Question about Dell Inspiron 1521 Notebook
Possibly corrupt I have a dell inspiron 1521... And my screen went blue one day statin stop: c0000221 bad image checksum ... The image url.dll is possibly corrupt. the header checksum does not match the computed checksum.. what does this mean
Stop c0000221 bad image checksum image
Try loading in Safe Mode and disabling as many Startup programs is MSCofig as possible. You could also try rolling back with System Restore, again in Safe Mode. From there try uninstalling any software that was loaded prior to the problem.
Another route is trying to load Windows on top of its self as to correct any corrupted files. Then try testing your RAM one DIMM at a time, one slot at a time to eliminate bad RAM.
Finally a clean install may be required, then going back to RAM isolation if occurs with a clean Windows setup.
May 28, 2013 | Dell Inspiron 1100, PP07L Series Laptop...
Compaq Presario 2500 stopped loading windows XP with a prompt STOP: c0000221 {bad Image Checksum} The image COMCTL32.dll is possibly corrupt. The header checksum does not match the computed checksum.
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start control panel date and time you can make your adjustments to the date and time from there also right click on the date and time on the bottom toolbar (bottom of screen) you should see Adjust date and time tab
hope this helps you
Sep 09, 2011 | Compaq Presario 2100 and 2500 ,NX 9000...
Laptop: Toshiba Satellite NB200.Problems when restart after upadated antivirus (kaspersky 2010) this message appear: STOP:c0000221 [bad Image Checksum] The image urlmon.dll is possibly corrupt.the...
Yes it may be possible, installing and updating antivirus may have figured our corruption in urlmon.dll deleted the file or did some changes due to which you are getting the critical error
You can try 2 things,
1. Restore earlier settings, which may uninstall your antivirus and you need to install again. But if this works recommend you to first scan the system with free standalone antivirus availalable and then install your version of antivirus. Try following link
http://go.trendmicro.com/housecall7/HousecallLauncher.exe
http://www.trendmicro.com/ftp/products/rootkitbuster/RootkitBuster_2.80.1077.zip
2. Repair the URLMON.DLL file
1.Insert your Windows XP CD in your CD-ROM drive and boot your computer from the CD.
2.When the Welcome to Setup screen appears, press R to open the Recovery Console.
3.When prompted for an administrator password, type the password and then press Enter. In case no administrator password was set, just press Enter.
4.At the Command Prompt, type the following command and press Enter
cd %systemroot%\system32
5.Next, type the following command to rename the urlmon.dll file and press Enter.
ren urlmon.dll urlmon.old.dll
6.Now, to restore the original urlmon.dll, type the following command and press Enter.
expand [CD drive letter]:\i386\urlmon.dll %systemroot%\system32 /Y
7.Next, type exit and press Enter.
8.Restart your computer.
3. Repair complete OS. You will need XP CD
Boot from CD and follow the instructions to repair the OS
May 20, 2010 | Computers & Internet
My laptop wont load to Windows XP when it tries to I get the following message. STOP:c0000221 {Bad Image Checksum} The image shell32.dll is possibly corrucpt. The header checksum does not match the...
your windows is surely corrupted.. install your windows again... if you dont know how to install your windows...contact me....at (bharat_s@ymail.com)
please vote for me...im sure this will solve your problem...
Sep 26, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
Help
Greetings,
When you upgrade your computer to Windows XP, you may receive an error message that is similar to one of the following: C0000221 (Bad Image Checksum)
-or- STOP: C0000221 - Bad Image Checksum in ModuleName
-or- STOP: C0000221 - Bad Image Checksum. User32.dll is possibly corrupt. The header check sum does not match the computed check sum.
Please go through the below mentioned link:
http://support.microsoft.com/kb/326687
Sep 20, 2009 | Microsoft Windows XP Professional for PC
STOP: c0000221 {bad image checksum}
You most likely have bad RAM. If you have two chips, pull one out and run the laptop on a single stick. You may need to alternate the sticks just incase the non-working one is the one you left in the laptop.
May 19, 2009 | Computers & Internet
Dell laptop won't boot even after clean install of xp
your windows prolly crashed because your hard drive is going bad, and thats why your getting error messages when reinstalling.
Feb 26, 2009 | Dell Inspiron 1150 Notebook
Blue Screen
Try re-starting your pc and tapping the F8 while it starts up and try getting in through "Safe Mode". If you can get in click "Start", "Run" and type "cmd". Hit OK. At the dos promt type "sfc" and let windows check your files.
Apr 10, 2008 | Toshiba Satellite A105 Notebook
Dell Inspiron 1521 Notebook Logo
443 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
