Question about HP Pavilion DV5234US Notebook Laptop
Laptop won't turn on
My laptop won't turn on, but it tries repeatedly.
when I turn it to look at the bottom, it then turns on.
Might there be something loose?
Can any one help me?
    Problem Solver:
  • 9 Answers
The reason your laptop wont turn on is most likely because of a boot error....and when this error occurs you usually get the infamous "blue screen of death" but this screen is not as bad as you think.  it tells you what happened and what is messed up on it.  and you do not see this screen because one of your settings are probably set on auto-restart.  the best way to fix this problem without losing any data from re-installing the OS is to boot from a live CD and from there you can check the event viewer and therefore fix the problem.  voila!!!
Posted on Mar 11, 2009
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
My HP Pavilion dv6830US Notebook overheated and now won't turn back on. What can I do?
I would start by cleaning the fan, vents and heatsink. Use a can of compressed air. You may have to open the Laptop to clean thoroughly with the air and a light brush, use ESD protection as well. . Improve air flow from the bottom of the laptop and the side vents, a Laptop Cooler is a option. Hopefully you haven't done damage to vital components due to overheating. Unplug, remove battery, leave battery out, plug in, try to reboot.
May 26, 2013 | Computers & Internet
Monitor button flashes and repeatedly clicks but won't turn on screen
Tell me where on a laptop is a monitor button, first
Post back in a Comment
Regards,
joecoolvette
Mar 08, 2013 | Computers & Internet
Blue screen and won't turn on
Unplug, remove battery, plug in, reboot. If that fails repeat process and do a system restore/recovery.
Dec 14, 2012 | Toshiba Satellite L455S5000 Notebook
My acer laptop screen won't turn on. The entire
It sounds like either your Lcd data cable loose or graphic card fried from excess heat. If you feel excess heat at the bottom of your laptop near the fan ventillation, then most probably it is graphic card. A chiplevel technician can repair your laptop. Don't try any repair if you are not a technician. Any repair without proper knowhow will kill your notebook for ever. Hope i helped you
Dec 01, 2012 | Computers & Internet
I was refering my laptop an when I shut off I turn on an it starts like to turn on that processes but that's it won't do noting else its a toshiba satellite
Your statement is a bit confusing. Try thi,s unplug AC, remove battery, replace battery, plug into AC outlet push on/off button start normally. If that fails repeat and at boot repeatedly tapping F-12 to enter restore/recovery.
Nov 08, 2012 | Computers & Internet
Toshiba laptop L505 won't turn on
Remove main battery and turn on, next! check the power supply for correct voltage, if okay! sub the ram out one out a time and power on and repeat. If still no result, the DC jack in the laptop is a common issue, suggest a professional to assess.
Mar 13, 2012 | Toshiba Satellite L500 Series Notebook
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
How do I turn off screen on laptop when I am watching Netflix on tv
Hi, connect your tv to your netbook, once connected, hold down FN (bottom left of your keyboard) then press accquired F button (top of keyboard). Ie on my laptop its FN and F5 together. This will turn your laptop screen off while you watch Netflix on your tv. To turn screen back on once finished, repeat the process. Hope this helps and please rate,, thanks
Mar 12, 2011 | Sony VAIO VGN-FZ240E/B Laptop
HP Pavilion DV5234US Notebook Laptop Logo
51 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
