Question about Acer Aspire 5100 Notebook
When I power on my acer 5100 ot beeps three times and stays on.
Please Help
In a lot of laptops 3 beeps on post check during boot up means an issue with either internal memory or the memory sticks in the laptop. If you know how to take out the memory sticks that is the first thing to check. To do so locate the memory sticks. Before taking them out make sure you are in a as static free environment as you can be. Idealy you can use a wrist ground strap to ground yourself to the laptop to eliminate any possible static built up in your body from discharging into the memory stick and possibly damaging it but I have changed many and never used one an never had one fail.
I try to do it in a non carpeted room. Remove the battery and make sure it is of course unplugged. Also after unplugging and removing the battery I hit the power button so if there is any stored energy inside the motherboard it will discharge in a way. I have a sager with such huge capacitors in it it actually momentarily lights up the power on led when I do this so yes there can be trapped energy so I reccomend this step. There are two tabs on either side of the memory stick that you carefully push outward and this allows the stick to release (pop up) evenly pull it out of the socket. Using a clean eraser lightly rub the gold contacts to clean them if they seem dirty. Shouldnt be on a laptop that new but never know. Make sure no eraser residue is on the stick and put it back in the slot and push down till locks back into tabs.
Try booting up the laptop if this doesn't work try using only one of the two memory sticks at a time to test if only one of the two is bad. If this does not work than if it is a internal memory problem you will have to have it serviced.
If this does not solve it then you could try removing one at a time and booting after removing the wireless card, cd/dvd (optical drive), hard drive, modem or memory card reader board ect. ect. but some of these may take a bit more experience to remove for some.
I am only self taught at laptop repair but I am no rookie to electronics either so hope this helps.
Posted on Dec 26, 2008
Hi i have a acer aspire 5100 on turn on i get 1 long beep and 2 short beeps.the fan is on and i can open cd drive but nothing on screen i took the ram out and that stoped the beeps but still no screen help...
Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.Video (Mono/CGA Display Circuitry) issue.Try to disconnect/connect the video card. If nothing happens, there's a possiblity that the problem is with the LCD cables or the LCD itself.
Hope this will help...Your response is very much appreciated...
Feb 06, 2011 | Acer Aspire 5100 Notebook
Acer 5100 hangs after desktop
this beep sound is geneally is due to the faulty ram.try having a loook at it.
Sep 10, 2009 | Acer Aspire 5100 Notebook
My acer aspire 5100 hanga after desktop and has a long continuous beep, please help??
Sounds like a bad key on your keypad. Try taping all keys, one at a time, to see if the beep goes away. If this fails to resolve the issue then it is probably a bad motherboard that will need repair or replacement.
My acer will power and then beep 3 times is this a hardware probl
Try removing the ram , if more than one stick, one at a time. Or try reseating the Ram.
Dec 26, 2008 | Acer Aspire 5100 Notebook
Won't stay on
sounds like fans are going bad. if you can open the bottom side where the fans are located you can replace it. plug in.
Dec 19, 2008 | Acer Aspire 5100 Notebook
No display on acer 5100
hiiii ther
how r u ??
the beep u got is the motherboard diagnose for error in the video card
so even if u try an external screen it won't work
so if that ur VGA card is built in
u have to buy a new one
but 1st u should try this try to unhooke the card and clen it and hooke it back again and se what will happend if u get the beep again than it's dead my friend sorry
u take careand have fun
salammmmmmmm {bye in arabic}
Nov 20, 2008 | Acer Aspire 5100 Notebook
Boot problem
You would need to note whether the 8 blinks are in a specific order; this is probably equivalent to beep codes and the spacing (grouping) of the beeps/blinks may tell you what problem you are having (other than having clumsy buddies).
Check to see if they are grouped in some recognizable manner such as 3-3-2 and then you would have to check with Acer to decode the sequence. Depending on whose BIOS is installed in your model, the 8 blinks equally spaced may be valid too and tell you the nature of the problem..
An example of the 'beep' codes can be seen here, midway down the page:
http://www.techsupportforum.com/hardware-support/laptop-support/163870-acer-aspire-5100-three-beeps-no-screen-boot.html
Oct 18, 2008 | Acer Aspire 3680 Laptop
Acer aspire 5100 - screen is turned off, cant turn it back on
The bios beep codes indicate the video card is not working, so you won't see anything on the screen.
Your video card is either dead, or is not contacting the board correctly.
If you are keen to open it up I will offer instructions to assist you. But in reality, your safest bet is to take it to a laptop shop and get them to do it. There are a lot of tiny screws in these things.
Apr 17, 2008 | Acer Aspire 5100 Notebook
Acer aspire 5050 - beeping laptop
i think your bios setup changed.
press key with which u enter bios setup.
then load default settings and save it
then restart pc.
Mar 21, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
130 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
