Question about Garmin iQue M5 GPS Receiver
IQueM5 - Screen issue/question
I dropped my iQueM5 onto the concrete road and the screen display seems to have got screwed up! LCD is fine. In the display, I see some lines slightly above the bottom right corner. Few resets have not changed anything! I did search some forums and saw some notes about LCD and Digitizers (not aware what that is). Worst part - my warranty is over! Saw that Service for an out-of-warranty iQueM5 is $175 (unbelievably expensive)...I just cannot afford that! Is it possible to find the broken part and fix it myself (or at a local service shop)? Please advice me of any way to get this fixed for a reasonable cost! Thanks in advance!
  • 3 more comments
  • rkay notes Apr 19, 2007
    Guys... does that mean there is no other way apart from shelling out $175?
  • rkay notes May 01, 2007
    Thanks for the suggestions.
    1. No solutions found there
    2. Attaching the photo of monitor
    3. No, all I see couple of skewed lines
  • rkay notes May 06, 2007
    Tom, did you see the info I provided for your questions. Thanks!
  • absgps Jul 19, 2008
    I didn't drop my iQue m5 and I have the same issue. It was working great one day, and then completely inoperable the next. The gps still works with activesync (I can tell it's sending and receiving data), but it does me no good because all I see is a bright white screen with lines through it (looks exactly the same as the screen photo the other user attached). I've checked the battery, pulled it in and out, removed the SD card... nothing changes the screen. Help!
  • macedancer Sep 07, 2008
    I have not dropped my iQue M5 and have the exact same problem. Almost identical to the latter image. I can't find any help in the manuals either...help!
    Thanks!
  • 1,141 Answers
First of all check out this manauls perehps you can Find a soultion there https://buy.garmin.com/shop/store/manual.jsp?product=010-00344-00&cID=165&pID=246 2nd, if you can post a Photo of the monitor and the lines that you speak about perehps somone will understand it better 3rd, Can't you see anything in the monitor?
Posted on Apr 30, 2007
The screen will not come on
Screen is probably damaged. Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
Mar 28, 2012 | Twinhead Durabook N15RI-2 Notebook PC
Tip
How to replace a defective LCD screen in a Kodak V803 Digital Camera
This tip is for Kodak V803 cameras that will take pictures fine but you can only be able to see them if you download them onto a PC.
A replacement screen can be easily ordered and replaced. Call Eastman Kodak. Their parts department can be reached at (800) 431-7278 ext 3. Tell them the model number of your camera and tell them you want to order a LCD screen for it. The cost of the new screen is $31.00 + $15.00 shipping. Don't let them talk you into sending it back for repair. You are looking at a repair bill over $80.00.
To replace the screen, remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock the connector and allow you to remove the flat ribbon cable from the black connector.
Remember the orientation of the old screen and its cable as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place.
Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard.
Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera. These cameras are well known for LCD screen failures due to shocks and drops.
on Jan 25, 2008 | Kodak V803 Digital Camera
I'd dropped the laptop and the screen had cracked, replaced the screen and it switches on fine but it is a completly white screen now. I have done some various research and it seems it could be down to a...
Its a possibility that it is a loose connection, I would clean the connection, and re-seat it. If this the problem persists, then the drop most likely damaged the mainboard. You could test this by plugging in an external display, if it does the same thing as your replacement display, then your mainboard has an issue. If it does work, the replacement screen is faulty.
Mar 03, 2011 | Computers & Internet
My bold has a white screen with a couple black lines going vertically and a black circle/blob in the top right. The phone was never dropped and has no crack in the screen. Please try and help restore to...
You don't have to drop your phone to crack / break the screen. This problem is almost certainly caused by a crack screen. This can be easily repaired by taking your phone to the local repair shop and getting the LCD replaced.
Depending on where you live and who you know you can get this done for $50 - $100 in North America.
Oct 12, 2010 | RIM BlackBerry Bold 9700 Smartphone
Camera Screen
The following procedure works on the V603. It uses the same LCD screen as the V803 & V1003.
It would appear you have a damaged LCD screen. The same problem happened to my daughter's V803. The camera will take pictures fine but you will only be able to see them if you download them onto a PC. A replacement screen can be easily ordered and replaced. Call Eastman Kodak. Their parts department can be reached at (800) 431-7278 ext 3. Tell them the model number of your camera and tell them you want to order a LCD screen for it. The cost of the new screen is $31.00 + $15.00 shipping. Don't let them talk you into sending it back for repair. You are looking at a repair bill over $80.00. To replace the screen, remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock the connector and allow you to remove the flat ribbon cable from the black connector. Remember the orientation of the old screen and its cable, as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place. Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard. Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera. These cameras are well known for LCD screen failures due to shocks and drops.
Good Luck!
- Jim
Jan 25, 2008 | Kodak EasyShare V603 Digital Camera
Kodak V803
It would appear you have a damaged LCD screen. The same problem happened to my daughter's V803. The camera will take pictures fine but you will only be able to see them if you download them onto a PC. A replacement screen can be easily ordered and replaced. Call Eastman Kodak. Their parts department can be reached at (800) 431-7278 ext 3. Tell them the model number of your camera and tell them you want to order a LCD screen for it. The cost of the new screen is $31.00 + $15.00 shipping. Don't let them talk you into sending it back for repair. You are looking at a repair bill over $80.00. To replace the screen, remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock the connector and allow you to remove the flat ribbon cable from the black connector. Remember the orientation of the old screen and its cable as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place. Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard. Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera. These cameras are well known for LCD screen failures due to shocks and drops.
Good Luck!
- Jim
Nov 25, 2007 | Kodak V803 Digital Camera
LCD display cracked
You can replace the lcd screen although you do need to be careful. You camera has a flash capacitor that contains 300 volts and if you short it out you can easily fry the camera circuitry. You can check on ebay for an lcd or call fuji usa. I will warn you though their parts department isn't the most helpful.
Nov 13, 2007 | Fuji FinePix A303 Digital Camera
Nintendo touch screen
Have you dropped the DS? It could be that the ribbon cable on the bottom LCD has come adrift.
Does the top screen display the Nintendo logo when switched on?
Oct 24, 2007 | Nintendo DS Console
Garmin iQue M5 GPS Receiver Logo
101 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
