Question about Microsoft Xbox 360 Console
How to hook an xbox 360 to direct tv
I have an xbox 360 with the 3 tv and 3 hdtv cable adapter, my problem is; i can get the xbox to turn on, but i cannot get the direct tv to do anything. i donot have a hdtv, just a normal tv, I have tried to attach the non hd cables accordingly by the instruction manual, by hooking it to both top and the bottom plug ins(seperate attempts) and plugging one on top and two on bottom and switched(video on bottom and other two on top) and Ive triend to program the remote for the direct tv, but I cannot figue out what i am doing wrong that i don't see any picture on the tv...Ive even tried putting in a game to see if that was the issue...
can anybody help me?
  • tiamac40 Jan 08, 2009
    Same exact problem. I can get sound but no picture??????
    Habit-Forming:
  • 138 Answers
What do you have coming out of the xbox 360, HDMI or RCA? The same question for the direct tv?
Posted on Apr 04, 2017
sandrew
  • 2961 Answers
SOURCE: HDTV Problem
there shouldnt be a problem with the cable, if you use the component leads then you will not need to use the s video cable for video incase that is what you are doing, component only uses 5 connectors and the switch should be set at HDTV not tv and the tv set at component Use the following colours into your tv:- Green, Blue, Red and the audio red and white, you do not need the yellow or the s video plugs. Then select the 1080i when in the component setings on your tv and do the same in the dashboard settings
Posted on Jul 01, 2007
Joe fix
  • 7 Answers
SOURCE: XBOX 360 no video after playing HALO 3
I just got the xbox 360 for christmas 07. Two days later I bought guitar hero 3 and Halo 3.
Get this...the console is noisy and it scratched grooves into both disks and now the games are worthless...I took this piece of junk back to best buy and they were all out of the console for an exchange...so they gave me money back for the system and instructions in how to get the games replaced through microsoft....its a total nightmare because guitar hero 3 isn't published by microsoft so I have to goto redoctane.com to get a hint as to what I have to do....on top of all this, I can't get the games exchanged for new ones until I have a serial number...
Is Bill Gates serious ?
Posted on Jan 08, 2008
kman203
  • 99 Answers
SOURCE: XBOX 360 Elite RCA video connection problem
On the TV you should have a video, input or mode button. If you press that button while the 360 is on it should pickup the signal. You need to be in video mode instead of cable mode since you are using the red, yellow, white cables. Many TVs have a few video modes so press it wait a few seconds and try again if it does not work. Hope this helps:)
Posted on Mar 21, 2008
Clockwire
  • 72 Answers
SOURCE: no picture or sound on the tv
Hey... I had same problem I opened up the console and found that there was to much heat sink compound and when system had gotten hot it ran onto the component/mobo.
Posted on Dec 02, 2008
SOURCE: XBOX 360 Elite HDMI SOUND PROBLEM
First you have to activate the HDMI audio option in your Sony suround system options so as to activate it. Please try this and then tell me what happens.
Posted on Dec 18, 2008
Phillips HDTV turns off when we turn the XBOX 360 on.
More than likely this is a trigger from the HDMI cable which can be disabled in the tv or xbox settings. To check, hook the xbox up to the tv with RCA cable that is supplied with the xbox and see does it turn the tv off it probably wont happen when connected like so.
Jan 08, 2015 | Philips Phillips 40 in. LCD HDTV
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
How should I hook up my xbox to the back of the television using the red, white, and yellow wires? It is hooked up but I am not getting any audio. Thank you.
First make sure your video cable is set to TV not HDTV
Then plug the 3 RCA cables into the color coded slots on the TV. Make sure you aren't using the red cable from the component RGB but are using the red cable for sound (next to the white one).
Then, if you still have no picture, start the console using the controllers Xbox button and hold "Y" and "RT" until the console restarts. this will reset the video settings on the 360 to default.
Follow this guide if you get confused:
http://support.xbox.com/en-us/pages/xbox-360/how-to/audio-video-devices/connect-xbox-360-console-tv.aspx
and for the video reset about halfway down the page:
http://support.xbox.com/en-us/Pages/xbox-360/troubleshoot/xbox-360-top-issues/tv-or-monitor-screen-is-blank-while-connected.aspx
Mar 30, 2011 | Video Game Consoles & Games
My Xbox elite is just over a year old. I have no red rings. Problem is that all games played on the box are now in black & white. There is no colour on my tv screen. There is nothing wrong with the...
Check and recheck and triple check the av/hd cables. If you want to help isolate, try hooking up your xbox 360 to another tv and doesn't matter if it is hdtv or standard to test out. That method will give your answer quick to help isolate the problem. If you have hdtv make sure your adapter has the switch set for hdtv and not standard and then go in the xbox 360 dashboard system settings and see if it shows up for display. Good luck!!!
Please rate and comment!!!
Dec 23, 2010 | Microsoft Xbox 360 Elite Console
Xbox 360 hdtv connection help!!!
Yes, you will need HDTV compatible AV cables.
Jun 25, 2009 | Microsoft Xbox 360 Console
How to hook up a XBOX 360 to an HDTV
You can go to Wal-Mart or any major electronics store and buy a splitter/selecter for your different devices.
Basically, the unit will allow you to connect a few input devices (xbox, ps3, whatever) into one HD connection on an HDTV. You will be able to select which device uses the HD connection to the tv through a switch.
I hope you find the item :-) A Competent electronics salesman should be able to help you out just fine!
Jun 29, 2008 | Microsoft Xbox 360 Console
XBOX 360
check connections.
e-mail me at B3652@live.com
May 31, 2008 | Microsoft Xbox 360 Console
Xbox 360
Check your AV cables. Make sure all the wires are plugged in and secure. Make sure the switch on your AV adapter is turned to TV, or HDTV, depending on which tv you have. If it still doesnt work, contact xbox customer support at 1-800-4MY-XBOX
Jan 20, 2008 | Microsoft Xbox 360 Console
Xbox 360
Yes I have mine hooked up to a old Tv
Regards
Mick
Nov 12, 2007 | Microsoft Xbox 360 Elite Console
Microsoft Xbox 360 Console Logo
3,916 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
