2007 | Hitachi 50DX01B 50" Rear Projection...
Dark , blurry picture
MTNESTR, My guess would be the FBT loc.TH01(flyback transformer) Hitachi p/n#BW03004 which would be far less expensive than replacing the entire deflection board... A shop could ring test the FBT to confirm the failure. I do know the FBT in this unit has an internal resistor that is prone to failure. It is in-line with the focus block and if it's open it would explain the blur and lack of screen voltage to light the crts properly. The deflection board is about $290-$350 plus shipping and a FBT is somewhere between $60 - $90 depending on the supplier. Hope this helps! Bill
Jun 04, 2007 | Hitachi 46F510 46" Projection HDTV
Strange Image Flubbering/Convergence Problem, Flutters From Dark Picture To Light Picture.
you "tooled around with the convergence board" well this chassis has several problems if the convergence doesnt hold replace both stks resolder around that area per tosh tech bulletin the bright problem is probably the hyper module all toshs should be checked with toshiba website to see if they were part of the recalls for power supply caps
Nov 30, 2006 | Hitachi 50UX57B 50" Rear Projection...
Running out of Brightness
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 23, 2006 | Hitachi 53SBX59B 53" Rear Projection...
Bad picture
convergance ic bad
Oct 26, 2006 | Hitachi 57SWX20B 57" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
85 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
