Question about Rinnai RHFE-556WTA Direct Vent Heater NG Air Conditioner
Stops working and flashes 53
Unit stops working and flashes the number 53.
Turning it on and off will fix this, but if we are out or late a night the
apartment will get verr..rrry cold.
This has happened half a dozen times. help
  • 700 Answers
You need to check the re=turn air filter and kmake sure that its clean/. Basically it shuts down the ignitor due to high outlet air temperature. Stay Warm!!!
Posted on Dec 26, 2008
Tank is full, but after a few minutes why does it stop and the 'Tank Empty' light comes on?
Reset light comes on, unit stops operating when tank is full ...
www.fixya.com/support/t384577-reset_light_comes_unit_stops_operating
Feb 6, 2008 - Question about Vicks Warm Mist V745A 1 Gallon Humidifier ... Tank is full. ... for about another 5 minutes when the unit stops, reset light comes on etc. ...the humidifier since the reset light keeps going on immediately after I turn ... water in the tank because of course, the heater is on, but no water is getting ...
How to Fix a Humidifier ' HomeTips
www.hometips.com/repair-fix/humidifier-doesnt-work.html
Jan 17, 2016 | Humidifiers
Mitsubishi air conditioner flashing timer light flashes twice
Switch the polarity of the control voltage...make sure it matches with the indoor & outdoor unit
Dec 18, 2013 | Mitsubishi Heating & Cooling
Won't final spin ?
What is the model number of your unit?
Nov 04, 2012 | Washing Machines
Sony Bravia KDS-55A3000 while watching last night screen went black as if someone turned the TV off when attempting to turn it back on the the power indicator light flashes green repeatedly stops then a...
It sounds like the lamp has failed. It is advisable to use a genuine Sony lamp. The part number for is XL-5200. It will cost around 180.00. That should fix you problem. If you cannot find the lamp local to you can order it form Sony at.
1800-222-SONY
I hope this help,
Skyassoc
Dec 15, 2010 | Sony KDS-55A3000 55" HDTV
When turning on joystick control the chair moves but when i stop the lights start to blink and stops moving horn works if i play with the on/off it start to works agian
fantasy when it stops count the number of flashes. For example it might flash 5 times pause flash 5 times pause etc. This is the flash code and your manual will give you what it means. Being an intermittent problem can be a bear to trouble shoot. It would be nice to know what chair you have and whether Medicare purchased the chair for you. If Medicare purchased the chair then they will pay for most of the repair cost Hope this helps you
Sep 10, 2010 | Health & Beauty
Weather King 13AJA36A01 AC freezing up at night
check the inside coil is dirtyor may be low on freon
May 14, 2009 | Weather King 12AJA4801AH Air Conditioner
Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
Apr 10, 2009 | Kenmore 15762 Dishwasher
Left turn signal stops flashing when brake pedal is depressed.
there is a ground problem, most likely in the tail unit itself, but a ground problem is hard to find and easy to fix. reground the system, the turning unit, and the problem should stop. About the hazards, I don't know...... some times in older cars, that is the way it works. because the brake and hazard element in the bulb is the same and the old cars used a break in the power, but the new cars use a break in the ground. any way, chase the ground down first, it is usually the cause.
Feb 12, 2009 | 1999 Jeep Wrangler
Indesit WIL103 flashing lights problem
because of the short time this runs then stops, there could be maybe 3 faults, 1 check water inlet valves and supply for water flow 2 check for any motor action (use another programme) 3 check heater element for open circuit number 1 or number 3 sounds most likely hope i have helped, if so rate me please
Sep 25, 2007 | Indesit W 123 Front Load Washer
Rinnai RHFE-556WTA Direct Vent Heater NG Air Conditioner Logo
391 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
