Question about Cobra 29 LTD CB Radio
Wires pulled off a cobra mic 75wxst 5 pin connector
Need to identify the color code of the wires going to a 5 pin cobra mic.
    Genius:
  • Cobra Master
  • 1,847 Answers
1) violet 2) blue 3 ) shield 4) yellow 5) grnd Violet inside the mic is the power wire . Blue and yellow are the internal and external speakers. the other wires are to the antenna
Posted on Mar 01, 2015
  • John Miller
    John Miller Jun 10, 2019
    Mike, is 'shield' wire the one wrapped in bare wire, and white the ground? I need to be sure, before I start soldering the terminals back on. Thanks!
SOURCE:
  • 39 Answers
SOURCE: NEED HELP WITH MIC WIRING FOR COBRA 25 LTD ST
1 Shield 2 White 3 Red 4 Black if the radio keys up as soon as you turn it on reverse 3 and 4 I am not familiar with that mic.But the way I actually should have given you the wiring order is as follows:1Shield 2 Modulation 3 and 4 key up I hope this helps.
Posted on Feb 20, 2009
Ironfist109
  • 3018 Answers
SOURCE: CB Radio - Cobra 29 WX ST - Need Chasis wiring
This one you will need a digram. any wiring you need is on that page. Good luck. www.cbtricks.com/radios/cobra/29ltd_29ltd_st_29wx_st/graphics/cobra_29ltdwx-st_29ltd_sch.pdf
Posted on Mar 05, 2011
  • 1212 Answers
SOURCE: I have a 1990 cobra 148 GTL with 5 pin
The wiring is not likely to be the same.
The information on the radio is here:
http://www.cbtricks.com/radios/cobra/148gtl/index.htm
You will likely need to open up the mic to identify what your wires connect to to determine the correct oreintation. it is possible too you may find one of the models listed was used by Barjan and is nothing more than a rebranded microphone.
Posted on Feb 19, 2012
maxmrossi
SOURCE: Need Cobra 148GTL with Cobra HG M75 pin-out color code
The above wiring combination does not work
Posted on Sep 16, 2012
  • 54 Answers
SOURCE: I bought 3o brand new standard cobra mics from an individual. The wire is not the standard color code. these mics do not work on cobra 4 pin radios. Whats up?
THE YELLOW I BELIEVE IS THE AUDIO LEAD WITCH GOES TO PIN 2 AND SHIELD IS PIN 1 PIN 3 IS TRANSMIT AND 4 IS RECEIVE
Posted on Feb 27, 2013
The wiring came off and don't know howe they go by color it'got5 places to salder wires are r/b/or/b
If your asking about a Cobra radio then these links will have the pin-outs plus wiring color code for different mic's.
I had to guess what you was asking for as your question was kinda vague. And a Cobra 29 is a 4 pin mike, not 5 pin.
The 148 - 142 were 5 pin. I'll include it also.
http://www.cbtricks.com/radios/cobra/148gtl/index.htm Cobra 29LTD ST 29WX ST
Aug 13, 2015 | Cobra 29 LTD CB Radio
Galaxy echo 5 pin desk mike wiring to cobra 2000?
before you go thru all the trouble of wireing it ,what kind of radio did the desk mic come from.If it came from a galaxy then you shouldn't have to change a thing. 5 pin to 5 pin try it then if you have to wire it.
Apr 28, 2014 | Cobra 148 GTL 120-Channels Base CB Radio
I need to wire a silver salute mic to a cobra 142 gtl 5 pin what color wire goes towhat mic pin
dont go by colors.. go by what wires are on the switch and mic element.. mics can be rewired and no one told you the colors could have changed FYI..
Pin #1 ~ Audio
Pin #2 ~ Shield
Pin #3 ~ Receive
Pin #4 ~ Switch Wire
Pin #5 ~ Transmit
always go by connections not color of the wire. that way you learn and you can do any mic. to any radio.
Nov 30, 2013 | Radio Communications
1audio. 1red
2shield. 2shield
3receive. 3blue
4switching. 4white
5transmit. 5black
Hope this helps
Jul 03, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
I have a 1990 cobra 148 GTL with 5 pin side-mounted mic. I recently bought a Barjan 5 pin noise canceling mic. Is the mic compatible with my cb, or do I need to change the wiring? Larry
Feb 17, 2012 | Cobra Radio Communications
I'm trying to wire a galaxy desk mic to a cobra 200 10 meter mobile
  • The Galaxy desk mic (power mic) is already wired four pin and the Cobra 200 is a 4 pin already as well. So unless someone has messed with them the mic will plug right up to the radio as is.
  • But if someone has repined the mic then follow the pinout I listed below to get it rewired for the Cobra 200
  1. Pin #1 on mic connector - Black wire.
  2. Pin #2 on mic connector - White wire.
  3. Pin #3 on the mic connector - Blue wire.
  4. Pin #4 on the mic connector - Red wire.
  • If you look on the end of the mic connector it will have the imprint of the number for each pin on the mic.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 02, 2011 | Cobra Radio Communications
Diesel #8-32 echo power mics
cobra 4 pin is pin1= shield, pin2= mic audio (usually the shield is wrapped around the mic audio wire).pin 3= transmit or push to talk usually red or white whichever isnt wrapped with the shield, and pin4 = receive or speaker complete
5 pin cobra=1-Audio 2- Shield 3-Receive 4-Switching Wire 5-Transmit, you can jump pins 4 and two
Dec 21, 2008 | Magnum 257 CB Radio
Cobra 29 LTD CB Radio Logo
457 people viewed this question
Top Cobra Radio Communications Experts
Steve Allison
Steve Allison
Chris
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
