Question about Apple AirPort Express (M9470Z/A) 802.11g/b (M9470ZA) Wireless Access Point
Netbook to airport connection
I am running airport for my macs just fine. My asus netbook running windows xp says that the signal is out of range even though it is receiving a healthy signal, The netbook can open other networks signal just fine
  • 2 more comments
  • georgeen7 Dec 26, 2008
    I am not technically oriented. It is important to note that the asus is able to get onto other networks. The base station does not need resetting as three other computers are able to access it without a problem.
    PLEASE give me a step-by-step tutorial to reconfigure the asus settings to work with the current network.
    Also, when changing the wireless setting on the asus, I did get the computer to ask for the password, but it asks for the hexidecimal password which is not needed by the other macs on the system.
    Which adapterdo you mean?
    Atheros AR5007EG IN A ASUS Eee PC SERIES
    Sorry.......Asus Eee PC 900
    President:
  • 2,110 Answers
Try changing the channel on the router and add/removing your preferred network assuming you are using the windows wireless utility.
Posted on Dec 26, 2008
  • 2 more comments
  • Sibananda Jena
    Sibananda Jena Dec 26, 2008
    which adapter r u having for wireless connection
  • Sibananda Jena
    okay just tell me which model of ASUS do u have...
  • Sibananda Jena
    no no which model laptop??
  • Sibananda Jena
    Okay try these steps
    1: Choose "Network" in the Internet option, disconnect it and then delete the Connection in the "Manage".
    2: Click "Create" to recreate the connection, choose "Local Area Network- Wireless", then Next.
    3: Choose "Next".
    4: Select Address Type, and then Next.
    5: Browse Wireless Networks and then choose the one you want to use, choose the mode to be "infrastructure" and the Transfer rate to be "auto", and then Next.
    6: Wireless Channel Settings, choose any channel.
    7: If your AP is using the WEP or WPA encryption, you need to choose "Enable encryption" and then input the Key and Key index, choose Next.
    8: Fill in the Name of connection, then choose Next.
    9: You can choose the "Connect automatically at system startup" or "Start this connection when finished" if you want, and then choose Finish.
Tip
How to connect your wireless computer to the wireless network ?
Connecting your wireless computer to the wireless network:
Make sure the wireless switch is turned on in the laptop, now look for the available wireless Networks in range, select your network name, enter the security key and get connected. You may also follow the navigation below according to your Operating System
WINDOWS XP: Start > Control Panel > Network and Internet Connections(Network connections) > Right Click Wireless Network Connection icon > Click on View Available Wireless Network
WINDOWS VISTA: Start > Control Panel > Network and Internet (Network and Sharing Center) > On your left hand side click on Manage Network connections > Right Click on Wireless Network Connection icon > Click on Connect/disconnect
WINDOWS 7: Start > Control Panel > Network and Internet (Network and Sharing Center) > On your left hand side Click on Change Adapter Settings > Right Click on Wireless Network Connection icon > Click on Connect/disconnect
MAC OSX: Select airport icon from desktop, turn on Airport, you will be able to view the available networks in range. Select your network name enter key and get connected.
You may also click on Apple logo > System preferences > Airport > select network name
You will be able to see the Network name (SSID) which you gave in the Router, try to connect to this it will ask for password type it and click on Connect. You will get connected wirelessly and able to go online.
on May 19, 2010 | Computers & Internet
Its an asus pc 1018series need to re boot how can i perform it
Your asus netbook should have come with a White restore dvd. You will need an external dvd drive to use it.
Just put it in and it will boot to the disk and begin the restore process. Follow the instructions and you should do fine.
If it didn't come with a restore disk, You can Load XP or windows 7 from new media. Every driver you will need is provided at asus' website. You will need to load the xp version of the touchpad utility, as well as the chipset and acpi drivers, even if you choose to load windows 7.
I'm using I Eee PC 1000HE with 2 gig of ram and a single core Intel Atom n280 processor, and it runs windows 7 just fine. If you need more help, reply, and I will help as muh as I can.
May 09, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Apple Macbook Pro does not connect to wireless network
The antennas in the Macbook Pros have had an issue with reception due to the aluminum housing of the laptop but, should still receive decent reception just not as much as a plastic Macbook or plastic PC laptop. It could be possible that the antenna's cables have become disconnected from the Airport Extreme card inside your Macbook Pro, that the card itself is faulty or damaged or that the Antennas themselves have been damaged in some way. As always make sure you have the latest updates and have installed any driver updates from Apple regarding your Airport Extreme card. Here's an article that may help eliminate any wireless interference that may be affecting your signal strength. Apple - Wireless Interference hope this helps, if so don't forget to comment, vote, etc. Thank you.
May 28, 2010 | Apple MacBook Mac Notebook
Cant connect with my mac even though the router seems to work fine.I am picking up the signal and using it on my iphone
You must configure the airport to connect to your router. Make sure to put the network key in. Also make sure that your airport is enabled.
Jun 28, 2009 | Linksys Wireless-G Broadband Router
Netgear wirleless network and Asus eee 1000H-XP.
Hi try this troubleshooting steps:
Delete the preferred networks of this computer, Check the Internet connection of the Netgear and modem if working properly. Check physically your network connections, make sure that they are connected properly.
Apr 20, 2009 | NetGear DG834G Router
Macbook Airport Problems
You should check to see if you have the connection set to static or to scan. Your computer could be set to scan, and so when it recieves a stronger signal, even if it is for a second, it will disconnect from the signal you have current. You can go to system preferences , select NETWORK, go to show, then AIRPORT, make sure your signal of choice is at the top of the list.
Aug 24, 2008 | Apple MacBook Mac Notebook
Macbook Pro airport extreme
You should only use Windows xp for running a program that is not yet available from Apple. There shouldn't be much reason to link to the net while in Windows. Also while in Windows you are wide open to any viruses that exist. Try getting your work done without getting on the net, then go back to your Apple format. There you are 99% free of viruses. … Still need to link onto the net let me know I will ask at our Apple Computer Club on Monday
Dale
May 10, 2008 | Apple MacBook Pro Laptop Computer with...
Vista compatibility
Vista has very little drivers for equipment sad but true. However in your case you can use Airport Extream. However here is what an apple tech had to say: If you are a Vista user and you don't have access to a Mac, you will not be able to get this working. Apple hasn't yet stirred itself to release a version of Airport Express Assistant that works with Windows Vista - you can't set it up via Windows' own networking software and nor does the Airport Admin Utility work under Vista. It installs and you can run it, but it returns error messages if you try and connect to the Airport Express. I had to use a Mac to get it working, though once it's set up as a client to your existing wireless network, you can stream from iTunes on a Vista PC to the Airport Express. The documentation is very poor, too, with this: I had to do extensive Googling first to track down the fact that I couldn't set it up with Vista and second to identify the device's IP address and default password. Having said that, it is a breeze to set up via a Mac and works like a dream witih Vista once it's up and running. But don't bother if you have Vista until Apple updates the software. Was this review helpful to you?
Aug 23, 2007 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Apple AirPort Express (M9470Z/A) 802.11g/b (M9470ZA) Wireless Access Point Logo
116 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
