Question about LG LRBN20510WW Bottom Freezer Refrigerator
Top of the freezer will freeze but bottom want
Top freezes well but the bottom dosen't get cool and theirs water build up in the bottom part
  • 3 Answers
Could be same as problem I just fixed.
Remove back panel inside freezer and
1. check fan operation
2. check for ice/water at bottom of the hidden section. There should be a drain hole, which may be blocked by ice. Fix by turning off and pouring boiling water in there until blockage is fixed
See http://www.fixya.com/support/t1507330-ice_collects_in_bottom_freezer
Posted on Jan 26, 2009
Bottom of freezer freezing bottom of frig cooling top of freezer and top of frig not cooling or freezing
I'm thinking you have a Bad fan. Not circulating air? You should hear the fan running when you open the door.
Feb 13, 2018 | Refrigerators
Why is Whirpool WRT111SFA 10.7 cubic feet not auto defrosting?
Hi Karen,
my name is Roger and i'd be glad to help you, most likely one of the components of the defrost system has failed. Or the drain got clogged and water is backing up and freezing over the air flow grids, inside the freezer.
Empty it and check the bottom of the freezer and back wall for ice build ups.
hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/roger_e8672cfe67bf61a1
May 31, 2014 | Whirlpool WRT111SFAF 11 cu. ft. Top...
Top of freezer not freezing
your cooling matchine get damaged,there having a cooling matchine.
Mar 25, 2013 | Daewoo FRSU20IA Freezer
I have a top freezer/bottom refrigerator-6months old-no icemaker hooked up. There is water dripping continuously into the refrigerator compartment-some of it freezes and the rest accumulates in the...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 17, 2011 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
Water dripping in the refrigerator and freezes on the top shelf. It seems to be coming from the freezer compartment. There is a square piece of metal missing from the top of the main compartment. One can...
Removed everything from the freezes. Removed a false bottom from the freezer floor, 2 screws. There was an ice build up under this plastic bottom. I let the ice melt with the de-frost cycle (or frost free cycle). No more water dripping into the refrigerator compartment.
Dec 15, 2009 | Whirlpool Refrigerators
Fridge/Freezer - fine bottom half, warm top half
Sounds like the fan in the freezer is not working ( pt# WR60X190 ) .
Jul 30, 2009 | Refrigerators
Refrigerator and freezer cools at bottom, but not at top.
first thing to check for is your fan running if yes than does your freezer freeze enouht to freeze water if not you need more gas or should i say freon possible freon leak thanks from gilles
Jan 20, 2009 | GE GSS20IEP Side by Side Refrigerator
Fan keeps freezing
HI .did you pull the fridge, away from the wall, and clean out the drain tube ,at the back. if not pull fridge away from wall, find the drain tube, and clean. thanks the appliance doc
Aug 04, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
LG LRBN20510WW Bottom Freezer Refrigerator Logo
112 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Mike
Mike
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
