Question about RCA M4204 MP3 Player
MP3 player freezes on the startup screen
When I press the power button, the mp3 starts up, then freezes on the initializing screen. Now it won't even come on after several power and reset cycles. I'm thinking I'm just being stupid and not charging it, but that screen doesn't come up either.
  • 3 more comments
  • cybergeek94 Dec 26, 2008
    By the way, my computer doesn't detect it on the USB either.
    Oh, and I tried updating the firmware but Firefox says it gets interrupted.
  • blair67156 Dec 26, 2008
    Ours is doing the same thing but it is new
  • mccarty33 Dec 26, 2008
    Same problem. I tried installing it last night and it took forever...when it was done, it wouldn't allow me to finish the download, so I went to bed. I got up this morning and tried again...now my computer doesn't recognize that it is plugged in and I can't seem to do anything with it....
  • Anonymous Jan 13, 2009
    frozen on the initializing screen. can not reset and computer wont recognizw. Also where do i get the firmeare program??
  • 159 Answers
Plug it into the usb device of your computer.
IF you already downloaded the firmware.
You need to go to where its downloaded.
And install it from there.
It will show you your firmware and ask if you want to format your player click yes.
After that is done it will work like new.
Posted on Jan 13, 2009
Player will not initial stays on initializing
Sounds like there is an issue with the firmware. Download the firmware install from here: http://voxrightnow.custhelp.com/app/answers/detail/a_id/2558
Follow the on-screen instructions to perform the install.
Be sure to back up any important media before performing this install.
If your computer does not recognize it, press and hold the play button while connecting the device for upwards of 30 seconds. If that does not work then it is likely the player is unrecoverable.
Oct 29, 2009 | RCA M4204 MP3 Player
How to unfreeze mp3 player
I would recommend you to upgrade your device firmware.
This will fix the issue.
Jul 04, 2008 | SanDisk Sansa e250 MP3 Player
Tip
How to Fix Your RCA Pearl TH1602 MP3 Player from Freezing at Startup
Does your RCA Pearl TH1062 MP3 player freeze on startup at the Pearl logo?
Whenever your player acts up, the best solution is to reflash/upgrade the firmware.
Download the firmware upgrade from http://voxrightnow.custhelp.com/app/answers/detail/a_id/2243/related/1, and follow all the troubleshooting instructions that popup when you start the program:
  1. start the program,
  2. remove the battery,
  3. hold the play button while plugging the RCA player into your computer's usb port,
  4. release the play button when the term "initalizing" replaces "searching",
  5. check the box that says "format data" (you can try it first without this checked, it may work and will save your music),
  6. click the start button to replace the firmware.
This solution will fix your player.
I hope that helps.
on Jan 17, 2010 | RCA TH1602 MP3 Player
Mp3 player freezes at initializing screen
Plug it into the usb device.
Hold down the power button for 10-15 seconds.
Go to the RCA website download the latest firmware and install it.
That fixed mine and a few other people I know that have one.
Jan 09, 2009 | RCA M4204 MP3 Player
Freezing on start up
hi return this cause is defect i know i have one !!!
Jan 02, 2009 | Philips GOGEAR SA6045 MP3 Player
My rca opal mp3 player freezes on the screen where it says initializing when i turn it on?
Go to "http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=2559"
To update the firmware of the M42xx mp3 player click here and download the firmware. start the firmware and when it is runnin plug the M42xx in at the same time holding down the PLAY BUTTON (center) until a white screen with a small computer with a line going to your M42xx is displayed and then release the PLAY button. You can then click on start and the firmware update will complete,,, DO NOT DISCONNECT DURING THIS UPDATE... it may take 2 times to complete this but it will work.... YEA!!!! WORKS with 2, 4 or 8 GB Models.....
Jan 01, 2009 | RCA M4204 MP3 Player
CARL
Nov 07, 2008 | RCA M4204 MP3 Player
Player shuts itself off
There could be a damage or corrupted file in the sansa clip. I suggest to reformat the player. To reformat the player. First turn off the player. Then slide the power switch down it will be showing red, now press and hold the center or the middle button on the player while connecting the player to the computer. It will be detected as a drive on your computer, now right click on it and choose FORMAT, make sure the file system is FAT32 then click start to continue formatting the player. This will erase or remove all the songs on your player but this will fix the problem that you are having
Aug 22, 2008 | SanDisk Sansa Clip MP3 Player
Insignia frozen
the player is confused.. see you might have a lot of songs and with the bluetooth initialized the player cant do every thing at once so it freeze since it is so confused and when it freezes dont keep pressing buttons it gets more confuzed. it happened to me once and i just reset it and it worked. so try not to do every thing at once the player is not a computer.
Jul 20, 2008 | Insignia Sport MP3 Player
GlorEE
if it freezes on start up, after its done turning on hold the power button for 15 seconds.
Mar 08, 2007 | SanDisk Sansa e250 MP3 Player
RCA M4204  MP3 Player Logo
107 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
